1996 tacoma 3.4--What year engines will fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigbucks, Feb 10, 2012.
  1. Dec 22, 2016 at 9:52 PM
    kmcmahon5
    kmcmahon5 Well-Known Member
    B.C.
    1996 Tacoma, 1989 pickup
    Tons! Lots of variety too. Im into the "overland" style of wheeling. But we got lots of rocks to climb.
  2. Dec 22, 2016 at 10:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Cool. Will do!
  3. Dec 24, 2016 at 10:17 PM
    97ktstacco
    97ktstacco Member
    I put a 96 engine into a 2002 tacoma. The only difference is the intake where the throttle hooks up and the cruise. Also the injector clips are different but you can swap these parts off of your old motor. Thas what i done and have driven it 50k miles since and still running strong
  4. Jan 14, 2017 at 7:54 PM
    1997tacomav6
    Denver
    I have a 1997 3.4 v6 and replaced the old motor at 485,000 with a 2004 3.4 v6 motor that had 100,000. Swap was easy, used the 2004 intake with the 2004 injectors, only issue was the injectors clips
    but made it work. Everything is pretty much the same and bolts back on including using the original wire harnesses from the 1997.
    The 2004 motor is an excellent choice. My 2004 motor has a lot more power on the top end then the 1997 motor. The 2004 motor power wakes up now at 4000 rpms where the 1996 motor would struggle for power above 4500 rpms. Use the 2004 injectors as they are larger and better and replace the knock sensors while your in there and the wires for them.
    You can buy oem knock sensors off eBay DESNO New for 85.00 pair and knock sensor wires for 25.00. Photo of the 2004 engine, looks the exact same as 1997 motor.
    masonb and Jaysjammin like this.
  5. Jan 14, 2017 at 9:10 PM
    kmcmahon5
    B.C.
    That was the exact info I was after. Some real life experience haha. Thanks! Next week is the swap. Using my 96 throttle body and accessories. Ever since I blew my spark plug/ coil pack, its been sluggish and way too many oil leaks. 335 Kms on it. Donor motor has 135 kms which is about 84000 miles
  6. Jan 14, 2017 at 9:32 PM
    1997tacomav6
    Denver
    Perfect then, what I did when I did this swap was replace all the gaskets on the new motor,
    Rear main seal, front main seal, valve cover gaskets, intake gasket, knock sensors, knock sensors wires,
    Resurface clutch plate, new clutch, new throw out bearing and pilot bearing, replaced ALL the vacuum
    hoses, the water pump, and timing belt and ALL bearing For those areas, new plugs and wires. Use the newer coil packs also.
    All this stuff is sooo easy to do when the engine is out and USE all OEM parts.
    Will cost a few extra bucks but then your engine will be good for 100,000 more miles till any new work
    will be needed.
    2004 engine on the left, 1997 motor on the right ready for swap
    boostedka likes this.
  7. Jan 15, 2017 at 12:16 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha! and everyone here thinks you have 500k on your original motor :p
    not that 485 isn't impressive.
  8. Jan 15, 2017 at 3:50 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Weren't the later year model tacomas starting to use the throttle by wire set up atleast having to do with the tps? Instead of just a plain ole cable running everything? As long as a guy switched everything over it seems there wouldnt be an issue but i was curious about the newer setup creating issues with a swap?
  9. Jan 15, 2017 at 6:32 AM
    1997tacomav6
    Denver
    Yes they were, but when you do the swap you use your original throttle body setup, not the throttle by wire, so it's all plug and play with the throttle body and cruise control cables
  10. Jan 15, 2017 at 7:02 AM
    1997tacomav6
    Denver
    I use old school math and round up, Haha, your funny, Everyone???? mmm I don't think so, I have posts looking for an engine, post about if I should fix head gaskets or replace engine, the process of replacing the old engine with a 2004 motor etc,
    https://www.tacomaworld.com/threads...89-000-miles-repair-or-replace-engine.397363/
    , As we all know from looking at the head gasket issues here on the forum the 3.4 motor will have a head gasket issue around 400,000 -500,000 or so and you will have to decide to fix or replace motor.
    Anyway If you followed me you would know, for you and those that don't follow
    A year ago I put a 2004 motor that had 100,000 miles into my 1997 and replaced the old motor that had a head gasket leak that had 485,000 miles, I could have fixed the head gasket but with that many miles everyone on the forum convinced me to replace the motor. Everything else is all original, except the motor now pushing 520,000
    So here is the strange thing, the 1997 motor used to ping with the supercharger all the time since new and the power leveled off around 4500-5000rmp and was flat in the higher range.
    The 2004 motor there is zero pinging, can't make it ping if I try even with the 2.1 pulley and I do not have any fuel upgrades, With The 2004 motor, the power comes on the same but around 4000 rpms instead of flating out it pulls and pulls really hard
    all the way to the redline. Is strange because even though these are the same engines the performance differences are huge. I'm wondering if there were company improvements done to the 3.4 engine during those 9 years? The Toyota guy that helped do the swap told me the 2004 motors were much better motors than the earlier motors and had larger valves and a few other things, but not sure if that's true.
    My truck now has never had so much power and never run better before with the 2004 motor. BTW I like your blinker conversation idea, will have to maybe do that if I can find a fog light conversion that fits easily
    This is the motor 2004 motor I got from a rolled 2004 Tacoma now in my truck
    Blackdawg[QUOTED] likes this.
  11. Jan 15, 2017 at 7:22 AM
    bry838
    oregon
    Gotcha! Thats what I thought but wanted to be sure!
  12. Jan 15, 2017 at 10:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im just giving you shit man haha
    As for if the motor is "beter" then on older one..i can see that maybe.
    Ive never heard of the heads flowing better or different valves and such. But the motors did get tweaked with emissions stuff and im sure with the ECU a lot. i have a 96 tacoma and an 03. But couldn't say they run any different. :notsure:
    maybe if i hit the 400k mark and need new head gaskets ill measure and find out!
    1997tacomav6[QUOTED] likes this.
  13. Jan 15, 2017 at 10:58 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I put a 04 motor into my truck. Works fine just have to swap over some stuff
  14. Jan 15, 2017 at 10:59 AM
    1997tacomav6
    Denver
    Maybe has to do with the supercharger combo? Don't know but zero pinging now and all types of new top end power, lower rpm power was the same
  15. Jan 15, 2017 at 11:04 AM
    #35
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Maybe the lack of ping in the new motor had to do with the newer pink top injectors higher flow rate.
  16. Jan 15, 2017 at 11:05 AM
    #36
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea id guess thats probably true, better fuel flow perhaps.
  17. Jan 15, 2017 at 11:07 AM
    #37
    boostedka
    James
    NM
    Yeah I think they're ~10% higher flow.
  18. Jan 15, 2017 at 11:08 AM
    #38
    1997tacomav6
    Denver
    Yup maybe, but that would be an easy fix for the ping issues that I would thought someone would have discovered a long time ago. I know they are larger and probably better flow rate and smaller droplet size
  19. Jan 15, 2017 at 11:10 AM
    #39
    Blackdawg
    Monte
    Wyoming/St. Louis
    i think it is a swap some do, but not easy as aren't the connectors different?
    I do know swapping to N/A 7mgte supra injectors is done. They are 318cc i think. Even think turbo supra ones fit, 440cc.
  20. Jan 15, 2017 at 11:13 AM
    #40
    1997tacomav6
    Denver
    The clips are a little different but is not a big deal to modify them
