1986 22RE Rebuild or replace motor
Discussion in 'Hilux' started by mvparadise, Aug 4, 2020.
  1. Aug 4, 2020 at 8:57 PM
    mvparadise
    mvparadise [OP] Well-Known Member
    2013 Toyota Crew cab 4x4
    Have a 22RE with 51K four speed. Got some rattle noise and took it to a repair shop and was told the motor might be shot or the fly wheel could be loose. any idea what a rebuild costs if the worst happens. Thanks
  2. Aug 5, 2020 at 4:07 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Is that a replacement engine?
  3. Aug 5, 2020 at 6:54 AM
    mvparadise
    Hoping to have it rebuilt or new if that cant be done.
  4. Aug 5, 2020 at 7:54 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    51K really? I have an 86 22R, I replaced my timing chain at 180,000 and am currently 345,000 on original motor. The 22R motor is pretty solid, I would start with the simpler things before looking at a full rebuild.
  5. Aug 6, 2020 at 6:36 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    The reason I asked is because they didn't put 22RE engines in 86 Hiluxs. Don't think they went FI (22RE) until 1989?
    I had one issue with my 94 Hilux, which was the cogs on the timing chain lost some teeth. But I already had the "dual roller" timing chain conversion kit from LCE. Once that went on, the engine was probably good to go for 1,000,000 miles.
  6. Aug 6, 2020 at 7:35 AM
    mvparadise
    The motor is in a Sunrader motor home. vin is 1986. Makes a rattling sound that the repair shop says it sounds deep in the motor?
  7. Aug 7, 2020 at 7:12 AM
    la0d0g
    running for the hills
    For crawling not hauling
    86 was the first year. You could get 22r or 22re later in the year.
    EdgemanVA[QUOTED] likes this.
