1995 Toyota Tacoma fuel leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95toyotaguy, Oct 20, 2017.
  1. Oct 20, 2017 at 1:23 PM
    95toyotaguy
    95toyotaguy [OP] New Member
    1995 Toyota Tacoma
    My Toyota truck is leaking gas on the bottom of my truck towards the front in 3 different places. Please help I’m very new to vehicles this is my first one.
  2. Oct 20, 2017 at 1:38 PM
    95toyotaguy
    1995 Toyota Tacoma
    The leak is near or on the back of the engine block near the firewall but it’s very hard to see and gas is everywhere
  3. Oct 20, 2017 at 7:02 PM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    Okay number one BE VERY CAREFUL this doesn't need to be said. I would drain the gas tank and spray the leaking areas with water to prevent it from catching on fire. Then you can diagnose from there
  4. Oct 20, 2017 at 7:52 PM
    Americandad
    Americandad Active Member
    Scott
    Marquette MI
    99 Tacoma under construction
    There's 3 steel fuel lines that run from the tank to the engine. Two of them connect to the tank and to the engine via small rubber fuel hoses and the larger main supply line to the engine has flare fittings both ends. Check all those hoses and fittings, they'll be on the drivers side. If it's not that follow the fuel ines down and look for leaks.
    95toyotaguy[OP] likes this.
