1999 Toyota Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shaz_12, Dec 9, 2018.
  1. Dec 9, 2018 at 10:41 AM
    Shaz_12
    Shaz_12 [OP] Member
    Shaz
    Toyota Tacoma
    Hey guys I have 1999
    Tacoma will crank and crank until it starts. I'll
    Run fine until then next morning and I'll
    Do the same thing again. I changed the fuel pump but still doing the same thing I checked all the fuses they all seem to be working fine.
    Shortbus47XYY likes this.
  2. Dec 9, 2018 at 12:49 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear Shaz,
    Sorry to hear about your 1999 Tacoma starting hard. Please give us some more information. Why did you change the fuel pump if your truck eventually starts? If a fuel pump was malfunctioning, that would mean the truck would be starved for gas, and, as a result, it would be unable to turn over.
    Does your starter sound like it is getting enough electrical power when trying to start the truck?
    Good Luck,
    Paul
  3. Dec 9, 2018 at 8:41 PM
    Shaz_12
    Shaz_12 [OP] Member
    Shaz
    Toyota Tacoma
    Hey Paul thanks for trying to help out! I changed the fuel pump because I was told it was from it. Happen to find out it wasn’t. So I checked all the fuses in the relay fuses and they all seem good. It turns on after trying to start it for 10 minutes. I’ll run fine and I can trun it off after I get it to start. But in the morning I’ll do the same thing!! So I don’t know what else it could be.
  4. Dec 10, 2018 at 5:18 PM
    TacomaJunkie8691
    WA State
    Hey Shaz,
    What engine is in your truck? Okay, so you have done some good homework in trying to solve your hard starting problem. You have checked all of your fuses in your fuse box, and they all check out fine. This tells me the problem lies somewhere after the fuse box. I wish I was more of an electrical expert. It sounds like you have some kind of intermittent short after the fuse box with the electrical connection to your starter. Have you ever changed out the starter?
    Good Luck,
    Paul
  5. Dec 10, 2018 at 7:26 PM
    UnderFire
    UnderFire Well-Known Member
    I'd try jumping the fuel pump for like 10 seconds, then try to start it, if it starts right up like that you'd know it's not holding fuel pressure. That would narrow it down quite a bit. Sounds like it may be the fuel pressure regulator to me.
    TacomaJunkie8691 likes this.
  6. Dec 11, 2018 at 6:15 PM
    TacomaJunkie8691
    WA State
    Good Idea UnderFire.
  7. Dec 12, 2018 at 12:09 PM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Sounds like the FPR has gone bad or you have a fuel line leak somewhere allowing fuel to go back in to the tank.
    The fuel pump has a check valve for the fuel which you have eliminated the possibility by replacing the pump
    The FPR holds fuel pressure in the line until next start as the fuel pump doesn't engage until the engine is actually cranking or on.
    Just thoughts
