1990 3.0 manual transmission bolt issue
Discussion in 'Toyota Trucks & SUVs' started by bde3183, Aug 10, 2010.
  1. Aug 10, 2010 at 6:50 AM
    bde3183
    bde3183 [OP] Member
    Texas
    08 TRD Offroad Debadged
    TRD Colad air Intake,Borla Cat Back Exhaust,Complete Clifford Alarm System w/ Bed Monitoring,Custom 185 Amp Alternator,Alpine 9887 Head unit,Alpine HD Radio Module,Alpine Bluetooh,JL Audio HD 600/4 Amp,JL Audio HD 750/1 Amp,JL 10W7 Sub,Focal 165 KPS Components (Front),Focal 165 CVX Coaxial (Rear)
    I am removing a manual transmission from a 1990 3.0 4x4. I have been sailing along but when I get to the top two bolts as well as the next one down on the right (by the starter) i do not have the room the break the bolt loose. I have tried my pneumatics etc and I cant get them. I think they were over torqued. Any ideas?
  2. Aug 10, 2010 at 2:30 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I think when I replaced my clutch in my '94 we attacked it fomr the top (through the area where the shifter used to be). Can you get in there to get a braker bar on it?
  3. Aug 10, 2010 at 2:33 PM
    bde3183
    bde3183 [OP] Member
    Texas
    I will try that and reply back. I had not thought of that approach. Thank you.
  4. Aug 10, 2010 at 2:38 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Breaker bar and a u-joint. Thats how I did my 1991 3.0. From under the truck.
  5. Aug 10, 2010 at 2:51 PM
    bde3183
    bde3183 [OP] Member
    Texas
    I tried to use a ujoint and a breaker from below but the fame and other things get in my way. I have literaly 2 inches to turn the breaker bar. I only have one bolt above the starter left that I can fit a socket on and that is the one giving me issues. The top two I think I can get with a wratchet wrench. I have worked on three tacos that i have owned and this is the most dificult bolt yet! thanks for the advise.
  6. Aug 10, 2010 at 2:54 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    use your leg
  7. Aug 10, 2010 at 8:21 PM
    desertdude59
    The leg works. lol. Mine is lifted so it is easier to get under the truck.
  8. Aug 11, 2010 at 8:51 PM
    Masada
    Taylor
    Laveen, AZ
    so did you ever get those bolts off?
  9. Aug 12, 2010 at 4:08 AM
    bde3183
    bde3183 [OP] Member
    Texas
    Not yet. I plan to hit it tonight.
  10. Aug 12, 2010 at 5:04 AM
    Masada
    Taylor
    Laveen, AZ
    Oh ok, cool good luck man :)
