18x9's and a 3" lift
Discussion in 'Wheels & Tires' started by Diverstj, Apr 17, 2010.
  1. Apr 17, 2010 at 9:13 PM
    Diverstj
    Diverstj [OP] Member
    Virgin Islands
    '09 TRD Off Road 4x4
    Custom Aluminum Rack Pioneer AVH 3200DVD JL Audio HD 600/4 amp JL Audio HD 750/1 amp 2 pair Boston Pro 60 SE's 2 Polk MM 1040 10" subs 3" lift Vent Visors Bugflector Front tint
    I've researched wheels, tires and sizes like crazy and I'm gonna' throw my selection out there for feedback before ordering. I'm a rookie at this kind of mod.
    '09 Taco DC TRD Off Road
    3" billet spacer lift w AAL's in back
    hoping to do BF Goodrich Mud Terrain KM2's 305/60/18 mounted on XD Hoss 18x9's with -12 offset (4.53 backspace)
    am I missing something?
  2. Apr 18, 2010 at 8:38 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    With 305's you are going to have to do a lot of trimming. You may also have to chop the body mount.
  3. Apr 18, 2010 at 8:41 AM
    bmxutah
    bmxutah Member
    Orem, Utah
    02 tacoma sr5 trd
    3'' Procomp lift 33'' bf ko 18'' wheels
    its gonna rub a ton! need to go bigger on the lift.
  4. Apr 19, 2010 at 5:15 AM
    Diverstj
    Virgin Islands
  5. Apr 19, 2010 at 5:36 AM
    KPT
    09 Prerunner
    ^^^ You will still have to trim, but that is a size a lot of people are running with no problems after trimming.
  6. Apr 19, 2010 at 6:17 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Can I ask you a question? Are you a serious hard core wheeler? Just wondering because your about to make some pretty big changes. Gonna hafta cut up your new truck to fit those tires. Also those bfg ta ko's are extremely heavy and will kill your power and gas mileage. Just a few things to think about.
  7. Apr 19, 2010 at 7:39 AM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    The 285s will "kill" the power and gas millage? I don't think so. What am I missing?
    285s with a 3" lift may require a little trimming but from my research you wont have to trim much. I know guys that run 285/70/17 BFG ATs with a 3" lift and didn't have to trim anything so I think it varies from truck to truck.
  8. Apr 19, 2010 at 7:54 AM
    TacoSupreem
    Hayden
    Kentucky
    The tires he's looking at weigh as much as his stock wheels and tires combined! That can't be good for gas mileage?
  9. Apr 19, 2010 at 4:44 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You won't lose power (the engine still puts out the same amount of power), but it will feel less powerful. A taller, heavier tire is going to take more power to turn.
    As weight increases, the power required to turn the wheel is greater. Also, the further out that weight is, the more power it will take. Same with diameter. For two tires of equal weight, the larger diameter tire will be more difficult to turn. Combine the two (larger diameter and heavier) and you require even more power to turn it. More power to turn it means more gas, hence, less mpg.
    It's not as pronouced on the manuals as we're geared higher. But it is noticable.
  10. Apr 19, 2010 at 5:44 PM
    TacoSupreem
    Hayden
    Kentucky
    Well said Mr. Evil Monkey!
  11. Apr 19, 2010 at 6:22 PM
    jmed99
    SC
    I understand the physics....just didn't think 285s would "kill" the power and gas mileage.
  12. Apr 19, 2010 at 6:44 PM
    TacoSupreem
    Hayden
    Kentucky
    ever try to pick up a bfg ta ko in a LT285/70/17? they are a very heavy and well made tire! our trucks come with those cheap rugged fails that dont weigh nothin cause they dont have any sidewall! lol I'm just sayin a stock truck may get 20mpg and when you start adding all that unsprung weight it'll drop a pretty good amount.
  13. Apr 19, 2010 at 6:53 PM
    Evil Monkey
    Robert
    Escondido, CA
    It didn't really kill mine (maybe 1mpg?). I still get 18mpg highway, which is good for a manual. I think it actually makes the manual's gear ratio more useable. I can't really speak to the autos though.
    I think it depends on the type of driving you do as well. If you're mostly city driving, then it will probably affect you more.
  14. Apr 19, 2010 at 7:01 PM
    TacoSupreem
    Hayden
    Kentucky
    I guess i shouldn't have said kill? I mean it will have a negative affect on performance and gas mileage!
  15. Apr 19, 2010 at 7:02 PM
    kingtaco
    kingtaco Well-Known Member
    San Gabriel Valley
    I'm running 305-60-17 and I only had to trim a small piece of plastic on the inside front of the wheel well. My gas mileage didn't change much and I notice a small amount of power loss at take off but not enough to matter. The tires are a little heavier but like I said not enough to matter.
  16. Apr 19, 2010 at 7:04 PM
    TacoSupreem
    Hayden
    Kentucky
    Well your odometer is off too so you can't use that to determine fuel economy.
  17. Apr 19, 2010 at 7:07 PM
    kingtaco
    San Gabriel Valley
    There are other ways to determine gas mileage and speed than your stock instruments.
  18. Apr 19, 2010 at 7:09 PM
    TacoSupreem
    Hayden
    Kentucky
    ^^^This is true. Nav.
  19. Apr 19, 2010 at 7:20 PM
    Evil Monkey
    Robert
    Escondido, CA
    Plus mileage would be worse if you didn't take tire size into consideration.
  20. Apr 20, 2010 at 6:33 AM
    Diverstj
    Virgin Islands
    Thanks for all the input. I ordered just the wheels last night. I'm not a serious off-roader. I'm a contractor in St. John US Virgin Islands and a lot of roads are unpaved and lots of rock. As for fuel economy I hope it doesn't get too much worse!! The island is mountainous therefore I only get about 12mpg as is (if I'm lucky!!!)
    The lift arrived yesterday and is going on shortly.
