1GR-FE rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rheath08, Nov 6, 2021.
  1. Mar 26, 2022 at 1:51 PM
    #221
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    It will only suck in dust if the cats are coming apart.
    I'm not trying scare anyone, just inform.
    SR-71A likes this.
  2. Mar 26, 2022 at 2:04 PM
    #222
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    yeah, it sucks when that bolt backs out. if you hear a tapping sound then u will knok where to look. it took mine about 8 years for it to back out and cause damage
    Torspd likes this.
  3. Mar 26, 2022 at 9:23 PM
    #223
    rheath08
    Russell
    Bakersfield, CA
    Today I had to be an adult home owner and spend half the day doing yard work. After that I went on got a hair cut and spoiled my self with drink from Dutch Bros. After adulting was done and a late lunch I started on the engine. I started off by taking the caps off and installing the rod bearings. I then cleaned the bolts for the rods. I picked up a inexpensive piston ring compressor the job. With high end parts and cheap tools in hand..:bananadead: I got the first piston ready. As I start to install it, I hit firm resistance after two taps or so. I pull in out. (All puns intended) inspect my rod assembly. I find that the wavy oil control ring shifted and was trying to over lap it's self. Man, that way a pain in the ass to correct. Oily gloves, oily piston, oily rings.:annoyed:. I got it straightened out and round two! Slid in like she was wanting it. :spy:
    I proceeded install the rear main seal, knock sensors and water pipe. I cleaned and prepped the deck to start the cylinder head install. With the arp bolts clean and installed (so no pics, they were in a plastic bag) I placed the head gasket on and applied the bolt lube from arp to the threads and the washers. I lowered the head down and found out I did NOT have the correct socket to torque the head studs. :censored:
    So, with a trip to not one but two auto parts stores I finally found a 1/2" 12point in 3/8 drive. Now I can get back to the job.
    With one head on I said "fuck it I need to get the other head tonight.
    Now time for a shower and a beer......maybe two.
    Cheers friends!
  4. Mar 26, 2022 at 9:43 PM
    #224
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    We’ll done mate. Glad you found the oil ring problem before trying to send it home, and creating an unnecessary problem.
    I am sure you’re quite relieved for your progress. Have a beer for me too!
    rheath08[OP] likes this.
  5. Mar 27, 2022 at 9:46 AM
    #225
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Really enjoying watching / reading your progress.
    Good on ya; keep up the good work!
  6. Mar 27, 2022 at 11:48 AM
    #226
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Great work man, I personally would double check torque on the headstuds tomorrow or late tonight after it has set for a little while.
    Torspd and rheath08[OP] like this.
  7. Mar 27, 2022 at 2:02 PM
    #227
    rheath08
    Russell
    Bakersfield, CA
    Can shafts are in. Time to take a short break.
    Would I be able to get a double check on cam timing? @mightytacoman @Torspd and any others.
    This is bank 1
    Bank 2
    Dm93, eherlihy, deanosaurus and 4 others like this.
  8. Mar 27, 2022 at 5:21 PM
    #228
    mightytacoman
    Kel
    4.5L 1grfe
    Looks right to me.
    Intake cam bank 2 looks ever so slightly advanced to me based solely on the angle of the lobes on the furthest away cylinder (#6 of memory serves)
    that might correct itself some once the main chain is on.
    Pics of "perfect" timing.
    Screenshot_20220327-201740_Gallery.jpg Screenshot_20220327-201758_Gallery.jpg
  9. Mar 27, 2022 at 6:21 PM
    #229
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Cheers to progress!
    Those oil rings are touchy I almost did the same thing.
  10. Mar 27, 2022 at 8:50 PM
    #230
    rheath08
    Russell
    Bakersfield, CA
    It has been a long day of taking my time. Double checked the torque on the head studs, cams, more cams, valve covers (which I found out the complete engine gasket kit from the factory did not have the grommet seals for the valve cover), installed the neverending pill of parts and accessories to the engine. Throughout the day the smile on my face grew bigger.
    I have delivery order and I'm sitting in the garage with my friend admiring the work and progress made over today and the past couple. I'm at a point where I feel good, excited and relieved, to name a few feelings, about this project. I would not have thought the the machine work would have been the biggest hold up. Now, I know I started out thinking I would need sleeves, but I would have thought that the first machine shop would have said something, at least, "hey let's try this, you have to bore it out anyways".
    Sorry for the that tangent/ vent. With double checking the timing and not liking the way it looked, even though bank 2 marks have a gray area. Lol! :facepalm:
    I decided to adjust 1 tooth on bank 2 intake, then rotating 4 rotations on the crank, I checked the cams again. They are looking better in my opinion. Like stated earlier put the rest together. Headers two! Here are some pics of what was done today. Enjoy friends!
    Supervisor doing what they know best.:rofl:
  11. Mar 27, 2022 at 8:56 PM
    #231
    Bishop84
    Bishop84 Well-Known Member
    Just did this thursday.
    Ideally you want to use the marks on the chains.
    Secondary chain marks face rearward.
  12. Mar 27, 2022 at 9:04 PM
    #232
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Looks good so far.
    I am wondering why you didn't replace the cam phasers since everything else is new, I know they aren't known to be much of an issue on these engines but I think I'd want to replace them when doing all that work.
    Hope it all continues to go smoothly for you, I know doing a big job like that one always gets nervous about forgetting or missing something.:thumbsup:
  13. Mar 28, 2022 at 8:45 AM
    #233
    rheath08
    Russell
    Bakersfield, CA
    I had half a thought to replace them. I think at the time I could not find after market ones to help keep the cost down.
    Dm93[QUOTED] likes this.
  14. Mar 28, 2022 at 8:50 AM
    #234
    rheath08
    Russell
    Bakersfield, CA
    Being exhausted and worn out I forgot to add,
    I installed new VVT solenoids, new tensioners and main chain (even tough I replaced them about 20k ago), it will get new coils. I wonder if I should try draining the tank and putting fresh gas in it. it has been in there for about 5 months now. Any suggestions?
    deanosaurus and Murphinator like this.
  15. Mar 28, 2022 at 9:11 AM
    #235
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'd just add some Star Tron and fresh fuel and run it through.
    And thanks for sharing your progress!
    Norton and rheath08[QUOTED][OP] like this.
  16. Mar 29, 2022 at 6:23 AM
    #236
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The wisdom of the elders, whether it's a chainsaw or a helicopter, is "Throw a lil' Sta-Bil in it!" :)
    Great build, thanks for sharing.
    rheath08[QUOTED][OP] likes this.
  17. Mar 29, 2022 at 7:31 AM
    #237
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you want, to verify timing, you can do a compression test. Prior to dropping it in the engine bay. Not necessary, but just an option.
    Attach the starter, and give it some voltage. Add some oil as well. It will prime everything, and will give you compression numbers. I have a simple short video from years ago, doing the same thing.
    eherlihy, TnShooter and deanosaurus like this.
  18. Mar 29, 2022 at 8:02 AM
    #238
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That seems like a great idea to prevent a future headache and provide peace of mind.
  19. Mar 29, 2022 at 8:16 AM
    #239
    rheath08
    Russell
    Bakersfield, CA
    My plan was to crank the engine over with the starter to prime the engine, with the spark plugs out and ECU #1 and #2 fuses pulled to kill the fuel pump.
    Torspd and JasonLee[QUOTED] like this.
  20. Apr 2, 2022 at 7:38 PM
    #240
    rheath08
    Russell
    Bakersfield, CA
    After waiting a week to installed the engine I assembled last weekend. I bring your a short story that involved massive amounts of labor from two hard working individuals and myself. It starts out out by wheeling my tool cart across the yard. My roommate asking if I need help and being stubborn, saying "no". With the two of us maneuvering the cart across goffer ridden lands that seem to never end. The tool cart makes it to the concrete slab where the truck is. A genuine thank you and my roommate going back in the house bare foot with wet grass and other debris on her feet, the preparation is far from done. :rofl:
    As I finish prepping the work area my first friend shows up. After a little BSing my other friend shows up. We start a long filled day of laboring, with a 30 minute break somewhere in the day. We get the engine installed. Then we move on to the next big ticket item, the transmission. With the transmission installed and flush to the block we install the bolts. At this point all is going well. When we start to install the transmission cross member, things are not lining up. Are a few of not remembering how things go, "the theme for the day" we figure out that it's upside down. :facepalm:
    Once we flip it around, right in smooth as glass. Lol!
    Next is the supercharger. Bada bing bada boom, the let's go fast and make you smile thing-a-majig is on. Then the thought........."fuck me, the damn heater hoses!" Now to fish the hoses behind the charger and get the small clamps tightened. I managed to make that happen.with the shakes from lack of food and my friends needing to get home to their wife's, the day is called.with more forward progress made today than expected, I am happy but very exhausted. With beer in hand. Hoping food will happen before I hunt the never ending goffer population in my yard to curb my hunger.
    Well, here I am having a beer trying to write this.
    Sorry, I am exhausted. Relaxing with my roommate and friend my friend from the SoCal area I try to write this chapter. Let me show some of the steps with a couple of pics.
    Cheers friends! :cheers:
    Edit: I'm not even going to correct the mistakes, just to express the exhaustion.
    At this point, goodnight and have a great evening! I may be around for quick comment. If you can read.throigh the beer talking. :drunk:
