1997 tacoma standard headlights?
Discussion in 'Lighting' started by doninva, Jul 3, 2010.
  1. Jul 3, 2010 at 7:56 PM
    doninva
    doninva [OP] Member
    Don
    Penhook, Virginia
    97 standard cab-straight drive with 276,000 m
    My 1997 tacoma has the old style bulbs. What would be the most cost efective way to get better light output from the headlights. I love the glass bulbs with no plastic lens, but more light would be great. Thanks, Don
  2. Jul 3, 2010 at 8:11 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  3. Jul 3, 2010 at 8:49 PM
    doninva
    doninva [OP] Member
    Don
    Penhook, Virginia
    Thanks, That looks like what I need. Don
  4. Jul 4, 2010 at 10:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Best bang for the buck is the GE halogen high output sealed beams. I had a set on my old 86 pickup. They were around 20 bucks for the pair at walmart.
    Huge increase in low beam light output when compared to the sylvania xtravision I had been running before. High beam wasn't much brighter, but was okay.
    I eventually went to hella H4 conversions with 80/100 bulbs and custom wiring harness. They cost more like 130 bucks plus the wiring upgrade. Killer high beam output, but the low beams were not that much better than the GEs.
    If your primary concern is low beam output, try the GEs first.
