1996 Tacoma 4x2 with a 2.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wyzinski, Jul 15, 2014.
  1. Jul 15, 2014 at 4:56 PM
    Wyzinski
    Wyzinski [OP] Member
    Edward
    Elp, TX
    Tacoma
    4x2, wanting to convert to 4x4
    Mid-life crisis mod...will attempt to convert my 1996 Tacoma into a 4x4. My question with regard to the rear diff: want to install 5.29 gears with Arb airlocker RD129. Stock diff. is 7.5". My question: will I need to upgrade the axle shafts to 30 spline? I think the ones currently in are 27 spline.
  2. Jul 15, 2014 at 4:58 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Your front suspension is completely different, you'll have to swap frames, put a solid axle under the front, or cut off your UCA and LCA mounts and add new ones where the pre-runner/4x4 mounts are.
  3. Jul 15, 2014 at 5:01 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
  4. Jul 15, 2014 at 9:40 PM
    Wyzinski
    Edward
    Elp, TX
    Tacoma
    Yup, SAS in mind is the Allpro Rock Jock 60 Taco Supreme. I realize it's involving some serious bucks, but I've been preparing for this for some time. The good thing is it's all complete, the tranny is a W59, so I figure it's not too difficult 'cause the 3rz also has a W59. Modification here won't be overly expensive. I'm allocating approx. $13.5K Rear diff. locker is on it's way, and the Arb twin compressor is on it's way, should arrive Thursday.
  5. Jul 16, 2014 at 12:19 AM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Sweet! Make a build thread!
  6. Jul 16, 2014 at 6:35 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have serious doubts about the 7.5" 5 lug axle holding up to this, but subbed for the results :popcorn:
  7. Jul 28, 2014 at 7:49 PM
    Wyzinski
    Edward
    Elp, TX
    Tacoma
    Question: Trying to decide where to mount the compressor? Thoughts and comments would be appreciated. "bout the only place I can figure is in the bed behind the drivers side.
  8. Jul 28, 2014 at 8:06 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    You might be able to fit it under the hood on the passenger side. Otherwise in the bed maybe in a tool box would be good.
  9. Aug 3, 2014 at 8:06 PM
    Wyzinski
    Edward
    Elp, TX
    Tacoma
    As mentioned before, I'm trying to convert my 4x2 into a 4x4...well, check out Mosk's posting on Yotatech titled 1995-2004 Tacoma A/T vs M/T ECU pinouts. As for me, it's a godsend. Hoping this information will make lightwork for others.
  10. Sep 5, 2014 at 12:22 PM
    Wyzinski
    Edward
    Elp, TX
    Tacoma
    Well, I finally finished installing the air compressor. Located in the taco bed. I added a 1 gallon tank so I can use pneumatic tools @ 120-150 psi. This will also engage the lockers. See pics in gallery. Additionally, got a 6-bolt rear end to replace the 5-bolt lug pattern.
