1986 toyota pickup help needed
Discussion in '4 Cylinder' started by ezjumper8, Mar 26, 2014.
  1. Mar 26, 2014 at 10:00 AM
    ezjumper8
    ezjumper8 [OP] Ethan
    ethan
    camp pendleton, ca
    white tacoma dbl cab 4WD sport
    20% tint all around, blacked out badges, flowmaster 40 series and tip, rock hood deflectors, window deflectors, home made baja bumper, 17" XDseries wheels on some nitto terra grapplers, bright white led interior lights, blue needle on white gauges, cb antenna, with cobra radio.
    I just recently bought a 1986 toyota pickup 4x4 with a 22r motor in it and it starts and everything but can't seem to keep it running. We changed the plugs, rebuilt the carburetor have a secondary gas line so it is getting gas, played with the timing. Not sure what it is, any help would be appreciated .
  2. Mar 26, 2014 at 11:07 PM
    nettto
    nettto Active Member
    San Diego
    2013 Tacoma 2.7l
    Couple guesses to throw out - choke on the carb not opening up fully, bad fuel pump / filter. Last engine I worked on with a carb was a Toyota 2F and that was a while ago. Good luck!
  3. Mar 26, 2014 at 11:26 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Are you trying to run it with the air cleaner off?
    My buddy had this problem.
  4. Mar 27, 2014 at 7:58 AM
    ezjumper8
    ethan
    camp pendleton, ca
    Yeah ill try all those and see if it solves the problem. And yes I am trying to run it with the air cleaner off
  5. Mar 29, 2014 at 3:12 PM
    ezjumper8
    ethan
    camp pendleton, ca
    alright so i put everything back to gather and it is running now and keeping a better idle, every now and then it'll back fire. my next problem is the 4wd, it says that it is in 4wd on the dash but the shifter it feels like there is nothing there. So just curious how to fix this?
