17x9 wheels - will tires rub UCA?
Discussion in 'Wheels & Tires' started by Iakopa84, Jul 25, 2011.
  1. Jul 25, 2011 at 3:26 PM
    Iakopa84
    Iakopa84 [OP] Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    I got some 17x9 wheels with 5" backspacing, 0 offset and mounted one on the truck to get an idea of how it'll look. After mounting, it looked pretty close to the UCA, and I thought with a tire mounted it would rub the UCA.
    Is anyone running a 17x9 wheel size with 5" backspacing on their truck? Or do you think this combo would rub?
    Thanks!
    Oh, and I did some searching on here before I posted this. I saw some similar threads, but none with this combo. If there is one, can you point me to it?
  2. Jul 25, 2011 at 3:28 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes..............and no. Depends on the tire. 275 or less should fit fine.
  3. Jul 25, 2011 at 3:34 PM
    Iakopa84
    Jake
    Escondido, CA
    I don't really care that much about the tire width... just whatever is sufficient for fitting the 9 inch properly. Would 265 be too small for that width?
  4. Jul 25, 2011 at 3:43 PM
    98tacoma27
    Ben
    Not Beech Creek
    That depends on the specific tire. A 265/70-17 MTR Kevlar is designed for a 7-8.5" rim. The same size Fortera TripleTred is designed for a 7-9" rim.
  5. Jul 25, 2011 at 3:56 PM
    Iakopa84
    Jake
    Escondido, CA
    Thanks!
    Since I haven't had the wheels mounted yet... I may just take them back.
