1GR-FE rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rheath08, Nov 6, 2021.
  1. Nov 20, 2021 at 7:32 AM
    #141
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Also if the heads are machined, get the amount that they shaved off. you'll need to make up that difference by buying a thicker head gasket.
  2. Nov 20, 2021 at 8:15 AM
    #142
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    how does down stream cat particles get into the oil. Isn't that the other way around?
  3. Nov 20, 2021 at 8:21 AM
    #143
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    tacoman45, Biscuits, Norton and 2 others like this.
  4. Nov 20, 2021 at 8:46 AM
    #144
    Dacapster
    Hugh
    14 trd
    Many coming
    Well damn.....
  5. Nov 20, 2021 at 8:50 AM
    #145
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Feel like this thread should be stickied somewhere lol, or at least the outcome.
    Biscuits likes this.
  6. Nov 20, 2021 at 9:28 AM
    #146
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Damn what a roller coaster lol, good job figuring it out.
  7. Nov 30, 2021 at 7:35 PM
    #147
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Well not to much has been happing. Mostly machine work and waiting. I still need to find a shop to machine the block the block. The shop I was looking at said he would not be able to touch it til after the first of the year. All of his tooling was set up for 90 degree blocks and had a large number to try a push through. My rotating assembly is getting balanced and shout has it by the end of the week. I got info from the other shop doing my heads. They said they don't leak and are straight. :bananadance: They will disassemble and clean them and install the new vitron seals. So I guess a little progress then.
    I took the old rods and Pistons to clean at work. I found two of them had some strange putting on them like something was pounding off the top, but it is only in two spots and both Pistons have them in the same area. Maybe compacting the carbon build up? Not sure.
    I never noticed any damage to the cylinder head.
    Another thing I did was get a new timing cover with oil pump. I thought the old one was damage from a previous repair. It had two low or recessed spots on the sealing face. When opening the new I noticed it was the same way. o_O well, if anyone wants a timing cover to clean and paint for themselves, pay shipping-ish.
    Any ways I also noticed that the tube for the oil to travel from the pump to the filter was poorly made and had very tight bends. In my opinion any way. But what do I know? :rofl:
    So I took the old one and cleaned it up a little. There was no sludge just some staining. I can live with that, so I swapped it to the new cover and pump.
    My OCD's are kind messing with me that the time cover will not be factory or have the Toyota embossing on it. :bananadead:
    I can live with out it.
    I think that is about it for now. As I have more to post I will.
    Stay tuned til next episode kids, assembly and more debt.
  8. Nov 30, 2021 at 8:05 PM
    #148
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Pitting probably from detonation?
  9. Dec 1, 2021 at 10:35 AM
    #149
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Well, your sacrifices may help many Boosted Brothers (any Sisters?) in the future.
    Myself and several others had the aFe Twisted Steel headers blow the cats out. Mine were really bad. aFe sent a complete replacement kit. Skipped that and went with URD EL.
    I suspected there may be some back flow into the engine but you now confirmed that. Although, my cats were disintegrating down stream. One side had the honey comb separating like yours, the other side had blown out with melted chunks.
    I had had oil loss for a period. No leaks (well a little around the valve cover gasket), no smoke. Ran a compression test, all cylinders +/-3psi from 180. Not bad for ~180kmi, ~50k mi boosted.
    As of recent, I have not experienced noticeable oil loss. Are Toyotas Self Healing? ;)
    Curious how the new parts will perform.
    Torspd, Biscuits and rheath08[OP] like this.
  10. Dec 1, 2021 at 10:39 AM
    #150
    rheath08
    Russell
    Bakersfield, CA
    I don't feel like I was have any detonation.
  11. Dec 1, 2021 at 10:52 AM
    #151
    scootter82
    Aurora, CO
    Is this an issue only with the cats closest to the engine? Could this still happen if only running the mid-pipe cats?
  12. Dec 1, 2021 at 11:04 AM
    #152
    rheath08
    Russell
    Bakersfield, CA
    With the primary cats, yes. The secondary not sure, But I will say no due to how far they are down stream.
    scootter82 likes this.
  13. Dec 1, 2021 at 11:51 AM
    #153
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which cylinders were those pistons out of? Detonation pits, from some point in their lives, perhaps?
  14. Dec 1, 2021 at 12:11 PM
    #154
    rheath08
    Russell
    Bakersfield, CA
    I do not know what cylinders. I did not see them under all the carbon, so when I took them to clean them I did not keep track.
    If I were to guess, it would be cylinder 3 and 4. Due to them being in the middle and based off the engine design to help reduce detonation on the middle cylinders. But we may never know.
  15. Dec 1, 2021 at 12:17 PM
    #155
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    :lalala:Well shit happens, this motor has been in there for a while eh?
  16. Dec 1, 2021 at 12:20 PM
    #156
    rheath08
    Russell
    Bakersfield, CA
    :rofl:
    It sure does!
    As stated before, just shy of 170k on a 06 model year. With an apparent rough life before me.
  17. Dec 1, 2021 at 12:26 PM
    #157
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Is what it is, seems like the rings were packing out first. Did you happen to check the bores by chance?
  18. Dec 1, 2021 at 12:37 PM
    #158
    rheath08
    Russell
    Bakersfield, CA
    No, I did not have or have access to an inside micrometer. I will try to remember to ask the machine shop when dropping off the block.
    PhoS[QUOTED] likes this.
  19. Dec 1, 2021 at 1:53 PM
    #159
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    Those cats are a mess.
    Fun story.
    The 2002-2003 WRX has a small cat before the turbo in the up-pipe. It was tragically famous for breaking up if the car was driven in the typically American fashion of stop/go and depositing itself into the turbo. Hilarity never ensued and you were buying a new snail.
    Torspd and Biscuits like this.
  20. Dec 2, 2021 at 2:14 PM
    #160
    rheath08
    Russell
    Bakersfield, CA
    One small step for progress, one large leap for this project. :bananadance:
    Today I got the head back from the shop. They are straight and have no leaks. They disassembled the heads and cleaned them. On assembly they put in new valve guide seals. Man do they look good.
    Before:
    After:
