1995.5 Tacomas only - how many are still out there
Discussion in '1st Gen. Tacomas (1995-2004)' started by RysiuM, Feb 12, 2019.
  1. May 13, 2019 at 6:15 PM
    #421
    GQ7227
    GQ7227 mw survivor
    J A Y
  2. May 13, 2019 at 6:16 PM
    #422
    GQ7227
    GQ7227 mw survivor
    J A Y
    there must be a more authoritative place to confirm than that website?
    Running Board Man likes this.
  3. May 13, 2019 at 6:32 PM
    #423
    95v6mt
    95v6mt Well-Known Member
    scott
    maryland
    95 v6 mt extra cab
    Okay, time for me not to be sarcastic.
    First thanks for moving the pic over.
    Second I dont know if it is truely an sr5, it has a clock, it has the two section cloth seat, slider window, cruise, and other upgrades. so who knows? I dont.
    I tried a few vin decoders, none say sr5. is it coded into the vin?
    btw the clock thing in my sig line is because of a thread i read here where everyone complained about the clock. sarcastic mode on MY CLOCK WORK PERFECTLY
    GQ7227 and Running Board Man like this.
  4. May 13, 2019 at 7:12 PM
    #424
    Tartan Jack
    Tartan Jack Rockin It Old School
    Clinton, SC
    “Sports Cart” -1995 Taco, 2.4 2wd, Manual Everything
    Interior “retroficaton” (in progress) Airbag removal (1st gen/high explosive type) Hard Tonneau (on it when I got it) New grill, with custom badge Light Steelies S-Runner suspenion
    Like the rail rust, from how it sounds. I was told the 95/96/97 short leaf spring frame seems OK (relatively), while the long spring frame has far more rust issues. Like, whatever change was made to the frames to fit longer springs also exasperated the rust issues.
    Can anyone confirm:
    The short springs are stiffer than the long springs.
    I was told the short springs were a carry over from the Hilux & they made the change to soften the ride (which also made them sag more with heavy loads).
    I ask because I am working to improve the handling (which, once I swapped the tires, is shockingly good on my particular configuration). I would love to confirm the rear springs are already stiffer than what I am trying to replicate ... (S Runner).
    Sheer speculation:
    Due to my 2wd standard cab having few options (only A/C adds weight to a totally stripped down model), the smallest/lightest engine, plus the bed has the fiberglass tonneau & the rubber bed mat (adding weight to the rear wheels that is pretty evenly spread across the bed):
    It may have better than “normal” front/rear weight distribution for a Taco.
    I’m actually thinking about getting it measured, once I get the major mods paid off.
    Edit: Added 97 to short leaf frame ... I forgot which it had.
    GQ7227 and vtroot like this.
  5. May 13, 2019 at 7:30 PM
    #425
    Tartan Jack
    Clinton, SC
    I’m not much of a fan to poly bushings.
    My plans:
    Performance tires-have
    Front (1 1/8”) & rear (1”) sways-need to buy, planning the ADDCO ones.
    S Runner springs & S Runner Tokico shocks)- have & need to install
    Mildly tweeking the suspension in the same was Toyota itself did. If the rear springs are stiffer, that means I don’t need to touch them.
    My only planned drivetrain mod is the LCE header.
    cruiserguy and Running Board Man like this.
  6. May 14, 2019 at 1:19 PM
    #426
    GQ7227
    GQ7227 mw survivor
    J A Y
    BassAckwards likes this.
  7. May 14, 2019 at 1:58 PM
    #427
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Nice one, sunroof and push button 4wd.
    It probably varies by state but in PA to get specialty registration/plates "antique" is more than 25 years old, for "classic" 15 years. My '03 is now eligible for the latter..wow lol
    edit: there are also "vintage" plates which are for vehicles from 1906-1976.
    GQ7227[QUOTED] likes this.
  8. May 14, 2019 at 2:06 PM
    #428
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  9. May 14, 2019 at 2:06 PM
    #429
    RysiuM
    RysiuM [OP] Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
  10. May 14, 2019 at 2:09 PM
    #430
    GQ7227
    GQ7227 mw survivor
    J A Y
    :notsure: it seems to be missing side stripes
    I recently looked up definitions to see if my truck was any special certification
    I found vintage to be no less than 20yrs old
    and antique is 100yrs or more
    not sure how authoritative the source of info was...
    perhaps motor vehicles have a different grading
    https://www.google.com/search?q=vin...0j69i57j0l4.3504j1j7&sourceid=chrome&ie=UTF-8
  11. May 14, 2019 at 2:13 PM
    #431
    GQ7227
    GQ7227 mw survivor
    J A Y
    I dropped off my 22yr old half-weathered lower fuel shield at the powdercoaters today
    the owner said I have a fine piece of metal !
    will be ready to put back on in two weeks (their shop is overly booked I guess)
    mine works perfectly too :fingerscrossed: but if it goes out I know what you mean about the headache it will be to get a properly working one, perhaps a similar age 4runner works
    damnThem
  12. May 14, 2019 at 2:26 PM
    #432
    GQ7227
    GQ7227 mw survivor
    J A Y
    you don't say :argue:
  13. May 14, 2019 at 4:00 PM
    #433
    RysiuM
    Rysiu
    What I like in 95.5 is that is all mechanical where it should be and computer is for the engine at bare minimum: Air + fuel + ignition + timing. The only thing that is bugging me is the EVAP system - it should not be integrated into ECU (hence the name: Engine Control Unit). But I suspect that government bureaucracy forced Toyota to that (otherwise it would not be legal in USA).
    Newer trucks are depending on electronic to much. Hundreds of sensors and the failure on one, that is not vital to the health of the vehicle can bring the truck to limp mode or stop rolling altogether. That reminds me of MCAS system in 737 MAX. In that comparison the 1st gen Tacoma is like Travolta's 707.
  14. May 14, 2019 at 5:49 PM
    #434
    vtroot
    vtroot Mistakes Were Made
    Eric
    Bay Village, OH
    1995 Toyota Tacoma 4x4 2.7 Manual Standard Cab
    modern engine management is a product of emissions standards - regulations that seem to be designed more to keep auto manufacturers afloat, and get politicians elected, than to actually improve American sustainability.
    meanwhile, I feel a lot more sustainable buying this old girl than I would buying a 2019 hybrid off the lot.
    GQ7227 likes this.
  15. May 14, 2019 at 6:49 PM
    #435
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Hahahaah
    GQ7227 likes this.
  16. May 14, 2019 at 7:33 PM
    #436
    GQ7227
    GQ7227 mw survivor
    J A Y
    are the 96 xtracab frames a compatible/exact fit to a 97 xtracab?
  17. May 14, 2019 at 7:48 PM
    #437
    Billan
    Billan Member
    Hawaii
    1995.5 4WD
    1995.5 4WD 5speed 2.7 checking in. Still running great at 143k miles.
  18. May 14, 2019 at 8:33 PM
    #438
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was just curious why Tartan Jack did not include mine in his post is all
  19. May 15, 2019 at 2:34 AM
    #439
    Tartan Jack
    Clinton, SC
    Didn’t realize there were 3 frames. I knew the 95-97 were short springs, but not that there was a 2nd change too.
    As for 97 .... forgot it was short leaf spring. They made so many mid-year running changes that I simply forgot which spring it had.
    No exclusion intentional.
  20. May 15, 2019 at 3:11 AM
    #440
    Tartan Jack
    Clinton, SC
    I can’t remember which frames 97 had- if they (97) are short leaf springs, they are the same.
    Toyota added/changed to longer leafs in 97 or 98 (forgot when), which caused a frame shape/design change. Many 97 changes seem to be “on the fly” & mid-run (such as air bags-> single over-powered to two 2nd gen/era air bags -2nd generation of airbags, not Taco).
    Above it is said 95-97 on short leaf frame, so I’ll go with that (I own a 95, so focus on it’s oddities, not where in 97 changes happened or if it was 98. So, that’s a weak-point in my Taco-know.)
    Edit: they all rust. All truck frames rust. Some just rust worse than others. Conditions on the road
    make rust worse or not-weather & road salt/sand/brine.
