1996 Toyota Tacoma questions
Discussion in 'Technical Chat' started by tonyrip, Mar 10, 2013.
  1. Mar 10, 2013 at 12:24 PM
    tonyrip
    tonyrip [OP] New Member
    tacoma 4 wheel drive
    1. What size fuel tank on 1996 4x4 pickup?
    2. should there be lights on dash for heater/defrost, etc?
    3. missing catalytic converter. Runs fine. Always has service engine light on. could this be a problem?
  2. Mar 10, 2013 at 4:47 PM
    BamaToy1997
    Bill
    Navarre, FL
    1. I believe they are 17 gallons.
    2. On the dash, or on the A/C Control head? Yes if you are meaning the A/C control head.
    3. Yes.
  3. Mar 10, 2013 at 4:57 PM
    Bullfrog
    Bullfrog "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    I don't have a cat, no problem here.
  4. Mar 12, 2013 at 10:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    Hope you enjoy breathing that. lol. Sorry, I always give recommendations and information based on repairing a vehicle back to legal, factory specs. Removing the cat is not exactly legal (in most states), nor good for the environment.
  5. Jul 5, 2013 at 9:09 PM
    dlehmkuhl
    dlehmkuhl Active Member
    D
    Colorado
    '98 SR5 Stndrd Taco
    Coil over front suspension Blocked in rear
    Ditton on the tank size. I found out when I ran my old one below E and it ended up taking like 16.563 gallons or some such so yea it's 17, lol. As for the CAT, I really don't see how it does much of anything other than maybe "scrub" the exhaust before leaving the vehicle out the pipe. I know a guy with an '89 Runner that "hollowed" out the cat and at emissions it runs right in the regs. Nuclear and coal fired power plants are bad for the environment too, but I like electricity. Tit for tat as it were, but just my two cents. Oh, and the check engine light is prolly on because of one of those crappy emissions censors, ie; O2's, but it could also be the knock, ATCS, or even the mass airflow sensor. Best way is to have it checked by a diagnostic pad which is free at AutoZone, Checker or even NAPA, depending on where yer located.
    EDIT: Could also be yer cam position sensor, dirty injectors (fouling), etc. See where I'm going with the diagnostic idea?
