1996 Toyota Tacoma 3.4l Automatic Tranmission Fluid. What brand??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steelhead Huntah, Feb 22, 2017.
  1. Feb 22, 2017 at 11:47 AM
    Steelhead Huntah
    Steelhead Huntah [OP] Active Member
    Hi, I am going to drain the transmission fluid in my Tacoma. I noticed it is black and before I assume anything, I am going to drain the fluids slowly from the drain pan. What is the best brand you guys prefer?
  2. Feb 22, 2017 at 11:50 AM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Toyota, Lexus Genuine OEM Dexron III ATF 4 QTS
    00718-ATF00
  3. Feb 22, 2017 at 11:57 AM
    Steelhead Huntah
    Thanks, for the reply. Is there any alternative to the Toyota brand? I noticed that stuff is expensive.
  4. Feb 22, 2017 at 1:16 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use Valvoline Max Life ATF. Works great
    cruxofthebisquit likes this.
  5. Feb 22, 2017 at 1:17 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    AmsOil ATF
  6. Feb 22, 2017 at 1:55 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  7. Feb 22, 2017 at 2:26 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    The alternate method to draining it is to disconnect the lines at the radiator.
    Take the "line out' from the radiator and replace it with a longer line routed into a bucket.
    Put a funnel in the dipstick fill. Start the truck and let it pump out some fluid into the bucket.
    Shut it off, Add more fluid. Repeat till the fluid is clean. Can be done solo. Easier if you have help.
  8. Feb 22, 2017 at 2:35 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    what's the primary way to drain it?
  9. Feb 22, 2017 at 3:06 PM
    Steelhead Huntah
    Dexron II is what it calls for so I'm assuming anything with the label dex/merc like the Valvoline max life would be suitable?? A little less than 6 quarts came out of the drain plug, it was all black and smelled burnt. Hoping to get a little more life out of the transmission but we'll see.
  10. Feb 22, 2017 at 3:37 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    make sure to block off the "inlet" hose or it will just run out since the fluid is forced out and through the radiator and back into the trans.
    pull the plug and/or pan to get more out.
    as long as it's compatible it should work fine. being that dark and smelly you will most likely want to do another drain/pan/drop after a week or two in order to get more of the burnt fluid out
  11. Feb 22, 2017 at 6:26 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    You can use Toyota T4. Its more common.
