1995.5 Tacomas only - how many are still out there
Discussion in '1st Gen. Tacomas (1995-2004)' started by RysiuM, Feb 12, 2019.
  1. Jan 27, 2023 at 9:27 PM
    #861
    mst7107
    mst7107 Member
    Anchorage, AK
    1995.5 Tacoma 3.4L 4x4
    16" SCS SR8's 33" Toyo Open Country M/T Leer XL100 camper shell Arkon tablet mount/tablet running torque pro OME Lift
    I purchased mine in California in 2016, packed up all my stuff, and drove it to Alaska where is lives currently. 07/95 Cardinal Red Tacoma LX 3.4L MT 4x4 A.D.D with 215k.
    The truck had some rancho branded replacement rear shocks and an aftermarket radio/sub system installed when I acquired the vehicle and I have since made some additional modifications.
    -Swapped the factory 15" wheels with some 16" SCS SR8's in matte gunmetal wrapped in Toyo Open Country M/T 285/75R16 tires (Had to remove windshield washer jar for clearance but was able to fit with zero rubbing)
    -Added a used black Leer XL100 camper shell I got from a random used camper shell lot in California for $500
    -Swapped the sealed headlamp units for Sylvania housings that accept standard bulbs
    -Tundra brake swapped
    -3.5" OME lift
    -JBA upper control arms
    -Ram mount added to dash
    -60/40 bench seat Replaced with S-Runner bucket seats and center console
    One day, many many years from now, when the engine needs to be replaced... I will replace it with something that has a little more pep.
  2. Jan 29, 2023 at 9:06 PM
    #862
    ElScorcho
    ElScorcho You don't understand, I rekt it all the way home!
    Sacramento
    1995.5 Tacoma Xtra cab 3.4L 5spd
    8/95. 3.4L 5spd 4x4, locking hubs, 293k miles.
  3. Feb 5, 2023 at 9:30 PM
    #863
    L78
    L78 Well-Known Member
    Tony
    Nor Cal
    1995 Tacoma DLX, 2.7/Manual, 4x4, 1 family ownership
    Mostly stock, added custom wood bed rails and a Sony/Infinity stereo system
    I originally posted (#782 and #783 on page 40).
    I changed all the fluids, hoses, T-stat, plugs, reset the valves, replaced the exhaust manifold (cracked) with the 2000+ "header" ($64 at a local wrecking yard) and replaced the tires. Driveshaft carrier bearing.
    I also replaced every A/C component, except one hardline (not available) ... That was condenser, dryer, evaporator, compressor, hoses... Free loaner tools (vac pump and guage manifold set) and a few You Tube videos, and the A/C was up and running. A/C has worked great for the past 2 years.
    After I did all the maintenance, the radiator cracked, so I replaced it.
    Replaced the rear window slider latch...
    Installed new 31x10.5 tires from Walmart. Inexpensive brand, but semi-aggressive sidewall.
    I put about 5500 miles on it and getting ready to change the oil again. I drive a 2 hour/ 125 miles trip (each way) about every 3-4 weeks. It cruises fine at 75-80MPH...
    Seems to have a shifting problem, a little notchy... But clutch is good, holds fine and doesn't grab near the floor... But it's harder to shift when sitting at a stop light... Shifts fine when rolling.
    Next up, fixing the intermittent clock and driver's seat-belt retractor... And still considering a new stereo...
    Cruise control won't work, but I think it's the switch. I can't adjust enough to get both the clutch-start switch AND the cruise-control switch to engage...
    My only complaints are lack of keyless entry (despite power locks), I looked for the RSV3000 stuff behind the kick panels, but nothing... The other issues are no steering wheel audio controls, and I wish my brother had bought the V6...
    95 Tacoma Vol and ElScorcho like this.
  4. Feb 14, 2023 at 4:54 PM
    #864
    RysiuM
    RysiuM [OP] Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Sorry guys, I was busy lately not having much time to monitor the forum. But finally I did catch up and updated the list. If I missed something please let me know.
    Now living in a country and working from home I don't need to drive that much - I added 2k miles in the last year. At that rate I will die first before this truck.
    ElScorcho and TForan like this.
  5. Feb 15, 2023 at 9:01 AM
    #865
    Lmedina6
    Lmedina6 Member
    Luis
    1995.5 Toyota Tacoma
    None
    Here's my 1995.5 2WD Manual 2.4 4cyl with 310K. Built 03/95. 20221201_093239.jpg No leaks, excellent interior, garage kept, with original decals. Bought this September 2022 from Original owner with all maintenance records done by Toyota in Southern California. Its is my DD and plan on keeping it stock, at least for the time being.
    I get about 26-28 mpg. Drive 50 highway miles to work. Purrs like a .
  6. Feb 20, 2023 at 4:35 PM
    #866
    TooManyTacos
    TooManyTacos Well-Known Member
    01 Ext Cab 4x4, 21 DC TRD Sport 4x4, 02 Land Cruiser
    My truck is a 1996 but was built in 9/95 and dofu was 12/95 so it’s pretty close. It’s a 4x4 extended cab 3.4 V6 auto, add hubs with 74,899 miles as of today
  7. Apr 29, 2023 at 10:09 PM
    #867
    TacoCar95
    TacoCar95 Member
    Carson
    white 95 taco V6, 5speed
    Used to be a line-x salesman truck. 5 speed, 3.4L, extra cab. they messed up the wiring in the whole thing though. it's bday is March 2nd, 1995!
    got a 02/95 pickup/taco V6 manual 4x4 234,xxx rough miles by a LINE-X salesman, was ordered by LINE-X and now belongs to me, truck was completely bone stock when i got it, all original windows with sound reduction on the underside of the hood still!
  8. Aug 1, 2023 at 5:27 PM
    #868
    1stGen4WD
    1stGen4WD New Member
    Ian
    Reno
    1995.5 Tacoma 2.7 4WD (359k), 2019 Tacoma TRD Off Road. 2020 STI.
    '95: 31's, 2' lift, Pro Comp alloys, stereo. '19: 33's, 5/29 gears, ICON stage 10 3' lift, Falcon wheels, ARB OB air, rock sliders, tune.
    Remember where you got this front off-road tube bumper?
  9. Sep 18, 2023 at 8:01 AM
    #869
    piscataqua
    piscataqua Member
    My 06/95 with 121k, 2.4cyl 5spd, in Evergreen Pearl. Perfect condition under the hood, just painted some trim and replaced all lights. Pulling some dents, paint correction, and then new decals all around next. Keeping it completely stock for a nice little "desert truck" to bum around in.
    Black97v6MT, 4x4Taco2012 and 4xdog like this.
  10. Sep 22, 2023 at 6:00 AM
    #870
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    Just bought this "rescue" rebuilt 5/1995 1st Gen Taco 3.4L, 4x4, A/T, Manual Hubs, 116K miles. An original California truck with a no rust frame and body.
    Was owned for 25 years in California by one owner then sold in Cali and within 2years of the sale was wrecked and totaled. Not a great rebuild/paint job but I bought it for no rust, relatively low mileage driveline and 4x4.
    It had a rough ride during the wreck but after three weeks of tweaking it to my standards and a 1200 mile trip up from Texas to Wisconsin, it will work out nicely for my needs.
    4x4Taco2012 likes this.
  11. Sep 22, 2023 at 2:20 PM
    #871
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    95/05 SX 4x4, 2.7 3RZfe, manual 5 speed, manual locking hubs
    271k miles 1 prior owner that was close family but is woods truck now.
    Never wrecked and is 90% original, including clutch
    Have done only what is required to stay running for last 18 years until now.
  12. Sep 23, 2023 at 12:13 PM
    #872
    Traef311
    Traef311 Member
    Trey
    95 Tacoma 2.7L 4wd
    3 inch lift
  13. Sep 23, 2023 at 12:14 PM
    #873
    Traef311
    Traef311 Member
    Trey
    95 Tacoma 2.7L 4wd
    3 inch lift
    My tacoma above has been in water in the Louisiana swamps almost over the windows....kept on the gas n kept going
  14. Sep 25, 2023 at 6:28 AM
    #874
    OG.Taco-95.5
    OG.Taco-95.5 Well-Known Member
    1995.5 Toyota Tacoma 2rz
    New to TacomaWorld! Stoked to be here. Figured I’d share a little about my Taco,
    1995.5 5speed 2rz 2wd xtracab
    owned since last year this time. Bought from my younger bro, he used it as a work truck for 5+years “pulling sod, mower equipment, material loads and so much more” She currently sits at 293k on the dash. Makes me the third “proud” owner. My bro sold it to myself after his business and family grew. My bro has owned and been modifying his Taco which is a 1997 5speed 2rz RegCab for 10+ years now. Family owned since original as well. His Taco has definitely inspired my build with mine. His is now a weekend cruiser and autox beast. I’ll throw in a picture or 2 of his as well. If anyone has any questions about either just let me know. Happy to answer. Thanks for the read, here are some pictures of the build so far. IMG_3379.jpg IMG_3701.jpg IMG_3912.jpg
    4x4Taco2012, Traef311 and semco-inc like this.
  15. Sep 29, 2023 at 6:06 AM
    #875
    semco-inc
    DFW & ATW
    Here is my 5/1995 under bed liner discovery for my salvage find.
    A California truck all its life. I'm finding a lot of tan trail dust everywhere in the vehicle.
    The frame is immaculate which was one of the reasons I even considered buying a salvage vehicle, plus the relatively low mileage (116K) on the engine and drivetrain and one owner for 25 years.
    When sold from the long term owner it was crashed within 2 years before the rebuilder got it and resurrected it (albeit somewhat sloppily).
  16. Oct 18, 2023 at 11:03 AM
    #876
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    I apologize for the late response, haven't been very active.
    Its a trailgear rock defense low profile.
    https://trail-gear.com/armor/bumpers/tacoma-rock-defense-low-profile-front-bumper-95-04.html
    I think back when I got it in 2016 it was only around $400....
    Its been pretty great though, holds my winch and drilled into it to mount the light bar.
    Very sturdy, although the mounting points seem to be a weak point.
    I got into a small (at least for my truck) accident with it, which has left the bumper not sitting perfectly straight on the truck. It is now angled about 5degrees up, but is otherwise perfect undamaged. It totaled the civic that was involved though, so I suppose I can't ask for much more.
  17. Oct 18, 2023 at 1:25 PM
    #877
    mic_standard
    mic_standard Well-Known Member
    Bay Area Northern California
    1996 Tacoma Xtra-Cab
    mic_taco1.jpg mic_taco2.jpg mic_taco3.jpg 96 Tacoma built in Sept95 - a true original. I picked it up a couple years ago with about 80k miles. It is all the way up to 90k miles now.
  18. Oct 30, 2023 at 5:24 PM
    #878
    Jagernats
    Jagernats Active Member
    Lauren
    Ontario, Canada
    1995.5 Tacoma SR5
    03/95 SR5
    Xcab, Manual hubs, MT, 319k KMS :)canada:)
    Solid frame very well taken care of, I love this truck so much. Glad to take care of a survivor
    Black97v6MT and 95 Tacoma Vol like this.
  19. Nov 12, 2024 at 4:46 PM
    #879
    RysiuM
    Rysiu
    Sorry for being away - other duties, and because my Taco kept running without problems, so I had no pressed needs to look for help to TW :)
    I have updated the list - we have reached 100 trucks listed here.:hbd: Amazing vehicles, almost 30 years and they keep going like that Duracell bunny.
    95 Tacoma Vol and Black97v6MT like this.
  20. Nov 12, 2024 at 6:02 PM
    #880
    alexswords
    alexswords Member
    Alex
    1999 Pre-Runner
    do you know what bed cover this is? been looking for this exact one forever
