1994 Pick-up 4x4
Discussion in 'Toyota Trucks & SUVs' started by Lunijo, Mar 22, 2011.
  1. Mar 22, 2011 at 10:50 AM
    Lunijo
    Lunijo [OP] Member
    Ethan
    Anchorage, AK
    Hey all, I am in the market for a truck, i saw this truck on craigslist yesterday and i am very interested, was just inquiring if any one out here thought it is a decent deal (limited knowledge on trucks)
    http://anchorage.craigslist.org/cto/2276918048.html
  2. Mar 22, 2011 at 10:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    $4900 is a little high. It blue books at $3125 in excellent condition. That's without knowing all of the goodies. I would try to get him down to the $3000-$3500 range. Also, it is due for a timing chain change judging by the mileage.
  3. Mar 22, 2011 at 11:03 AM
    Lunijo
    Lunijo [OP] Member
    Ethan
    Anchorage, AK
    I had forgotten about the timing chains, my excitement comes from the mileage, up here in Alaska it is difficult to find a 2000-20004 below 100k let alone a 94 with just over that amount.
  4. Mar 22, 2011 at 11:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's not so much the chain the needs replaced. It's the guides. They are plastic and when they fail, it causes the chain to rub through to the water pump. Been there, done that, sicked major kahoonies. It's typically the right side (looking at the motor from the front) that breaks.
  5. Mar 22, 2011 at 11:24 AM
    Lunijo
    Lunijo [OP] Member
    Ethan
    Anchorage, AK
    ya that doesn't sound like a fun situation to go through, but ok, so general idea is to try and talk them down a bit.
  6. Mar 22, 2011 at 11:48 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Location affects price.
  7. Mar 22, 2011 at 12:01 PM
    Lunijo
    Lunijo [OP] Member
    Ethan
    Anchorage, AK
    hmm, true, well honestly i will give him a call today, try to set something up for friday or so, what might be some questions i should have in mind? i have to timing chain question in my head now (thanks 98taco) any others i should keep in mind?
  8. Mar 22, 2011 at 12:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    Just the basics. Ask about maintenance schedules and if any major problems have occurred. Test drive of course. And enjoy.
    • Transfer and tranny fluid changed?
    • Front and rear diff fluid changed?
    • A/C work?
    • Last plug change?
    • Coolant change?
    • Water pump?
    • Brakes good?
  9. Mar 22, 2011 at 12:55 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i think it may be a little over priced as said above, but everything in alaska sells for more. so that could be a deal for you up there ya know?
  10. Mar 22, 2011 at 1:27 PM
    Lunijo
    Lunijo [OP] Member
    Ethan
    Anchorage, AK
    Honestly I have been lurking around Craigslist for a while and for Alaska the state that truck is in does make it a bit of a deal, and plus its an early 90s Toyota, those years have always held fun vehicles, such as the previa ;)
