1999 Tacoma 2.4L loud knocking sound only when warmed up 222K miles
Discussion in '1st Gen. Tacomas (1995-2004)' started by gdaddy, Apr 2, 2020.
  1. Apr 2, 2020 at 11:24 AM
    gdaddy
    gdaddy [OP] New Member
    Took it to a good, honest mechanic. First listened to front of engine with stethoscope. He believed it was coming from bottom of engine. He disabled #1 injector, sound went away. Reconnected, came back. Dropped oil pan to replace rod bearings. Could see no issue. Checked thrust bearings, could find no issue. Replaced all rod bearings. After engine warmed up, knocking returned. I told him I thought it could be timing chain or guides. He checked front of engine and said he could feel vibration coming from oil pump. He disassembled the oil pump and could find no problem. He replaced oil pump and just to take no chances replaced the timing chain assembly (everything). He even replaced the harmonic balancer. The sound was still there! He told me he does not have anymore ideas at this time. $3800 in parts and labor, and he didn't charge me because he couldn't find the problem!
    Any ideas?
  2. Apr 2, 2020 at 11:28 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  3. Apr 2, 2020 at 12:12 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    This seems too obvious to me so maybe I’m missing something. After disconnecting injector #1 and the knock going away, I would have dug further into #1 cylinder. If the rod bearing didn’t do it I’d be checking wrist pin and piston next. Of course not hearing the sound it made makes it difficult to second guess.
    Black DOG Lila likes this.
  4. Apr 2, 2020 at 12:43 PM
    gdaddy
    I asked him about the wrist pin being loose. He said they tighen up as they get hotter.
  5. Apr 2, 2020 at 12:54 PM
    Old n' slow
    Oak Island, N.C.
    True.......pistons being aluminum warm up and expand so piston slap and wrist pin noise usually get better.
    That’s all I had.......so I’ll get out of the way now and follow this.
  6. Nov 7, 2021 at 6:28 PM
    rustbuster
    rustbuster New Member
    Dave
    South Florida
    03 sr5 4x4 xtracab
    All stock 87k miles
    Hey did you ever get this figured out? I’m having the same issue! Thanks
  7. Nov 8, 2021 at 8:07 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    What about the balance shafts? How much did the engine slow down with the injector unplugged.
  8. Nov 8, 2021 at 8:53 AM
    Glamisman
    Glamisman Well-Known Member
    this is a difficult situation on multiple levels... how much time and money are you going to spend on a 20+ year old truck. Chasing a ghost noise is problem enough and that brings up another issue. If you choose to put a new piston in her where do you stop... do you do a valve job at the same time? If you could do the work yourself I wouldn't hesitate to put in a new piston/new rings and lightly hone that cylinder and drive her. You didnt mention if the truck is a beater or your baby, I would factor that into the decision making process too. At 200k she has another 200k minimum of life left.
  9. Nov 8, 2021 at 9:25 AM
    bwonbwonbwon
    bwonbwonbwon New Member
    Washington
    1999 2.4L Base
    Any chance its the AC pulley bearing? Sometimes on my 99 2.4L I get a knocking that stops when I turn off the AC or defogger for a while. Did some digging and it turned out to be the AC pulley bearing that gets loose after a while.
    https://youtu.be/VjRtLLd0vE4
    https://youtu.be/8ehoRUcGsV4
  10. Nov 8, 2021 at 4:18 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    That mechanic is a keeper do not let him get away!!
  11. Nov 8, 2021 at 10:50 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    No kidding! OP care to share your mechanic??
  12. Nov 9, 2021 at 4:49 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    they haven't been on since February and only made those two posts. PM might be the way to go but that depends on if they check email :D
  13. Nov 9, 2021 at 9:26 AM
    Bivouac
    I hate when this happens!!
    Such is life!
  14. Nov 15, 2021 at 3:35 AM
    gdaddy
    Sorry I went to sleep on this post. I now have 228000 miles and still have the noise. The day after I got the truck back my mechanic called and told me another Tacoma (same year) came into his shop for some work. It had the same knocking sound! I'm going to drive it until one of us (me or the truck) dies. My mechanic is very honest and fair. His name is Mike Holden of Holden Automotive in Snellville GA. 770-982-5546.
