1999 - Need help identifying a part in the center dash area!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Jan 9, 2014.
  1. Jan 9, 2014 at 6:14 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Hello all. I need help identifying a part. Or perhaps someone could point me to where I could get a diagram to assist in identifying this part.
    The part is located directly behind the center trim and Radio bracket. Im trying to figure out what the part is behind the stereo bracket. Basically, its the bracket/support bars that the radio bracket bolts onto. Its the piece that you would screw your radio bracket into to secure the radio/bracket. The part is metal and it appears to go all the way down to the floor. I have no pictures unfortunately because I dont want to tear out my dash center. Thanks!
  2. Jan 9, 2014 at 6:18 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Jan 9, 2014 at 6:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  4. Jan 9, 2014 at 6:24 PM
    Zer0
    SGV, California
    99 PreRunner
    dam you guys are fast! what the heck! thanks for diagram and reply. Its the piece that # 2 and #3 bolt onto. thanks again! I remember when I looked at the part on my tacoma, its appears to go all the way down to the floor. its then bolted onto something else. but yea....its what 2 and 3 bolt onto and its metal. thanks!
  5. Jan 9, 2014 at 6:25 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    glad to help, thats why we are all here :)
    u seen the link I included to the part right?
  6. Jan 9, 2014 at 6:35 PM
    Zer0
    SGV, California
    99 PreRunner
  7. Jan 9, 2014 at 6:37 PM
    Zer0
    SGV, California
    99 PreRunner
    main reason i want to replace these parts is because the picklehead that the car before me did a mickeymouse job on installing the apline that was in the car. picklehead used the wrongs screw on one side and broke a screw on the other side. picklehead ended up leaving the screw in. instead of trying to remove screw and rethread everything, i figure i just make it fresh again! thanks.
  8. Jan 9, 2014 at 6:43 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    without tearing into a service manual for a 1st gen, I cannot be certain.... Sorry, I dont have one on me :(
    dealership may be able to tell u tho.... they should be able to pull up the diagram and tell u what bolts to what. Just go in and act like ur gunna buy the part...... no need to commit.
    U can always say "thank you, Ill have to double check mine at home and Ill get back to you...what were the part #'s again?"
    then order the parts based off their info
    course, thats unless someone else can chime in here and answer ur question
    #2 and #3 in this diagram kind of look like they connect to the insturment cluster/steering wheel housing............but thats just a guess, I may be waaaaay off
  9. Jan 9, 2014 at 7:53 PM
    Zer0
    SGV, California
    99 PreRunner
    yea thats tru. ill check it out. thanks again for replies!
