1994 Tacoma Topper... Will it fit my 2004?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reverend, Feb 21, 2010.
  1. Feb 21, 2010 at 7:19 PM
    Reverend
    Reverend [OP] Active Member
    David
    Baltimore
    2004 4-Cylinder Extra Cab
    Hi,
    Newbie Question Alert!
    I'm thinking of buying a 2nd hand topper from a 1994 Tacoma for my 2004. Does anyone know if the years are compatible?
    Thanks!
  2. Feb 21, 2010 at 7:20 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    It might go on, but it will not match up. They are a different shape and size.
    GA
  3. Feb 21, 2010 at 7:26 PM
    Reverend
    David
    Baltimore
    Thanks Gavonder... How far back can I go? Do you know?
  4. Feb 21, 2010 at 7:31 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    1995-2004 should be the same.
    there are no 1994 tacomas
  5. Feb 21, 2010 at 7:32 PM
    gavonder
    Bethel, Ct
    I think 2001, but not positive.
    GA
  6. Feb 21, 2010 at 7:32 PM
    Ramphonic
    Ramphonic Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    95.5 as long as its off an extracab Taco. The back of the cab is different on a reg cab
  7. Feb 21, 2010 at 7:38 PM
    gavonder
    Bethel, Ct
    Guess I'm wrong. I thought it was changed in 2001, but maybe it was just a face lift.
    GA
  8. Feb 21, 2010 at 7:42 PM
    Reverend
    David
    Baltimore
    so there's a chance this 1994 might fit right? I've already messed up my bedrails and tailgate by putting the wrong cap on my beloved truck... I want the right thing now and I'm on a really limited budget, so...
  9. Feb 22, 2010 at 8:47 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No - it won't fit 'right'. As already mentioned, the bed dimensions are different between 1989 - 1995 PreTacos and 1995.5 - 2004 Tacomas.
    Also - as already mentioned - it would be better if you locate a cap / canopy / shell designed for an XtraCab.
  10. Feb 23, 2010 at 2:40 PM
    Reverend
    David
    Baltimore
    Hey Enola, as already mentioned, thanks for the advice.
    Rev.
