1999 Toyota Tacoma Xtra Cab TRD Off Road - Western Washington
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by irish_11, May 9, 2016.
  1. May 9, 2016 at 10:12 AM
    irish_11
    irish_11 [OP] Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    SOLD
    • 5vzfe V6 with 209k mi
    • 5spd
    • TRD Off Road package has ABS delete and electronic rear locking differential
    • Clean car fax, no accidents.
    • Never smoked in, very clean interior
    • Oil changed every 3.5k-4k mi services documented
    Additions since I have owned it:
    Body:
    • Line-x Bedliner in bed
    • Snug Top canopy with carpeted liner and Yakima mounts
    • 78" Trail-Gear rock sliders (never used as protection, only as a step and jack point to lift the vehicle)
    • ARB Bumper
    • Uni-Track bed tie down track in bed (aircraft style track for securing cargo)
    Suspension and Tires:
    • 33x10.5r15 BFG All Terrains with ____ tread left
    • Sway-a-way 2.5 coilover front shocks (new 2015)
    • All Pro rear leaf springs w/ Old Man Emu Shocks
    • High angle CV joints in the front
    Electrical:
    • Aux electrical fuse panel
    • 500w inverter under the passenger seat
    • On board air with chuck and switch in front bumper
    Comes with spare parts (all new in box):
    • Set of factory service manuals (in 3-ring binders)
    • Radiator hose set
    • New belts
    • Spare CV half shaft for front axel
    • U-joints for drive lines (front and rear)
    • Fuel filter
    The "bad"
    This is the full disclosure of issues section. It is a used truck with some dings and scratches:
    • Small dent in the rear passenger corner where someone backed into me in a parking lot and drove off
    • Small dent in the rear bumper (see photo below)
    • Scratches in the paint after 200k mi of use
    • Power steering pin hole leak in the canister. Asked Toyota about this and they said at the rate it was leaking it was not an issue at all
    • Rear drum brakes need replacing at some point
    This truck has been my daily driver for the last 6+ years. I would not hesitate to take it anywhere. It has been lightly taken off road (mainly Search and Rescue work and forest service roads). It has been maintained using only Toyota parts, fluids regularly changed, and has been well cared for. It has always had floor mats installed (took them out for the photos to show the interior condition)
    Looking for $7,000. No trades. Located in Bothell, Wa (Seattle area)
    SOLD
    mothergoose likes this.
  2. May 9, 2016 at 10:15 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Did you have to weld new leaf spring hangers? I've got mixed answers, even from all pro....
  3. May 9, 2016 at 10:17 AM
    irish_11
    Everett, WA
    2011 DCSB
    No, they worked with the factory hangers. The PO actually installed them before I bought the truck, I just replaced the bushings when shortly after bought it.
  4. May 9, 2016 at 10:19 AM
    JKO1998
    Utah
    Do you happen to know if they're the expos or? Allpro said I needed to....
  5. May 9, 2016 at 10:20 AM
    irish_11
    Everett, WA
    2011 DCSB
    I don't off the top of my head, sorry.
  6. May 10, 2016 at 12:25 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    good luck with the sale, I would really be interested in this if you were closer.
  7. May 12, 2016 at 3:48 PM
    irish_11
    Everett, WA
    2011 DCSB
    Bump. Fresh oil change with filter and new front brakes (OEM pads and aftermarket rotors) added 5/10.
  8. May 16, 2016 at 2:41 PM
    V6Hunter
    V6Hunter Member
    San Francisco, Ca
    88 Longbed 4x4, 5spd, V6 eng. Smittybilt, Aisin Hubs,
    Does this truck happen to be the California legal version, or the 49 state model? I live in the Bay Area, but the DMV wont register any vehicle that won't pass smog rules...
  9. May 16, 2016 at 3:40 PM
    V6Hunter
    V6Hunter Member
    San Francisco, Ca
    Correction! I think any vehicle with more than 7500 miles is OK.. Is that true?
  10. May 17, 2016 at 10:16 AM
    irish_11
    Everett, WA
    2011 DCSB
    Based on the VIN I have the 49 state version not the California Smog version. I don't know about import regulations to California unfortunately, but I am sure you can check online about what is required. It meets Washington Smog regulations right now and has all its factory emissions equipment in place.
  11. May 17, 2016 at 1:37 PM
    V6Hunter
    V6Hunter Member
    San Francisco, Ca
    Yes, I think any vehicle with more than 7500 miles will be Calif. OK. (Protections for new car dealers...) Looks like a great truck and I would definitely be interested in coming by to check it out if our locations weren't so far away. I can't travel away from NorCal for a couple of weeks, so good luck with the sale, looks like a nice truck...
