1989 pick up starts sometimes please help
Discussion in 'New Members' started by bblancha, Jan 4, 2012.
  1. Jan 4, 2012 at 7:04 PM
    bblancha
    bblancha [OP] New Member
    89 pick up
    i have a 1989 toyota 4by4 i started having problems with it starting all the time it always turns over fine just doesnt always start. i changed coil,distributor cap, rotor,plug wires and it still does the same thing. If i spray starter fluid in the intake it starts somtimes and runs fine somtimes i spray it it starts with up and runs rough a little while and kills please help
  2. Jan 4, 2012 at 7:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    did you change the plugs?
  3. Jan 4, 2012 at 7:23 PM
    Spike8844
    Spike8844 Active Member
    Spike
    Minot, North Dakota
    04 SR5 4X4 TRD
    Topper, Bedliner, Bedlining the Rocker panels next.
    Check to make sure your getting fuel. If you spray starter fuid in there and it runs, it makes me think that its your fuel pump. Try changing your fuel filter first. If that doesnt help your probably going to need to replace your fuel pump.
  4. Jan 4, 2012 at 7:24 PM
    bblancha
    89 pick up
    nope shore didnt yet when it was still doing it after i changed all that i thought it might have been a fuel problem then??
  5. Jan 4, 2012 at 7:25 PM
    Spike8844
    Spike
    Minot, North Dakota
    04 SR5 4X4 TRD
    But be careful with the starting fluid because if you use it too much the motor will become dependant upon it. Just a heads up.
  6. Jan 4, 2012 at 7:26 PM
    bblancha
    89 pick up
    after i spray starter fluid it runs fine after it gets goin would it do that if its the fuel pump??
  7. Jan 4, 2012 at 7:46 PM
    Spike8844
    Spike
    Minot, North Dakota
    04 SR5 4X4 TRD
    Yes it would but I would still start with the fuel filter because 1 its cheaper and 2 it cant hurt. Your filter might be too clogged and it cant get the initial PUSH through. After it Starts, there is also a draw coming from the other side. I would buy both and do the filter first, if that fixes it, then return the fuel pump. If not, replace the pump. Hope this helps!
  8. Jan 4, 2012 at 7:51 PM
    bblancha
    89 pick up
    Thanks allot appreciate it
  9. Jan 4, 2012 at 8:05 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I am agree with Spike884, start with the cheapest first. Do not open the fuel pump box until you have tried the filter first. It will be easier to return if not needed.
  10. Jan 9, 2012 at 12:45 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
