175 Ultra rogue wheels
Discussion in 'Wheels & Tires' started by Neve, Sep 23, 2012.
  1. Sep 23, 2012 at 4:58 AM
    Neve
    Neve [OP] Member
    Jeff
    Ohio
    2011 Black Tacoma SR5
    None
    Anyone rolling with these wheel specs? 17x8 4 7/8 back spacing +10 offset. I understand I'll need hub rings to change the 108mm that they are. To 106.1mm Tacoma's hub are. If anyone has pics, I'd really like to see. Thanks!
  2. Feb 6, 2013 at 5:47 AM
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2011 TRD Sport
    5100's, Eibachs, Light Racing UCAs, ATO Rear bumper and ifs skid, Lights, Tonno Cover, TJM Front Bumper and Slider not sure of the brand.
    Hey I know this is old but I do have these wheels and they fit I like em
  3. Feb 8, 2013 at 12:21 PM
    Neve
    Neve [OP] Member
    Jeff
    Ohio
    None
    Thanks! You don't happen to have a pic of your truck, with them on? Did you put hub rings on. Going to get them this summer.
  4. Feb 8, 2013 at 12:48 PM
    Taco Guy11
    Joe
    Western Maryland
    2011 TRD Sport
    I have pics. I like them if you have a second gen like me you won't need hub rings with the center caps they are a tight fit so its all good. The tires don't stick out real far the treat with is right at the edge of my fender flare. [​IMG]
  5. Feb 9, 2013 at 5:50 AM
    Neve
    Neve [OP] Member
    Jeff
    Ohio
    None
    Damn! Your truck looks great. I will be getting the rogues for sure seeing your truck. I do have a 2nd gen, 2011 accesss cab. Going to get the black rogue, since my truck is black. Glad to see they don't stick out pass the fender. Thanks for saving me some cash. Not having to buy hub rings. I'll send you a pic, when I get them on. My truck is straight up stock right now.
  6. Feb 9, 2013 at 7:07 AM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Truck looks good, what size tires are those?
  7. Feb 9, 2013 at 7:20 AM
    Taco Guy11
    Joe
    Western Maryland
    2011 TRD Sport
    I will warn you when you put the center caps on apply a little anti seize to the inside lip they are tight on the hub seating area. It helps to get them back off. I didn't put anti seize on the first time and had to beat the center caps back off when I changed my wheels. I contacted ultra and they said there clearance is tight an no problem and sent me four center caps for free even tho I told them I only messed two up but no problem with them when u add a little anti seize I love the wheels and like how they don't stick out too far. Glad I could help.
  8. Feb 9, 2013 at 7:20 AM
    Taco Guy11
    Joe
    Western Maryland
    2011 TRD Sport
    There just 265/70/17's
  9. Feb 10, 2013 at 4:54 PM
    rhfl
    rhfl New Member
    Did you use stock studs? What lug nut are you running?
  10. Feb 10, 2013 at 5:31 PM
    Taco Guy11
    Joe
    Western Maryland
    2011 TRD Sport
    Yea I used stock studs as for lugs I'm not sure what the part number is I would have to look but they are gorilla locks there all spline looking.
  11. May 24, 2013 at 7:28 AM
    Wickedwagens
    Wickedwagens Well-Known Member
    Mark
    Carson City NV
    07 Dbl Cab LB
    3" lift, 285/70/R17 BFG A/T
  12. Aug 31, 2013 at 11:29 AM
    bschmitt09
    bschmitt09 Welcome to the abusement park.
    Bryan
    Western WA
    Barcelona Red 2011 TRD Off-Road
    Debadged, Wheels & Tires, Delta Toolbox, LEDs interior & exterior, Spyder tail lights, Color matched grille, door handles, and rear bumper, MBRP dual exhaust.
    Bringing this thread back from the dead. Do you have wheel spacers on? I have these wheels in 18" and needed 1/4" spacers in the front because they rubbed the calipers ever so slightly. Did you have any fitment issues with the 17"? I am not aware of different calipers between the Off-Road and Sport editions...
  13. Aug 31, 2013 at 7:29 PM
    Taco Guy11
    Joe
    Western Maryland
    2011 TRD Sport
    No issues with the 17's fit fine didn't hit a thing looked great just wasn't the look I was going for
