1GRFE Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lucky, Feb 20, 2010.
  1. Nov 6, 2019 at 2:17 PM
    #101
    Muddinfun
    Muddinfun Well-Known Member
    Yes, that's a problem. That engine didn't come out of a Tacoma and won't work in a Tacoma.
    henryp and T3d[QUOTED] like this.
  2. Nov 6, 2019 at 6:09 PM
    #102
    T3d
    T3d Member
    2006 DC LB TRD SPORTS
    @Muddinfun, as I recall @lucky swapped engines between 07 and 09. Didn’t dual VVTI came out in 09 engines? I wonder if lucky had any issues. I might have to switch out parts from the old engine, I recall reading a tread somewhere here. Fingers cross.
  3. Nov 6, 2019 at 6:11 PM
    #103
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    T3d[QUOTED] likes this.
  4. Nov 6, 2019 at 6:12 PM
    #104
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dual VVT engines are in the 10+ FJ, and '9 or '10+ 4Runners.
    As long as you purchase a Tacoma, it will swap in. Some external parts may be to be swapped to match how yours came. No biggie.
    T3d[QUOTED] and henryp like this.
  5. Nov 6, 2019 at 6:19 PM
    #105
    Muddinfun
    A few more words added to make this more clear.
    Dual VVT engines are in the 10+ FJ, and '9 or '10+ 4Runners and so far we don't know if anyone was successful in swapping into a Tacoma.
    As long as you purchase a 4.0 Tacoma engine, it will swap into any '05-'15 Tacoma. Some external parts may need to be swapped to match how yours came if you swap a '12-'15 engine into a '05-'11 Tacoma. No biggie.
    fixnfly and T3d like this.
  6. Nov 6, 2019 at 6:36 PM
    #106
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    Yes, I put an 09 in my 07. They were identical. The 09 had a mere 1200 miles on it when I got it. No issues at all, everything bolted and plugged back up perfectly - no hacking of anything.
  7. Nov 6, 2019 at 6:40 PM
    #107
    lucky
    NB, TX
    07 PreRunnerX4
    Its almost impossible to hook it up wrong. All the wiring and connectors have just enough slack to reach the place they need to be connected. I recommend you take some pictures anyway - all the vacuum lines can get a little confusing.
    T3d likes this.
  8. Nov 6, 2019 at 7:58 PM
    #108
    T3d
    T3d Member
    Thanks you guys for the reply, this is a great tread that we 2nd gen owners will always fall back on, I will update on how my swap goes. The DONOR ENGINE is coming from 2010 4.0L Tacoma.
  9. Nov 6, 2019 at 11:01 PM
    #109
    T3d
    T3d Member
    this answers my # 2 questions, thanks @Muddinfun
    Muddinfun likes this.
  10. Nov 7, 2019 at 4:31 AM
    #110
    lucky
    NB, TX
    07 PreRunnerX4
    1. Is it better to use the donor engine wire harness? Or use my old wire harness.
    I used my existing harness. At the time I did the swap, my truck had around 80k miles on it. All wiring and connectors were still in good shape, not brittle or cracking, so I used what I had. I didnt have the entire donor truck anyway - just engine, minus intake, harness, ecu.
    2. Any issues with the dual VVTI? Being my truck (2006) is single VVTI.
    answered
    3. Do I have to replace my 2006 ECU with 2010 ECU?
    With my swap being an 09 going in an 07, I didnt - plus as noted above, I didnt have the 09 ecu anyway. If you have the 2010 ecu, I say use it. Put the 06 one on the shelf as a spare or sell it here - it will likely go quick. If you really want to get the most out of your new-to-you engine, I would recommend flashing which ever ECU you end up using with a good tune - ala HPTuners.
    T3d likes this.
  11. Nov 7, 2019 at 5:53 PM
    #111
    NewTacoDude
    NewTacoDude Member
    2005 Tacoma V6 Prerunner
    I too completed a swap on my tacoma. 2011 Tacoma engine went into a 2005 Tacoma. However, after completing the swap, I have yet to hear it run. engine has 80k miles when pulled. I’m getting these codes: p0121, p0123, p0102, p2135 and p0113. I tried swapping out the air mass sensor from one I bought off of eBay for about $13 (kind of suspicious of that) but it didn’t change anything and I don’t want to throw parts at it. Anybody ever have this issue? Plenty of spark, fuel and compression but it’s a dead no start
    T3d likes this.
  12. Nov 7, 2019 at 10:21 PM
    #112
    T3d
    T3d Member
    @NewTacoDude, my engine is in transit right now. I most like will encounter the same issues you are having. The engine is from 2010 Tacoma to 2006 Tacoma. I’m interested to know more from your experience and I will also post mine here as I go with my engine swap.
  13. Nov 27, 2019 at 8:16 PM
    #113
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    Getting ready to replace my 2005 to a 2007....
  14. Nov 28, 2019 at 2:39 AM
    #114
    T3d
    T3d Member
    I just had mine swapped last weekend, I still have to do the electrical wirings. I did it with the occasional help from my 17 y.o son I used the 2T hoist from HF, the 1T has not enough reach. And while at it, I also rebuilt the alternator and flush the PS fluid.
  15. Dec 1, 2019 at 5:17 PM
    #115
    toyotaman29
    Darrell
    North Carolina
    Hey guys, you pull the exhaust manifolds off or can i just unbolt it underneath?
    T3d likes this.
  16. Dec 1, 2019 at 6:05 PM
    #116
    T3d
    T3d Member
    @toyotaman29, in my case I pulled it out to make the load lighter and have more room. I should have leave it. I remove the oil filler extension for safe keeping as the donor engine arrived with broken oil filler. Hope this help. You need to replace those metal gasket in between the manifold and the engine block and also the manifold and the down exhaust. These gaskets are suppose to be single use only.
    toyotaman29 likes this.
  17. Dec 1, 2019 at 6:56 PM
    #117
    Muddinfun
    @T3d In the 1st pic in post #114, the left engine has the engine oil cooler for the towing package. The right one does not. Since the right one has plastic plugs, I'm assuming that's the replacement engine. Did you transfer the engine oil cooler parts over to the replacement engine?
    T3d likes this.
  18. Dec 1, 2019 at 6:58 PM
    #118
    T3d
    T3d Member
    Yes I did, the donor engine came with no oil cooler.
  19. Dec 1, 2019 at 7:48 PM
    #119
    toyotaman29
    Darrell
    North Carolina
    @T3d thanks for the info...
    T3d likes this.
  20. Dec 1, 2019 at 8:02 PM
    #120
    T3d
    T3d Member
    @toyotaman29, your welcome. I did my engine with guidance from members in this forum. I’m more than happy to share my experience.
