18" ATX Mojave on 2012 DC?
Discussion in 'Wheels & Tires' started by Tyheel, Jan 17, 2012.
  1. Jan 17, 2012 at 4:48 PM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
    My stock wheels are:
    18" X 7.5"
    Offset 25
    and I'm thinking of going with ATX mojaves that are
    18x9.5 wheel size
    6 on 5.5 bolt pattern
    Backspace = 4.31in.
    Will the tires work? Can I use my stock tires at 265/65-18 on them?
  2. Jan 18, 2012 at 5:59 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I doubt that the 265/65/18's are approved for use on 9.5" rims. You can check on the tire manufacturers website.
    Either way those wheels are going to stick out 3" more than stock and will likely lead to rubbing on the outer edge of the tire.
    If you want to run the 265/65/18's you should look at wheels that are 8-8.5" wide (in some cases you can run 9", check the tire manufactuered website), with around 5.0 backspacing give or take.
  3. Jan 18, 2012 at 6:02 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    took the words right out of my mouth actually not at all but you are the tire/wheel genius
  4. Jan 18, 2012 at 10:02 AM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
    Thanks KPT and EasyE. Trying to do this a little$ at a time to avoid spousal sticker shock and the resulting divorce.
  5. Jan 18, 2012 at 1:00 PM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
  6. Jan 18, 2012 at 1:07 PM
    KPT
    09 Prerunner
    A good rule of thumb is to believe the exact opposite of anything 4wp says....ever. You will be fine moving from a 18 to a 17.
    Did you check that the duratracs are approved for 9" wide rims in the 265/70?
  7. Jan 18, 2012 at 1:09 PM
    KPT
    09 Prerunner
    Also, the link you provided has a wheel with 4.75" BS, not 5.
    And I checked on the duratracs, they are only approved up to 8.5" rims.
  8. Jan 18, 2012 at 5:39 PM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
  9. Jan 18, 2012 at 5:54 PM
    KPT
    09 Prerunner
  10. Jan 26, 2012 at 10:29 AM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
    Just got them installed last night and managed to shoot a crappy iphone pic before the sun went down. Very slight rubbing in a right turn but I think a dremel should take care of that this weekend. Next mod will probably be a hard or soft shell with a 3" lift this Summer.
  11. Jan 26, 2012 at 10:32 AM
    Tyheel
    Tyheel [OP] Member
    Colorado
    2012 TRD Sport DC
    PS I checked with Black Rock before the wheels came in. I guess their earlier version had some trouble with caliper clearance but they fixed it months ago. There was a fitment guide on their Website at blackrockwheels.com it was a little hard to find but they've done the test fitting.
  12. Jan 26, 2012 at 11:04 AM
    KPT
    09 Prerunner
    Good to know. Wheels look great.
