1996 tacoma 2.7 runs rough
Discussion in 'Toyota Trucks & SUVs' started by toyotaman4ever, Oct 28, 2012.
  1. Oct 28, 2012 at 12:50 PM
    toyotaman4ever
    toyotaman4ever [OP] New Member
    wisconsin
    1996 tacoma 2.7
    i picked up 1996 tacoma 4x4 ext cab runs rough code 0340 put in new distributor,maf hardly starts misfires took off air box system sprayed choke cleaner thru system got it running and idling put together still running till i plug in maf kills engine any help similiar problems fixed?
  2. Oct 28, 2012 at 4:49 PM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    might need a new maf sensor
  3. Oct 28, 2012 at 6:43 PM
    toyotaman4ever
    wisconsin
    1996 tacoma 2.7
    put new maf in same problem
  4. Oct 29, 2012 at 6:54 PM
    mitchellayes
    mitchellayes Active Member
    Mitchell
    Bremerton, WA
    1997 Toyota Tacoma SR5
    stock
    Might just be a bad spark plug wire...Might be running on 5 cylinders due to this. CHeck all your wires to make sure they are in all the way!
  5. Oct 29, 2012 at 7:28 PM
    mac424205
    Mathew
    Chelsea
    2.7 is a 4 cyl. The truck wouldn't cut off when the MAF was plugged in if it was a bad wire. It would mis like crazy
