1996 2.7L Low oil pressure light at idle!!!
Discussion in '4 Cylinder' started by jgwelchjr, Jan 8, 2010.
  1. Jan 8, 2010 at 10:15 PM
    jgwelchjr
    jgwelchjr [OP] Member
    Crossett, Arkansas
    1996 Tacoma LX 4WD
    Recently after about a 45 minute drive, coming into town my oil pressure light blinked on at a red light (at idle). And then just above idle it goes back out. Did a few searches and didn't find this exact problem. It seems to have gotten worse as the weather has turned colder. Now tonight the light is staying on until about 1500 rpm and I pulled the oil fill cap off and noticed quite a bit of blow by. Is that normal, haven't noticed it before? The truck has 134,000 miles on it. And I also noticed that when starting it seems like the engine is not turning over as fast. Feeling more and more like I'll be putting along block in it. What do you guys think. Where is the oil pressure sender, I would like to put an actual gauge on it and see what the pressure is.
  2. Jan 9, 2010 at 7:28 AM
    yotakid98
    yotakid98 Active Member
    Tyler
    Vriginia
    98 tacoma.
    dick cepek rims,dayton timberline A/T 33x12.50 , 4in body lift. K&N air filter
    u could need to replace the oil pressure sender. check all seals make sure no leaks.
  3. Jan 9, 2010 at 7:29 AM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    Could be a combination of things. What weight oil are you running? If your oil is too heavy that would account for why it's turning over slow in cold weather. If your motor is idling a little on the low side and your oil is too heavy, you're not getting sufficient flow at idle. That can cause the sending unit to turn on the low pressure light. Also, at 134,000 miles your oil pump could be getting a little weak. I'm not sure but I believe the manual recommends 5W30 for that motor or 10w30 if the ambient temp is above 0F. Anything heavier than that can cause problems in the winter, especially if your oil pump has a little age on it.
  4. Jan 9, 2010 at 4:28 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Most of the time, the oil pressure sensor is the problem.
  5. Jan 9, 2010 at 8:32 PM
    jgwelchjr
    Crossett, Arkansas
    1996 Tacoma LX 4WD
    This morning I installed a manual gauge and after a few minutes of idling the gauge shows around 2-3 psi and the light is on at this point. So I feel like the sender is doing it's job. (I put a tee in so I could see what pressure the light comes on at while looking at the gauge. So what now? How much blow by should I have at the oil filler cap? It seems like a lot to me? Maybe not considring the mileage. The engine sure seems to run good and does not use oil at all, it has no leaks anywhere. I'm thinking i should do a compression check on all cylinders, and if they turn out good then maybe I can just replace the oil pump. Oh yeah by the way about the most psi I can ge out of it at about 4000-5000 rpm is around 30 psi.
    Could I have a clearance problem in some of the bearings? Like i said I have zero knocking and the truck seems to have good power. What about the cam, is it like a V-8 with pressurized bearing fit or is it just splash lubricated? Thanks for all your help.
  6. Jan 10, 2010 at 3:26 PM
    mbtech208
    mbtech208 Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    I'm having the same problem with mine. It lost power on the highway, I pushed in the clutch and the engine died. Cranked over very slowly and finally started, but the oil light was on at idle and it's knocking. It's going to the dealer tomorrow.
  7. Jan 10, 2010 at 7:59 PM
    jgwelchjr
    Crossett, Arkansas
    1996 Tacoma LX 4WD
    That's exactly what happened to me, I'm just wondering if I can get by with putting an oil pump in or if I need a complete overhaul. Let me know what they say at the dealer.
  8. Jan 10, 2010 at 9:04 PM
    mbtech208
    Peoria, Illinois
    I'll let you know. I hope it doesn't need a new engine, it wouldn't even be worth fixing.
  9. Sep 6, 2011 at 7:48 AM
    jriveraboriqua
    jriveraboriqua New Member
    Joe
    Vermont
    Tacoma
    The oil light goes on after I drive about 4-5 miles and stays on until I let it cool down. It is not overheating. The light goes off or flickers if I rev the engine a bit. Not sure if it is the oil or the oil pump...I have 156K miles.
  10. Nov 1, 2014 at 10:14 PM
    YoTaboss
    YoTaboss Member
    Western NC
    96 Tacoma single cab 2.7l, 02 ext cab 2.7l
    3" suspension lift, Cold air intake, 33x12.50x15
    Any luck figuring out what your problem was my trucks runs fine but oil light comes on after a couple miles and stays on until I then it off and let it cool down plus the motor does not rev out and by that I mean it will not reach the rev limiter when you hold the gas down while the clutch is pushed in. Doesn't overheat and doesn't knock but after I while it does sound like maybe the top end isn't getting proper oil pressure and I have already replaced the oil pump but no changes
    Please help!
  11. Nov 2, 2014 at 1:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have the same engine and I can confidently say that no matter what they seem to produce a lot of blow by. Other users and guys on Yotatech can confirm that. Mine sounds like another exhaust (just a lot quieter) when you take off the oil cap while it is running. However, generally the 3rz oil pump is a pretty solid unit so I would change the sender unit first. The oil pump on the 3rz can be changed if worse comes to worst.
  12. Nov 2, 2014 at 3:49 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    change the oil and filter more regularly. use high quality oil. no pennzoil. the engine obviously is worn. more than likely the main bearings. maybe use a little heavier oil. you don't have that much cold weather up there.
  13. Jan 31, 2016 at 5:21 PM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Was there any resolution on this? I'm having exact same problems. About to put it back together with a cleaned bypass valve, cleaned sump screen, and new oil pump. I'm checking my bearing oil clearances tomorrow before it put it back together.
  14. Jan 31, 2016 at 5:32 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    These all sound like Main bearing tolerance issue's to me.
  15. Jan 31, 2016 at 7:51 PM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    I'd say you're right. And I hate that you're right.
    Main bearing 1
    Main bearing 5
