1GR-FE F/I Mods and Dyno's
Discussion in 'Performance and Tuning' started by Torspd, Dec 15, 2016.
  1. Jun 8, 2023 at 10:30 AM
    #181
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    from what I read if your going past 2.5 you will want meth, that stuff will get super hot and heat soak.
    jamesepoop[QUOTED] likes this.
  2. Jun 8, 2023 at 10:35 AM
    #182
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    100 more on the Maggy setup? Nos and race gas.
  3. Jun 8, 2023 at 10:41 AM
    #183
    nudavinci64
    Robert
    I think he is thinking his current to @Athlaos levels. Another 100 off that would be impressive but a ton of work.
    Athlaos likes this.
  4. Jun 8, 2023 at 10:56 AM
    #184
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What all performance adders, besides the S/C does yours have? I know a lot ,but cannot remember specifically.
  5. Jun 8, 2023 at 11:19 AM
    #185
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Not really alot... kind more like here and there. 2.7 smoothflow, NST Pulleys, URD Ucon, upsized coolant tank, jba shorties, afe Y pipe, RB VVTi solenoids and aero 340 pump. . Still on TuRD s/c injectors..
    Torspd[QUOTED][OP] likes this.
  6. Jun 8, 2023 at 11:19 AM
    #186
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Going down a few tires sizes would feel like 100hp. :rofl:
  7. Jun 8, 2023 at 3:28 PM
    #187
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I would think you’d want at least some kind of intercooler upgrade. And be running the highest octane possible. And be finely tuned. 100hp… that’d be tough to get even with that though; in my opinion.
  8. Jun 8, 2023 at 5:56 PM
    #188
    Torspd
    Tor
    The Great America!
    There is this. Lol
    nudavinci64 likes this.
  9. Jun 8, 2023 at 7:30 PM
    #189
    jamesepoop
    California
    2007 Fj Cruiser
    I was thinking bigger injectors, intercooler and water pump. High octane is no good. Want to make sure I'm able to run it anywhere. Many times we run into 87-89 octane on the road and it's the only choice. Just know that I'm too lazy to fill a stand alone tank for water/meth. Hmmm
    No going back!!
    SUMOTNK likes this.
  10. Jun 8, 2023 at 7:44 PM
    #190
    Athlaos
    Leigh
    Edmonton
    Well unfortunately, bigger injectors aren't going to make more power - you only need as much fuel as is necessary to make the power goal you want, and the TRD injectors are actually quite good up to 400hp or a little more. You could upsize just to be sure but with a good fuel pump it shouldn't be a problem.
    Hate to break it to you, but 87-89 octane you're not going to make 100 more wheel horsepower with any available bolt-ons that I can think of...
  11. Jun 9, 2023 at 2:14 AM
    #191
    nudavinci64
    Robert
    Maybe it’s time to get a stroker kit and up the displacement. That should help a bit. Haha port the S/C should provide some giants too.
  12. Jun 9, 2023 at 10:10 PM
    #192
    jamesepoop
    California
    2007 Fj Cruiser
    If I'm just doing it for the Dyno, I can obtain the good stuff. But really I just mean, it would need to be obtanium pump gas for 95 percent of the driving. Hence I wouldn't bother with e85 or 100+ oct because it's not going to be around on the road. That's all. But was your Dyno on higher octane? I may consider the water/meth route before smaller pulley if it's saving headaches. Just was hoping there wasn't more work lol
  13. Mar 27, 2025 at 5:39 AM
    #193
    Torspd
    Tor
    The Great America!
    The latest addition, compliments of @Xrunner2nv
    Quote,"What my setup has been able to produce. Cast pistons, bC rods, head studs, BC cam regrind, kelford springs, pulsar 6466, 1700cc injectors, dual fuel pumps."
    SUMOTNK, colinb17 and nudavinci64 like this.
  14. Mar 27, 2025 at 9:10 AM
    #194
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    602.4 hp? :eek:
    herecomesace likes this.
  15. Mar 27, 2025 at 9:43 AM
    #195
    Torspd
    Tor
    The Great America!
    Turbo. This is the way. :militarypress:
    herecomesace, yota243 and colinb17 like this.
  16. Mar 27, 2025 at 10:02 AM
    #196
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    E85 is the way.
  17. Mar 27, 2025 at 10:12 AM
    #197
    Torspd
    Tor
    The Great America!
    No lie there.
  18. Mar 27, 2025 at 1:41 PM
    #198
    Athlaos
    Leigh
    Edmonton
    Fun!
  19. Mar 27, 2025 at 2:55 PM
    #199
    Torspd
    Tor
    The Great America!
    @Xrunner2nv , at what PSI was that pull in the dyno?
  20. Mar 27, 2025 at 5:39 PM
    #200
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Why a dip at 4200?
