18" Wheels on 1st Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 94TTM6, May 16, 2013.
  1. May 16, 2013 at 10:13 PM
    94TTM6
    94TTM6 [OP] Member
    Aaron
    Victoria, BC
    96 Tacoma 4x4
    Bone Stock...129K (80k Miles)
    Hey Guys/Gals,
    I am new to this forum and just recently acquired a 96 Tacoma. Now obviously the first thing we want to do with these machines is ditch the factory pizza cutters, elevate the SOB and slap on some meats! :) Now I know offsets and lift kits have been beaten to death but I just wanted some opinions on my new 18" wheels (18x9) with +20 offset and the likelihood of fitting 33x13.5's (Mickey Thompson ATZ) with a 3" lift. I am thinking a spacer will be needed to bring the wheels out and I am not so sure I wanna go that route. Thoughts...
  2. May 17, 2013 at 6:16 AM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    I personally don't see you being able to fit 33"s with a +20 offset without some serious trimming. (Chopping is more like it) Most people I see on here run negative offsets or a low BS and some still need spacers for 33"s. Especially that wide.
  3. May 17, 2013 at 6:55 AM
    firetaco74
    firetaco74 Member
    Tyler
    Washington, North Carolina
    04 Tacoma, sr5 trd 3.4, 4x4
    3" body lift, 16" Mickey Thompson Bullet Holes, 33" Mastercraft Courser AXT All Terrains, Flomaster Duals, High Flow Cat, Resonator delete
    What kind of offset you running? it its the factory toyota offset you should be fine. If you used the chevrolet offset it would work with at most a 12.50 tire. I got a buddy who has a 33/12.50/20's on his tacoma with just a leveling kit. just a word to the wise. i personally wouldn't run a 13.50. its just more trouble you have to deal with the scrubbing and everything. hope this helped in your decision making
  4. May 17, 2013 at 2:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No way a 12.5 will fit on stock offset. It'll rub the UCAs and frame while turning.
    Also 13.5s you'll need at least 3.5" BS to be safe and get ready to cut a ton out if your fenders.
    Wulf likes this.
  5. May 17, 2013 at 6:37 PM
    94TTM6
    94TTM6 [OP] Member
    Aaron
    Victoria, BC
    96 Tacoma 4x4
    Thanks for the responses guys! I just had an opportunity to buy these tires for cheap so I thought if it could work it wouldn't be all that bad. Now if I were to add some 1.5" spidertrax spacers into the mix, that would recreate my offset to a -17.5 on these wheels. Still rubbing issues or would I sneak by?
  6. May 17, 2013 at 6:40 PM
    94TTM6
    94TTM6 [OP] Member
    Aaron
    Victoria, BC
    96 Tacoma 4x4
    These wheels have +20 offset. Any idea what offset your buddy is running on his 20s?
  7. May 19, 2013 at 4:57 PM
    firetaco74
    firetaco74 Member
    Tyler
    The guy he bought them from told me but I can't remember, I think it was a -12, cause it has a 4.5" backspacing. Ohh and BTW its not my buddy, its my brother, stupid computer. Anyway, if they have a +20 backspacing, you may want to invest in some wheel spacers.
    Check out this link: http://www.google.com/imgres?imgurl...GSZUY6HENi64AOXnIHgDw&ved=0CDAQ9QEwAQ&dur=330
    It helped us decide what backspacing we had to have. Most chevys have the same backspacing, hub size, and lug pattern as a lot of the Toyota's. If that doesn't help, call around to local businesses and talk to their Tech guys.
  8. May 20, 2013 at 9:30 AM
    94TTM6
    94TTM6 [OP] Member
    Aaron
    Victoria, BC
    96 Tacoma 4x4
    Nice! Thanks for the info sir. I bought the tires and will be mounting them up when I get a few inches under her. I will be buying 1.5" spacers as well to make it work. I am a sucker for doing what some people say can't be done. I am in no rush as my Supra is priority at the moment so I will be collecting parts and hopefully post pics sometime in June.
  9. Mar 22, 2021 at 7:41 AM
    Txwelder1
    Txwelder1 New Member
    Nate
    96 tacoma
    96 3 inch spacer in front 2 inch block in back ,18 inch wheels on 285 75 18. Idk they look too big sometimes, and other angles it looks badass. Whatchawl thank??
  10. Mar 22, 2021 at 7:42 AM
    Txwelder1
    Nate
    96 tacoma
  11. Mar 22, 2021 at 9:17 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    o_O :crazy: :facepalm: :smack:
