1GR-FE Billet Anodized Fuel Rails *** TRD SC approved ***
Discussion in 'Performance and Tuning' started by 05Taco4x4, Jun 8, 2019.
  1. Jun 14, 2019 at 5:00 PM
    #141
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'd rather throw noodles but to each their own!
  2. Jun 14, 2019 at 5:36 PM
    #142
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    There will always be a weak link in any system. What we are doing is raising the ceiling (headroom) before the weakest link can show itself.
    I still run the 255 but may install a fuel pressure gauge so I can monitor FP from in the cab vs at the FPR.
    The fuel pump (FP) only supplies flow which turns to pressure when we restrict the outlet via (FPR). Everything that is in between the FP and FPR will become pressurized to the FPR adjusted value. So with this in mind, if you had say double the fuel capacity in this "pressurized region", then fuel pressure would actually remain more consistent because the pump wouldn't have to compensate for sharper fuel pressure spikes in the system. Pressure spikes are decreased because the fuel reservoir is larger and as long as the pump can keep up with demand at WOT , then the pump is adequate for the application.
    This follows closely with @Torspd's explanation but presented in a different way.
  3. Jun 14, 2019 at 5:49 PM
    #143
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  4. Jun 14, 2019 at 6:05 PM
    #144
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @Roostfactor , could some basic math be done to establish fuel needs? Stock pump is good with a 3" pulley. 2.5 would need x more. Showing roughly where a 255lph pump sets us at? Like just a reasonable estimate. Whatcha think?
  5. Jun 14, 2019 at 6:47 PM
    #145
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is also why you want a fuel pressure dampener. Which has been purposefully integrated. By Mr. @loginfailed
  6. Jun 14, 2019 at 9:47 PM
    #146
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Well, I’m in for FIC 650, just dont know what color, probably just raw. Black if I had to do a color. I will get the funds sorted out. How long do I have to decide on color? How to pay? I rather wait on more people to sign up to get the lowest price, but whatever.
    Roostfactor and loginfailed like this.
  7. Jun 14, 2019 at 11:15 PM
    #147
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    To be clear this does not include injectors, the FIC were a previous group buy. I'll add you to the list and invite you to the buyer's private message.
  8. Jun 15, 2019 at 12:01 AM
    #148
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I love it, I love it!
  9. Jun 15, 2019 at 12:09 AM
    #149
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Anyone who is lurking, watching and waiting around to jump in on this is holding the group buy back. Don’t be that guy!
    We only need 4 more participants to reach the next price level!
    :bananadance::fingerscrossed:
    Roostfactor likes this.
  10. Jun 15, 2019 at 7:18 AM
    #150
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Damn it you guys.
    Ok. I’m in. At the 10+ price point anyway. FIC injector specific and bright red if possible. Otherwise black is fine.
    What aboot a small port up front on the passenger side rail to screw in a nice small liquid filled pressure gauge?
    Something like:
    https://www.redhorseperformance.com/collections/liquid-filled-fuel-pressure-gauges
  11. Jun 15, 2019 at 7:40 AM
    #151
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    WOOT! Only 3 more to go!!!
    If we get to 9, I may swoop in and buy a second set to re-sell later for 1 million dollars.
    @BillDaCat8 Sorry for the peer pressure! :D
    Shh! There might be something going on behind the scenes related to this. :gossip:
    GT7, Roostfactor and 5thGearPinned like this.
  12. Jun 15, 2019 at 8:20 AM
    #152
    05Taco4x4
    2TR-FE Enthusiast
  13. Jun 15, 2019 at 8:29 AM
    #153
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    All right, I’ll stop lurking. Add me also for the FIC group & blue would be my first choice. If not, black will be fine.
    loginfailed and Roostfactor like this.
  14. Jun 15, 2019 at 8:33 AM
    #154
    Roostfactor
    TX panhandle
    Yeah! Another blue request.
    loginfailed likes this.
  15. Jun 15, 2019 at 8:38 AM
    #155
    Roostfactor
    TX panhandle
    Agreed good sir.
  16. Jun 15, 2019 at 8:59 AM
    #156
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Put me in under the fic group... I prefer black if any color
    P.s @GT7 tag, you’re it
    loginfailed, GT7 and Roostfactor like this.
  17. Jun 15, 2019 at 9:01 AM
    #157
    Roostfactor
    TX panhandle
    Damn Dwayne, you sure do an exceptional job at spending other peoples money! Maybe you are in the wrong career field. Sales may be your calling :D
  18. Jun 15, 2019 at 9:02 AM
    #158
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    In, FIC. Black unless @05Taco4x4 does more colors
  19. Jun 15, 2019 at 9:05 AM
    #159
    GT7
    Grant
    Phoenix
    2013 DCLB
    :drevil:
  20. Jun 15, 2019 at 9:07 AM
    #160
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
