1999 Toyota Tacoma
Discussion in 'New Members' started by Shaz_12, Dec 8, 2018.
  1. Dec 8, 2018 at 10:19 PM
    Shaz_12
    Shaz_12 [OP] Member
    Shaz
    Toyota Tacoma
    Hey guys I have 1999 Toyota Tacoma. The truck is having trouble starting! It cranks and cranks for few minutes to get it started. I changed the fuel
    Pump but didn't help! I check all the fuses and they all seem to be good. But when I get the truck started it will run fine! Until the next morning and I'll have the same problem.. I need help anyone that knows please! Thanks
  2. Dec 8, 2018 at 11:01 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    Is the check engine light on? If so, have you checked to see what codes it is throwing?
    buckhuntin-tacoma and MJ-12 like this.
  3. Dec 8, 2018 at 11:03 PM
    Shaz_12
    Shaz_12 [OP] Member
    Shaz
    Toyota Tacoma
    The check engine light doesn't come on.
    MJ-12 likes this.
  4. Dec 8, 2018 at 11:31 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    Do the first gens have an in-line fuel filter or just a filter on the pump? Might try cleaning the mass air flow and making sure the air filter is clean.
    Does it only do it after sitting for a while or is it every time you try to start it?
    MJ-12 likes this.
  5. Dec 9, 2018 at 5:50 AM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
    Welcome
    buckhuntin-tacoma and irayfz6 like this.
  6. Dec 9, 2018 at 7:48 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
  7. Dec 9, 2018 at 7:50 AM
    jeprox
    jeprox Well-Known Member
  8. Dec 9, 2018 at 10:00 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  9. Dec 9, 2018 at 10:18 AM
    Shaz_12
    Shaz_12 [OP] Member
    Shaz
    Toyota Tacoma
    Yes I checked everything and all seems to be good! So I don't know what to do at this point.
    irayfz6 likes this.
  10. Dec 9, 2018 at 10:28 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    What you do now is post your question in the first gen section, where it will be seen by more knowledgeable people that can hopefully help you out.
    https://www.tacomaworld.com/forums/1st-gen-tacomas-1995-2004.4/
  11. Dec 9, 2018 at 10:44 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6 and Shaz_12[OP] like this.
  12. Dec 10, 2018 at 4:06 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It needs to crank and crank before it starts this is just after sitting over night .
    Once it starts in the morning your good to go till it gets shut off for a long period
    I wonder leaky injectors fouling out the plugs till they burn all the gunk off .
    This will also completely lower the fuel pressure
    Have you pulled the plugs to see what they look like
    Best guess
