1995-2004 3.4L V6 fabricated solid motor mounts for sale
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Bonzen, Oct 13, 2015.
  1. Feb 7, 2023 at 1:22 AM
    #301
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Nice. Can’t wait for mine to arrive.
  2. Feb 7, 2023 at 11:39 AM
    #302
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Glad they are showing up :D
    The balance of the GB kits should be in the mail this week.
    Please don't forget to ship me your steel block bracket cores back when you do the swap, instructions are provided!
    drr likes this.
  3. Mar 29, 2023 at 9:43 AM
    #303
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Just a reminder, when you swap out your kits to the new ones, please save the steel engine block brackets, as I will send you some $$ for them as usable cores.
    Instructions for this were shipped with every kit:D
  4. Apr 3, 2023 at 8:51 AM
    #304
    manapiko
    manapiko Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Well, if you happen to have thrown away those instructions, can you DM them to me? I saved all the stock stuff.
  5. Apr 3, 2023 at 9:14 AM
    #305
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Uploaded file for the instructions:
    manapiko[QUOTED] likes this.
  6. Apr 6, 2023 at 11:08 AM
    #306
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    anyone swapped them out yet?
  7. Apr 6, 2023 at 1:57 PM
    #307
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I swapped the passenger side out last weekend, while I had the transmission and starter out. Still a damn pain in the ass with that AC bracket, but mostly with removing the stock mount. I did have to bend the little tabs on the perch out of the way for the new mount.
    I’ll do the drivers side next weekend, if all goes well.
    Bonzen[QUOTED][OP] likes this.
  8. Apr 6, 2023 at 5:16 PM
    #308
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    The AC bracket is the biggest PITA on that one bolt for sure
  9. Apr 6, 2023 at 5:23 PM
    #309
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not yet. Hopefully in a couple of weeks.
  10. Apr 12, 2023 at 10:35 PM
    #310
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I’ll be doing mine when I swap engines, might be a while.
  11. Apr 26, 2023 at 5:10 PM
    #311
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    I have a few kits in stock of the 3.4, if anyone is looking for a set soon!
    unstpible likes this.
  12. May 2, 2023 at 11:53 PM
    #312
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Hmmmm. Just maybe
  13. May 3, 2023 at 12:00 PM
    #313
    manapiko
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Or buy a used set from me, trans included! (not to thread jack, since Bonzen makes an incredible product!)
  14. Nov 1, 2023 at 7:34 PM
    #314
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    If there is enough interest, I will do a group buy for a "black friday" type deal. This would apply to 3.4V6 motor mount kits. If you want a different vehicle specific kit, we can work a comparable price out.
    Minimum 5 kits sold, and we will make this happen.
    $400 per kit if 5 people commit.
    $375 per kit if 10 people commit.
    Plus $20 shipping.
    Bulk sales (GB) allows me to buy in bulk from my suppliers and therefore I can lower the prices for you guys.
    drr and unstpible like this.
  15. Nov 1, 2023 at 7:56 PM
    #315
    unstpible
    Derek
    Cedar City, Utah
  16. Nov 2, 2023 at 12:53 AM
    #316
    ChargedSHOTaco
    I absolutely love the way the solid motor mounts makes my truck with a manual transmission feel. I also added a solid transmission mount. It did induce some buzzing at the dash, but nothing some foam seal couldn’t fix.
    unstpible, 19975lugger and Bonzen[OP] like this.
  17. Nov 2, 2023 at 10:40 AM
    #317
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    The 1st gens are over 20 years old now, there are bound to be some dash rattles and loose components. Thank you for that quick fix idea, I'll pass it along!
  18. Nov 30, 2023 at 8:34 AM
    #318
    highvelocitytaco
    highvelocitytaco Well-Known Member
    queens ny
    1996 2.4 tacoma 2wd
    Do have these in stocks still? And do you make an automatic transmission mount?
    rjsimz likes this.
  19. Dec 2, 2023 at 2:13 PM
    #319
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    I build all the orders as they come in, basically building a kit everyday so I cant even find time to build anything for stock on the shelves haha.
    If its listed on the website, its available:thumbsup:
  20. Dec 4, 2023 at 12:42 PM
    #320
    highvelocitytaco
    queens ny
    1996 2.4 tacoma 2wd
    Just ordered my set super pumped on making the best truck ever made even better.
    Bonzen[OP] likes this.
