1991 4Runner with blown head gasket
Discussion in '4Runners' started by ‘91Runner, Nov 28, 2023.
  1. Nov 28, 2023 at 6:20 PM
    ‘91Runner
    ‘91Runner [OP] New Member
    1991 4Runner
    3.4 Swap
    I have a 1991 4Runner that I just picked up and Im wondering if I should replace the head gasket or just get a whole new engine. It has the 3.4 swap in it with only 70k miles on the engine. It started up and ran fine when I would drive it and it never over heated. I decided to take the throttle body off and clean it, when I put it back on it would not start and run properly. We figured out there was coolant going in places it shouldn’t. What should I do?
  2. Nov 29, 2023 at 2:18 PM
    NorthPark
    NorthPark Well-Known Member
    My friend just bought a '70k on the engine' swapped (1998) truck about a month ago. The last I heard he was doing the rear main seal now, after having the heads machined and loads of other work done.
    I couldn't answer you question, but my friend went in thinking it was just a head gasket and it turned into a gigantic time sink and money pit. To me, known working 3.4's that I see for sale in the $1300-1600 range seems reasonable. I see known and proven 3.4 engines sold locally often enough.
    I have a hard time trusting the claimed miles on these swaps when the engine is pushing 25 years old
  3. Jul 5, 2024 at 8:12 AM
    lbhsbz
    lbhsbz Well-Known Member
    You likely stuck the hoses back on the ISV in the incorrect spots...there are 2 coolant lines and one air line...if you put a coolant line where the air line goes, it'll fill up with coolant.
    Superdave1.0 likes this.
