1GR-FE rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rheath08, Nov 6, 2021.
  1. Feb 16, 2022 at 3:14 PM
    #201
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Someone hack a block in half and let us know how thick those liners really are. :rofl:
  2. Feb 16, 2022 at 3:48 PM
    #202
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Per the suggestion by @Torspd, I contacted LC Engineering. They said I should get .040" over. They did stress a good machine shop that knows what they are doing due to how thin they are.
    ohcaltexscar, Torspd and PhoS like this.
  3. Feb 16, 2022 at 4:49 PM
    #203
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well that is valuable news. :thumbsup: Glad my memory served you well.
    rheath08[OP] likes this.
  4. Mar 24, 2022 at 9:29 AM
    #204
    rheath08
    Russell
    Bakersfield, CA
    Just a small update. I finally have the block back from the machine shop. I will add more later after work.
  5. Mar 24, 2022 at 10:30 AM
    #205
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is a good start! :thumbsup:
  6. Mar 24, 2022 at 7:54 PM
    #206
    rheath08
    Russell
    Bakersfield, CA
    Alright ladies and gentlemen, the long awaited time has came! I have the block back and it is time to put her back together. If I remember how and not forgot to get need parts. :goingcrazy:
    I will let you in on a little secret,:drevil:
    The block can be bored. I have bored the stock block .5mm over to a bore size of 94.5mm. It brings the CC's up to 3998. :D It makes me excited for it to be a true 4.0. sorry, it's the little things that make me happy sometimes.
    The block has a captured sleeve that is the spiny type. (Posted at the top of this page) I have been told that it can go 1mm over or .040". But at least we now have confirmation of being able to bore the stock block. :headbang:
    I will try to get the crank installed tonight. Here are a couple of pics to drool over.
    Oh, and before you say it, I know using the calipers is not the best way to measure cylinder diameter. It's all I have.
  7. Mar 24, 2022 at 8:13 PM
    #207
    rheath08
    Russell
    Bakersfield, CA
    I have the bearing next to the OEM bearing. Don't panic like I did. The after market bearings are the right ones and size. The factory at one point updated the bearing size and supercedes. The after market companies base there bearings off the new size as well. When looking at the OEM bearings you can see the micro growing that is to help retain oil on the bearing surface. The new bearing I sent out to Polydyn to have a polymer ceramic coating put on to help act as a dry lube on dry starts and initial start up. (As per a recommendation from @Torspd ) The price was about $96 or so, that includes $22 return shipping. I had them do my main bearings and rod bearings.
  8. Mar 24, 2022 at 9:09 PM
    #208
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
  9. Mar 24, 2022 at 10:11 PM
    #209
    rheath08
    Russell
    Bakersfield, CA
    With the help of my friend, the crankshaft is in. It feels really good to be making forward progress, instead of dead stand still. Time for a celebratory Scotch with my friend. IMG_20220324_211915.jpg
    Here are my garage helpers for the evening. Need to give credit due where credit is due. IMG_20220324_220933.jpg
    *Disclaimer* this pic was taken after an 11 hour work day and two Scotch's. She might stab me. :rofl:
  10. Mar 25, 2022 at 4:32 AM
    #210
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :bananadance:
    rheath08[QUOTED][OP] likes this.
  11. Mar 25, 2022 at 4:33 AM
    #211
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers:
  12. Mar 25, 2022 at 4:34 AM
    #212
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know that you're getting a sense of relief and motivation. Doing well my friend.
    12TRDTacoma and rheath08[OP] like this.
  13. Mar 25, 2022 at 7:39 AM
    #213
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    There is something so satisfying looking at freshly machined metal. I guess it's really the anticipation of what is coming.
  14. Mar 25, 2022 at 7:53 AM
    #214
    rheath08
    Russell
    Bakersfield, CA
    Thank you sir!
  15. Mar 25, 2022 at 9:45 PM
    #215
    rheath08
    Russell
    Bakersfield, CA
    On tonight's episode we have rings, pistons and rods.
    Disclaimer: I failed to take good pictures tonight.
    I started off in a unusual order. I installed the wrist pin keeps on one side of the pistons. I then lubricated the small end of the rods and wrist pins. I then assembled them and install the second keeper. I move on the rings after than. After opening that packages, I placed them out into piles of top, 2nd and oil control. I placed each ring in the cylinder and pressed it down using the piston top. (Hence strange order )
    This makes sure the ring is level and straight. The measured the gap with a feeler gauge. I took a flap file to the edges of the ring gap to adjust it to the desired gap size. I set the end gap to the larger side of factory spec. It was a recommendation due to known week ring lands and my engine being supercharged. (Hopefully the aftermarket piston makers took that into consideration) I then installed the oil control ring in three stages. It's three parts. Then the 2nd and then the top rings. WOW, that took up a large amount of time! It's not hard work, just tedious work. LOL! At that point I decided to call it a night. That and my garage help was taking a personal night for shenanigans with Friends, so I did not have anyone to hold the block steady when torquing the rod bolts.
    The piston I believe are "Safety pistons" brand. I got them from LC Engineering, their Street pistons, not forged.
    The rings are Hastings
    The rods are Molnar forged chromemoly H-beam rods.
  16. Mar 26, 2022 at 5:59 AM
    #216
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    Wow that's crazy..
    Really making me worried about my cats, I have an 05 and they've probably had a rough life, lots of -30 cold starts and me not letting the truck warm up (volunteer firefighter...) to get to calls.
    I've had a cat engine light for a while now but I kinda just ignored it, uh should I be worried lol. How do you prevent this??
  17. Mar 26, 2022 at 9:27 AM
    #217
    rheath08
    Russell
    Bakersfield, CA
    To start I have the 3* cam gears, I'm not sure if I have mentioned that. I would need to find out more info, but the cam gears add extra over lap of the valves. Good for performance, but may be why it sucked the cat dust into the engine. I will say the long you run bad cats the higher the risk of them starting to come apart.
    timbobzimbob likes this.
  18. Mar 26, 2022 at 10:58 AM
    #218
    montijo505
    How long were the gears on before the issue? You got me nervous now, I've had them on for about 20k.
  19. Mar 26, 2022 at 11:04 AM
    #219
    rheath08
    Russell
    Bakersfield, CA
    About that for me too. The cam gears did not cause the cats to fail. It was a bad cat that caused the rebuild. The cam gears helped the dust get into the engine. I'm still going to put the cam gears in on assembly.
  20. Mar 26, 2022 at 12:14 PM
    #220
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I’ve lost more sleep over wondering if that cam tensioner bolt that’s torqued to 14# is going to hold even though I went back in and lock-tite it than my valves are sucking in cat dust.
    ohcaltexscar likes this.
