1GR-FE rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rheath08, Nov 6, 2021.
  1. Nov 14, 2021 at 2:08 PM
    #61
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i had my cherry picker maxed out and cleared the core support by about half an inch. putting it back in, same and i kinda crunched the throttle body connector. the connector still works but its kinda cracked. probably should have aired down the tires but meh, it worked. the front was sooooo tall tho
    Biscuits and Torspd[QUOTED] like this.
  2. Nov 14, 2021 at 2:10 PM
    #62
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I ordered a complete gasket kit from the factory. I will need a couple of gasket for the water housing extension.
  3. Nov 14, 2021 at 2:16 PM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Perfect time to get the cam gears right next time. :D
    Biscuits and rheath08[OP] like this.
  4. Nov 14, 2021 at 3:11 PM
    #64
    rheath08
    Russell
    Bakersfield, CA
    @Torspd Do you Know what size socket for the main bearing cap bolts are? They look like 12 point. I will need to hunt down a socket.
  5. Nov 14, 2021 at 3:26 PM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I cannot remember. 12 or 14mm are my guesses. I used 1/2" drive.
    rheath08[OP] likes this.
  6. Nov 14, 2021 at 3:52 PM
    #66
    rheath08
    Russell
    Bakersfield, CA
    I got the driver's side head off. This w as the side I think I had the cam gear installed wrong or the timing off a tooth. I do not see any damage to the valves or Pistons. That's a plus.
    Cyl 6
    Cyl 4
    And both sides of the gasket.
  7. Nov 14, 2021 at 5:36 PM
    #67
    rheath08
    Russell
    Bakersfield, CA
    I have pulled the pass side head off and I see no signs of anything cylinders look good.
    The gasket
    Cyl 5
    Cyl 3
    After that I took a short break then tackled the oil pans. I found some small chunks of silicone and 1 small ring spring. I think it came from the valve guide seals I did about 2 years ago.
    Looking at the crank and rods, everything still looks fine.
    I will have to get 2 sockets that are 12 point. A 12mm and a 14mm.
    Now, now I am just as excited to find out as you are, but we will just have to wait for now. :rofl:
  8. Nov 14, 2021 at 6:32 PM
    #68
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
  9. Nov 15, 2021 at 7:16 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cross hatches in those cylinders still look good.
    How are the cam races and bearings?
  10. Nov 15, 2021 at 9:10 AM
    #70
    rheath08
    Russell
    Bakersfield, CA
    The cam journals look good.
    @Torspd are the main bearing cap bolts reusable or one time use?
    deanosaurus, Biscuits and Torspd like this.
  11. Nov 15, 2021 at 9:21 AM
    #71
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well those all look good. You know I am going to raz you a little now though. Change the oil a little sooner. :boink: :D Otherwise, the mystery moves along to the next area. The bowels.
    Biscuits and Wishbone Runner like this.
  12. Nov 15, 2021 at 9:29 AM
    #72
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    No mention of needing to replace them in the repair manual.
  13. Nov 15, 2021 at 9:34 AM
    #73
    rheath08
    Russell
    Bakersfield, CA
    :rofl:
    I change my oil every 5k. I was using full synthetic oil. I did get the truck used at about 75k-80k miles.
    Biscuits, Torspd[QUOTED] and SR-71A like this.
  14. Nov 15, 2021 at 10:36 AM
    #74
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Reminders of a previous life. Lol.
    The main bearing caps' bolts are likely supposed to be thrown away. I may or may not have re-used them though. :anonymous: Many times, without issue.
    TnShooter, Biscuits and rheath08[OP] like this.
  15. Nov 15, 2021 at 12:45 PM
    #75
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the above assembly instructions are correct. The bolts look to be Torque to Yield. The general consensus is you always replace TTY bolts.
    Does everyone, No.
    I’ve been an @Torspd myself too.
    Run what you got.
    If it feels like the bolts are stretching and are usually ”soft” when tightening. Replace them. Other wise, run it.
    Torspd likes this.
  16. Nov 15, 2021 at 2:03 PM
    #76
    Taco'09
    Taco'09 Well-Known Member
    This tear down has me sitting on the edge of my seat trying to guess the source of all that glitter in the oil. For some reason I can't help to keep thinking back a long time ago to one of the first 1GR failures reported on this forum. IIRC it was due to oil starvation to the drivers side of the engine, perhaps pump related(?)
  17. Nov 17, 2021 at 4:29 PM
    #77
    rheath08
    Russell
    Bakersfield, CA
    Well the oil pan spent about 2 hour total in the parts washer today. Here is a little before and after. There are a few tight spots that still have some build up.
  18. Nov 17, 2021 at 5:51 PM
    #78
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That turned out great.
  19. Nov 17, 2021 at 6:34 PM
    #79
    rheath08
    Russell
    Bakersfield, CA
    Look what I finally got in the mail!!
    My 12 point sockets for the mains and rods. :D
    Now, I just need to act like a good home owner and pet parent, then I can go play in the garage.
    Oorrrrrrrrrr. :rofl:
    Torspd, Biscuits and TnShooter like this.
  20. Nov 17, 2021 at 6:37 PM
    #80
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You're being a good home owner by working on your truck.
    Torspd and rheath08[QUOTED][OP] like this.
