1997 Tacoma SX v6 5sp TVS1320 supercharged 300 HP! Haltech ECU, Reg Cab 750,000 Build
Discussion in '1st Gen. Builds (1995-2004)' started by 1997tacomav6, Mar 1, 2017.
  1. Dec 29, 2017 at 9:59 PM
    #101
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    It's the same measurement, no difference in boost between the two, both will create the same boost
  2. Dec 30, 2017 at 5:08 AM
    #102
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Hahaha
  3. Dec 30, 2017 at 6:06 AM
    #103
    04yota
    Angelo
    Central New Jersey
    Def Will look into this as well. :thumbsup:
  4. Dec 30, 2017 at 12:29 PM
    #104
    04yota
    Angelo
    Central New Jersey
    So i have been researching about the meth kit and seems like the way to go. Do you have any other gauges aside from your boost? how do you keep an eye on the AFR
  5. Dec 30, 2017 at 12:31 PM
    #105
    04yota
    Angelo
    Central New Jersey
    Maybe i can get away with the 2.2 pulley and meth with no upgrade to the fuel pump?
  6. Dec 30, 2017 at 1:07 PM
    #106
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    1997tacomav6[OP] and 04yota like this.
  7. Dec 30, 2017 at 1:16 PM
    #107
    04yota
    Angelo
    Central New Jersey
    boostedka[QUOTED] likes this.
  8. Dec 30, 2017 at 1:40 PM
    #108
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This is the greatest build thread ive laid eyes on..
    500K miles boosted truck..
    Def keeping both my toys (176K and 183K miles) longggg into the future.
    :cheers:
    Wondering if water meth would work on my boosted is300.. :spy:
    1997tacomav6[OP] likes this.
  9. Dec 30, 2017 at 3:38 PM
    #109
    1997tacomav6
    Denver
    371.00 is a screaming deal, probably cheaper in winter than summer and 160 units sold!!
    Get the low level fluid sensor if you use the windshield tank, you will NOT need to replace the fuel pump,
    Start off with the 2.2 pulley as I'm sure it will work just fine. I had a speed shop that installs these kits do the tuning for me with it on the dyno to make sure my AFR was perfect.
    Your factors will be a size 1 nozzel or size 2 nozzel and when to have the spray start will depend on your
    needs for the truck, each truck will be different depending on the motor and your altitude and pulley size. The spray comes on when the the truck starts to run lean! For me it's 4.5 pounds of boost up. I don't have an AFR but will get one soon, that way you can always check on your system to make sure it's working correctly,
    Run 50/50 methanol to start
  10. Dec 30, 2017 at 4:57 PM
    #110
    1997tacomav6
    Denver
    If your adding a supercharger, a methonal kit for more power, more boost, here are a few things I would suggest
    1) replace fuel filter so your getting 100 percent flow
    2) a better air filter that would accommodate 10 pounds of boost
    3) upgrade the nose seal to a higher quality, 400 degrees seal
    4) change supercharger fluid every 25,000 miles
    5) use the GATES supercharger belt, last the longest
    6) get a steel supercharger pulley as they don't wear out and no slipping
    7) get a low level fluid sensor for methonal
    8) get an AFR gauge
    9) get boost gauge
    10) if you have the 1gen supercharger, get the "O" gasket to replace the "D" gasket at the throttle body
    11) if you have 1st gen supercharger install a butt screw on the nose snout for 5 minute oil changes
    12) DRIVE AND HAVE FUN!!!
    boostedka and eon_blue like this.
  11. Dec 30, 2017 at 5:03 PM
    #111
    eon_blue
    eon_blue Most Improved Member
    I had a Gates belt put on for my supercharger to replace the TRD one, based on your suggestion a little while back. It was less expensive than the TRD version and had great reviews online. I usually hit it (and the other belts) with conditioner every few thousand miles to keep 'em fresh
  12. Dec 30, 2017 at 6:34 PM
    #112
    04yota
    Angelo
    Central New Jersey
    Excellent advice, I also happen to work for an autoparts store which happens to carry gates belts. Do you know what's the part number by any chance?
    Also, what low level sensor did you ordered? I thought the kit came with one.
    I think I will run into trouble using my reservoir as the container, because I have an aftermarket bumper and kinda exposes my reservoir.
  13. Dec 30, 2017 at 6:58 PM
    #113
    eon_blue
    This is the one I installed for my 04 3.4l v6, ordered through Amazon...
    link: https://www.amazon.com/gp/product/B001C97W5O/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
  14. Dec 30, 2017 at 7:24 PM
    #114
    04yota
    Angelo
    Central New Jersey
    Thanks for the info :thumbsup:
    Already ordered the meth kit. I only need the supercharger now :rofl:
    Just waiting to see who I buy it from. Urd has them on back ordered for another 2 weeks or maybe 3. My next option was to order thru Amazon via the seller lce performance, and get me some 5% cash back on my CC :D
    eon_blue[QUOTED] likes this.
  15. Dec 30, 2017 at 7:32 PM
    #115
    eon_blue
    LC Engineering is a good place to buy from, just as reputable as URD...they've been around a long time. Just make sure that if you buy it through Amazon that any warranty LCE normally offers is still intact. Sometimes Amazon will sell things from other vendors "unofficially", meaning you might be getting a great deal through Amazon but the product won't come with the company's warranty because you didn't get it through them...if that makes sense. Just something to look into, good luck!!
    04yota[QUOTED] likes this.
  16. Dec 30, 2017 at 7:39 PM
    #116
    1997tacomav6
    Denver
    A low level sensor is extra I believe but they are cheap and u can probably get a universal one for what ever tank u use
  17. Dec 30, 2017 at 7:56 PM
    #117
    04yota
    Angelo
    Central New Jersey
    Thanks.. Will def check into that.
  18. Dec 30, 2017 at 7:57 PM
    #118
    04yota
    Angelo
    Central New Jersey
    :thumbsup:
  19. Jan 16, 2018 at 11:35 AM
    #119
    Danjor2
    Danjor2 Well-Known Member
    Daniel
    Riverside
    01 Limited Double Cab Prerunner
    I love this build, so many good ideas and helpful information on here
  20. Jan 20, 2018 at 3:35 PM
    #120
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    where did you get the smaller pulley? I have a 2.1 right now. But im at elevation as well so would run a 2'' if i could find it. Probably going to go to a meth kit as well.
    Also, i believe when you say it's fast. I got an sx taco and its so damn light the v6 just moves it a long super easy.
    And do you have EGR? or did you delete it with the new motor?
