+18 wheel offset is rubbing bad
Discussion in 'Wheels & Tires' started by mash25, Jun 18, 2012.
  1. Jun 18, 2012 at 2:55 PM
    mash25
    mash25 [OP] Roll Tide Roll
    Mark
    Bama
    '08 DC Sport 4X4..
    TGC 3'' lift,18'' Addicts,33'' Trail Grapplers
    I have a 2.5 spacer lift and just put on 285/65/18 trail grapplers and 18" xd addixts..and they are rubbing the Ucas bad bad...would 1.25 spidertraxx help me or make it worse I need some info pretty quick here thanks!!!
  2. Jun 18, 2012 at 3:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    The spacers should help but I havent heard of anyone running that offset wheel before so I wouldnt know for sure if it would completely get rid of your rubbing issues. I have -12mm offset wheels like everyone else.
  3. Jun 18, 2012 at 3:05 PM
    kane
    kane Well-Known Member
    s.w. missouri
    2011 TRD Sport DC 4x4 6" pro comp
    6" pro comp stage 1, Debadged, Tint
    Should help with rubbing on uca but may cause to rub in other places .... need more info ... bs/wheel width etc.
  4. Jun 18, 2012 at 3:09 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not surprising at all. Those wheels aren't designed for tacomas. You needed one with 4.5" BS, which would be -12 offset, assuming this is a 9" wide wheel.
    A 1.25" spacer would help if exchanging the wheels for the right ones isn't an option.
  5. Jun 19, 2012 at 1:22 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Ok guys thanks for the help...I talked to the guy I ordered them from and he wanted to put spacers on it since he ordered the wrong ones and a long story short I raised hell and my new set with -12 offset will be here in a couple days....
  6. Jun 19, 2012 at 1:39 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Nice! They will work out perfect but you will still have to do some minor trimming.
