17" Wheel and 33" Tires
Discussion in 'Wheels & Tires' started by Pat, Jul 11, 2008.
  1. Jul 11, 2008 at 12:11 PM
    Pat
    Pat [OP] Well-Known Member
    San Diego
    05 PreRunner Access Cab
    King Coilvers, 285 BFG A/T's, Moto Metal 951b's 17"
    Im going to be getting the readylift leveling kit that I was told by the shop Im buying it from and getting it installed from that I will be able to run 33" tires. My question is, can I run 17" wheels and 33" tires on it without rubbing alot? The leveling kit gives me 2.25 inches of lift. Thanks for the help!
    (Sorry if I put this in the wrong section)
  2. Jul 11, 2008 at 12:34 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    the 17" rims won't matter. it's really more the matter of the width of the rim and the offset. 33's with just over 2" of lift will almost definately rub. several members have a 3" lift with 285/70/17 and they need to do some triming.
  3. Jul 11, 2008 at 1:01 PM
    Pat
    San Diego
  4. Jul 11, 2008 at 2:39 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u'll prolly have to end up removing the front mud flaps and the inner fenders for 33's on just 2.25". roxspin had to do that w/ his. for 33's w/ minor trimming u need 3" of lift
  5. Jul 18, 2008 at 8:22 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Im running Nitto 285/70/17's (2/10" shorter than 33") on my stock 17 inch rims. you will need to go down to your local parts store and get a set of 1/4" spacers for the front wheels to get more clearance. even with the extra 1/4" the tires still rub on the upper control arm at full steer. Check out these spacers http://www.spidertrax.com/s.nl/it.A/id.2294/.f
    they are pricey and will probably require some other trimming to prevent rub but i like my stock wheels ant thy will look sweet sitting out an extra inch.
  6. Jul 18, 2008 at 2:13 PM
    wilky10
    wilky10 Active Member
    Tucson
    06 DC TRD 4x4
    I just put a toy tec leveling kit on my truck. It has a 3" up front and add a leaf in the rear. I am running BFG 285/70/17 and I am rubbing pretty good. I have not removed my mud flaps yet.
  7. Jul 18, 2008 at 2:17 PM
    The_Hodge
    SC
    yeah...u definately have to run wheel spacers to fit anything wider than a 265 on stock rims b/c of the backspacing
  8. Jul 18, 2008 at 2:49 PM
    Pat
    San Diego
    Im putting new wheels on that have a back spacing, Im going to take off all my mud flaps and Im going to have to trim a little but in the inner wheel well. Hopefully then they will fit fine with no rub. I have been talking to a guy who has a similar set up and he has no rub. The shop where I will have it done at also says it should work. Ill post pics when it gets done but it won't be for a few weeks.
  9. Jul 18, 2008 at 3:06 PM
    wilky10
    Tucson
    06 DC TRD 4x4
    I have aftermarket wheels with the backspacing and I will probably still rub when I remove the mud flaps. What material is the front end spacer made out of on the kit you are getting Pat.
  10. Jul 18, 2008 at 7:34 PM
    Pat
    San Diego
  11. Jul 18, 2008 at 7:52 PM
    wilky10
    Tucson
    06 DC TRD 4x4
    If you are not totally set on that lift, checkout Toy Tec. I had a lift like that at first and didn't like how it looked. That is why I went with 3" up front and add a leaf for 195( That included shipping). I am very happy with it.
