1995-2004 3.4L V6 fabricated solid motor mounts for sale
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Bonzen, Oct 13, 2015.
  1. Dec 16, 2015 at 8:54 AM
    #41
    Cknight024
    Cknight024 New Member
    Connor
    San Diego Ca
    98 tacoma ext cab 3.4 5sp
    Jd log travel kit cold air intake exhaust
    I will have to get your email and keep it. Will need these soon in my long travel Tacoma. I see your in San Diego to
    06HAOLE likes this.
  2. Dec 16, 2015 at 11:30 AM
    #42
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    I'm not 100% sure if my motor mounts work on the 3.4 V6 2wd 5 lug trucks. I designed them around the 2wd prerunner and 4wd frames. The block is obviously the same and the center section but I'm concerned that the distance to the frame perch may be different.
  3. Dec 16, 2015 at 1:09 PM
    #43
    MrHentoni
    MrHentoni New Member
    Tanner
    Littleton, CO
    Stella (00 4Runner)
    Just ask... there's a lot.
    Any idea if these will fit on a 2000 4Runner 3.4l? I'm not sure if the mounts are different between the 2 platforms.
  4. Dec 16, 2015 at 5:39 PM
    #44
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    heh heehhhh. 5speed for the win!
  5. Dec 16, 2015 at 7:20 PM
    #45
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  6. Dec 16, 2015 at 7:41 PM
    #46
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Ill have to research the part numbers. They "should" be the same as the block/center rubber piece and the frames were all the same for the 4wd/prerunner trucks and the 4runners had the exact same front suspension and mount points.
  7. Dec 16, 2015 at 7:43 PM
    #47
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Don't get too down on the auto...it robs a bit more power but if you keep it running cool it will outlast any 5 speed. I have blown up around ten 5speeds from heavy offroading and racing. 3rd gear is the weak link, it blows the teeth off it from heavy shock loading.
    Digiratus likes this.
  8. Jan 7, 2016 at 6:37 PM
    #48
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Just completed the prototype for a member on here. This is a perfect compliment to my solid motor mounts and is based around the same hard polyurethane bushings. Bolts to the stock factory cross member (new bolts will be supplied) and to the aluminum transmission case. No modification/fabrication required. Have a truly solid mounted drivetrain for serious off-roading and more positive throttle response. The 3.4L manual transmission and T-case is extremely heavy and is a lot of weight to be supported by solid motor mounts alone! I have personally cracked the aluminum housing from over flexing of the stock tranny mount and in conjunction with broken/over flexing motor mounts...this will cure all those possible problems common with heavy off-roading/hitting whoops/jumping.
    Price is $400, I take PayPal ryan_tfg@hotmail.com
    Message my inbox if interested!
  9. Jan 7, 2016 at 6:45 PM
    #49
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Smexy!
  10. Feb 20, 2016 at 11:15 PM
    #50
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    May be giving you an email for a set.... Doesn't look to good for the taco at the moment. Gonna take a closer look tomorrow :(
  11. Feb 21, 2016 at 3:16 PM
    #51
    FlapJack935
    Jack
    Abq New Mexico
    ya i think youll be hearing from me lol
    driver
    passenger
    need to get the actual towers sorted out but i think its time to bite the bullet
    Bonzen[OP] likes this.
  12. Feb 22, 2016 at 10:38 PM
    #52
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Yikes....well ive see worse... the reason the towers/perches are mangled is because the rubber isolator has failed and the whole mount is raising up and slamming back down. This is the #1 thing that I constantly tell people what to expect. Even if the actual mount itself hasn't failed, it can still be weakened enough to cause frame perch damage from the sloppy movement.
    Looking forward to building you a set and ending your issues forever! I can possibly help you with the frame perches as well.
  13. Mar 15, 2016 at 10:21 AM
    #53
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Going to put in a re-order to the laser cutter for 3.4L plates, if anyone is interested please reply or DM me so I can get an idea on how many sets to buy, thanks!
  14. Mar 23, 2016 at 5:32 PM
    #54
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    Definitely interested in getting both at some point. Do you provide installation instructions? Lastly, do you have any plans to make these for an 05 T4R V8?
  15. Mar 24, 2016 at 1:13 PM
    #55
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    No instructions needed, the installation is self explanatory. if you can change a starter or idler pulley or driveshaft then it is on par with those operations.
    Forgive my ignorance, but what is a T4R?
  16. Mar 24, 2016 at 1:36 PM
    #56
    Griff 99 TRD
    Unfortunately, I've never changed any of the aforementioned. I guess my concern (really) lies with properly supporting and lifting the engine and transmission. I don't want to damage anything.
    T4R stands for Toyota 4runner.
  17. Mar 28, 2016 at 10:16 AM
    #57
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Oh lol. Ive never heard a 4 runner referred to that way.
    I have no reason to believe that the motor mounts will not bolt into the 3.4L 4 Runners. The engine blocks are identical and the frames at least up in the front should be identical too since the suspension/pivot points/steering are identical.
    As far as supporting the engine when changing the mounts, a simple floor jack with a block of wood under the oil pan will suffice. that's pretty much how everyone does it, including myself.
  18. Mar 28, 2016 at 1:39 PM
    #58
    Griff 99 TRD
    My 4runner has a V8, which is why I was inquiring.
    As far as using a floor Jack and a piece of wood: would I use a 2x4? Plywood? If so, how many pieces do you suggest? I apologize for being anal, but this will be my first run at lifting up a motor.
  19. Mar 28, 2016 at 2:59 PM
    #59
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    These won't fit your 4runner. Wrong generation and wrong motor.
  20. Mar 28, 2016 at 4:22 PM
    #60
    Griff 99 TRD
    Yes, I'm aware of that...but my question, a few posts up, wss asking if the OP had any plans to make mounts compatible with V8.
