1998 taco 4x4 2.7 front Disc brake job
Discussion in 'Technical Chat' started by badaboom, Jan 29, 2018.
  1. Jan 29, 2018 at 2:23 PM
    badaboom
    badaboom [OP] Well-Known Member
    Rick
    GEN1 1998 Toyota Tacoma SR5 4cyl. 2.7
    Pretty much nothing yet rolls drives sucks fuel
    Looks like its getting near time for doing the front disc brakes.
    1998 Toyota tacoma 4x4 ext cab manual hubs manual trans 5 speed
    Can the front rotors be machined? Or you just replace them?
    Any suggestions or related links for this job, parts gotchas etc?
    Thanks
  2. Jan 29, 2018 at 2:28 PM
    00PreRunner
    00PreRunner Well-Known Member
    Jackson, MS
    '05 DCSB 4x4
    2005 DCSB, 4x4, Auto. more to come...
    Rotors can be machined, but if they’re worn thin or warped you’ll wanna replace them. As far as parts go, I usually run Wagner ThermoQuiet pads, they seem to do well. And there tons of YouTube videos and write ups on this forum that show the process.
    CS_AR likes this.
  3. Jan 29, 2018 at 2:35 PM
    badaboom
    Rick
    Do the manual hubs have to be removed or will the rotors come off without manual hub removal ?- thanks
  4. Jan 29, 2018 at 2:36 PM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    Ok you may wanna double check me, but no the hubs don’t have to come off. Once the caliper is off, the rotor will slide off the wheel studs
  5. Jan 29, 2018 at 2:40 PM
    badaboom
    Rick
    Thanks
  6. Jan 29, 2018 at 7:57 PM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    No problem. Post if you run into any problems
  7. Jan 29, 2018 at 9:12 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    In case you don't know, you don't need to disconnect the brake line from the caliper when you remove it. Just be prepared to suspend it with a length of wire (coat-hanger, or romex) after you unbolt it. Don't let it hang by the flexible brake line.
  8. Jan 30, 2018 at 10:27 AM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    X2, my bad for leaving that out
