1997 Tacoma A Lot of Problems No CEL (SOLVED)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1997White4x4, Dec 7, 2019.
  1. Dec 7, 2019 at 8:58 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 [OP] America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    1997 Toyota Tacoma
    Single Cab
    4Cylinder
    2.7L
    4x4
    auto
    220xxx
    I live in Los Angeles
    Issues:
    -Rough idle
    -Hesitation on take off
    -muffler keeps making noise
    What ive done:
    -Radiator, thermostat, trans oil cjange, plugs, wires, coils, pcv, valve check, conpression good, leak down good, new brakes rotors calipers, changed oil synth, air filter, cleaned iac and throttle, replaced maf, no exhaust or vac leaks, new trans solenoids(only cel i wver got), new tires, stock wheels, new muffler but i think this muffler shop sells crappy mifflers this is the 3 rd one they put on and they all rattle on throttle, cleaned fuel injectors, i checked all the fuses, checked battery and alternator, changed power steerin pump, chamged cv axle, cat is new, changed 02 sensors both
    Ive took it to 3 mechanics and they cant figuire it out, I’m really getting sad about this because this was supposed to be my dream vehicle and is turning into a nightmare
    Things I will do (literally left to do) or I suspect:
    -ecm (i ordered oned coming monday)
    -tps (i just bought one, gotta install)
    -fuel pump
    -oem muffler(dont want no “performance” muffler i enjoy a nice quiet ride)
    -egr
    I still love this truck, I believe one day itll be all good, I mean i put everything into it except a new motor, any help will be appreciated
    my mpg 16, I do a lot of city driving, but can get 19mpg 25%highway
    truck has never ever left me stranded turns on everytime, never has stalled out once
  2. Dec 7, 2019 at 9:11 PM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    I don't think you missed anything to fix but the only thing that you might want to replace anyway would be the lower ball joints? No idea on the idle and hesitation, normally those would be from dirty throttle body or MAF so I'm stumped.
    cruxofthebisquit likes this.
  3. Dec 7, 2019 at 9:13 PM
    Tacoma1997White4x4
    I knew I forgot to lost something ALREADY CHANGED the ball joints aswell
    TacoBike likes this.
  4. Dec 7, 2019 at 9:15 PM
    Tacoma1997White4x4
    I would like to mention that I am getting a new ecm because in 1999 toyota issued a tsb on the vehicle i have, ‘revised ecm :improve engine smoothness’ whatever that means
    Stout890 likes this.
  5. Dec 7, 2019 at 9:15 PM
    Tacoma1997White4x4
    Also ive tried the whole disconnect battery and fuse thingy
  6. Dec 7, 2019 at 9:20 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Have you tried running Seafoam through the engine?
  7. Dec 7, 2019 at 9:24 PM
    Tacoma1997White4x4
    No, but I’m at the point to where ill try anything
    sPeaking of that I even tried 91 “vpowah” from Shell I didnt and dont have pinging but hey I tried, Ill try seafoaming, but This monday i recieve new ecm, its plug n play, if that doesnt do it well ill drive it till i get a cel, i must be the most weirdest person to pray for a cel
    but yeah ill try seafoam
  8. Dec 7, 2019 at 9:24 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Fuel filter?
  9. Dec 7, 2019 at 9:25 PM
    Tacoma1997White4x4
    Forgot to lost that aswell already changed it
  10. Dec 8, 2019 at 2:03 AM
    TacoBike
    Mason
    Have you changed every sensor on the engine? They are what control idle etc. for the most part. you might have one that just isnt sending a code, not sure if that is even possible.
  11. Dec 8, 2019 at 2:55 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Has anyone actually run across one that was bad on a 2.7? I keep wondering about mine....
  12. Dec 8, 2019 at 5:25 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
    Do you know that the bulb for the CEL is good?
    Should be OBDII being a 97 right? Have you tried plugging a scanner into the port and seeing if there are any codes? If you don't have one, they'll do it at an auto parts store.
    Although, if you've taken it to 3 mechanics surely at least one of them would have scanned it even if the light wasn't on.
  13. Dec 8, 2019 at 6:43 AM
    Glamisman
    Glamisman Well-Known Member
    improve engine smoothness means that Toyota has raised the idle rpm for the 4 cyls some 50 rpm.
    cruiserguy likes this.
  14. Dec 8, 2019 at 7:35 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If I memba right, he had to replace his to get his running correctly. But I hadn't heard of one on these tacos going bad before.
  15. Dec 8, 2019 at 7:40 AM
    Tacoma1997White4x4
    Whats fpr?
  16. Dec 8, 2019 at 7:41 AM
    cruiserguy
    Elijah
    SEKS
    Fuel pressure regulator
  17. Dec 8, 2019 at 7:41 AM
    Tacoma1997White4x4
    no, like the fuses?
  18. Dec 8, 2019 at 7:42 AM
    Tacoma1997White4x4
    wouldnt that throw a code?
  19. Dec 8, 2019 at 7:44 AM
    Tacoma1997White4x4
    yes the cel bulb does work, 3 mechanics have scanned it....nothin
  20. Dec 8, 2019 at 10:58 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Have you tested any of these parts you replaced? Just seems expensive throwing parts at it without knowing if they're actually bad.
    Try looking at the live data on a scanner. Maybe something will be noticeably off.
    Checking the fuel pressure and FPR is a good suggestion.
    Check the compression and valve clearances. At 220k the valve clearances may be starting to get out of spec. Even if that's not the source of your problem it's still good to check at this mileage.
    If you're going to replace the TPS you have to follow the procedure in the repair manual to set it so it detects the idle position.
