1st gen 105 amp bolt in alternator.
Discussion in '1st Gen. Tacomas (1995-2004)' started by chagovatoloco, Sep 21, 2019.
  1. Aug 9, 2022 at 2:44 PM
    #401
    packman62
    packman62 Member
    Mesa, AZ
    1999 White Tacoma Pre Runner Ext TRD
    Denso part #210-0461 is listed at 105 amps. If they’re telling you the alternator you found is 160 amps it’s definitely not the same one. If you are running or planning to run a lot of electrical accessories, 160amps may be adequate for your 4Runner. It would be overkill for me. The unit I ordered was for a 2001 model. Sounds like the 02-06 units amp output is higher.
  2. Aug 27, 2022 at 4:02 PM
    #402
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    Now that I’ve had 6 months of driving to really soak in the difference, I can say for certain this is a must have. Not only is the electrical system sharp as a tack, but I’ve even noticed better gas mileage and all around performance.
    Could I have gotten similar results with a regular OE replacement? Maybe. But if I can get a little more juice for my add-ons while still buying Denso then I think it’s an easy choice.
    Thanks again to the freaks who can discover things like this for morons like me.
    leid, Madjik_Man and Area51Runner like this.
  3. Oct 22, 2022 at 6:41 AM
    #403
    1997tacomav6
    Denver
    Well 3 years later with zero issues, 90k on this alternator it has died,
    Uggg,
    Just went with an 90 amp life time replacement from O’Reillys now
    leid and Area51Runner like this.
  4. Oct 22, 2022 at 7:37 AM
    #404
    Taco!
    Taco! Well-Known Member
    98Xcab4WD
    Rock Auto still showing out of stock for the 105 amp. Anybody found another source recently? My stock alternator hasn't died yet but I'll keep it in reserve if I can find one. Might have to scrounge pick n pull.
  5. Oct 22, 2022 at 7:38 AM
    #405
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Bummer. My original OEM Denso alternator is still working after 25 years but I think it is the early 60 amp type. It would be interesting to see if your dead Denso 210-0461 105 amp alternator just needed brushes or what.
    1997tacomav6[QUOTED] likes this.
  6. Oct 22, 2022 at 1:06 PM
    #406
    1997tacomav6
    Denver
    My original one is 60 amp, I put in a 2004 alternator that’s 80 amps or 90 amps,
    Everything is the same
    leid[QUOTED] likes this.
  7. Oct 22, 2022 at 1:40 PM
    #407
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Well that’s a bummer o_O I would of expected at least 175k like most Toyota alternators get.
  8. Oct 22, 2022 at 3:01 PM
    #408
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I'm about the same age but less mileage. On a trip to the SW Colorado I was getting some lights surging at idle and the volts fluctuated way more than it did before (14.6-13.6). I replaced it with my old for now and ordered a replacement regulator off ebay for $20, I will toss it back in and see how it goes. The bearings and brushes are still in great shape so it should be back up and running with the new parts.
  9. Oct 22, 2022 at 3:14 PM
    #409
    1997tacomav6
    Denver
    My voltage was fluctuating by one volt too sitting at idle jumping back and forth and the following morning the battery was completely dead.
    So mine was a diode or regulator,
  10. Oct 22, 2022 at 3:19 PM
    #410
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Yup,
    This is what I bought, matched the numbers on the back of the regulator.
    https://www.ebay.com/itm/174523263057
    I will report back when I get it, I may have it tested at auto parts store first before tossing in the truck. Mines a PITA to swap because of my battery tray and winch controller box.
  11. Oct 22, 2022 at 6:25 PM
    #411
    leid
    Brandon, MS
    Understood. I would like to put one of the reman Denso 210-0461 105 amp alternators in my '97 Taco 4x4. But if it is still unavailable when I need to replace my original 60 amp OEM alternator, I will have to decide between the new 80 amp 13794N NipponDenso at Rockauto or the new 140 amp 13671 alternator sold on Ebay. Still on the fence as to which would be the better choice.
    EDIT: I wound up going with a new 80 amp. 13794N NipponDenso alternator from RockAuto. It is the highest output OEM type alternator I saw, and it is charging at 14.37V. at high idle which will work just fine. Good timing too because my OEM alternator bearings finally started getting noisy after 25 years of offroad abuse.
  12. Oct 22, 2022 at 7:53 PM
    #412
    Godzilla619
    Godzilla619 Well-Known Member
    David
    San Diego
    2000 Black Taco prerunner v6
    Mid travel
    I wonder if that ebay 140 amp is any good. The company has good reviews
    EDIT: After further research, nevermind lol
  13. Oct 22, 2022 at 11:12 PM
    #413
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    That sucks. Was hoping the extra amps would add life, not reduce by half.
    I don’t think O’Reilly’s understood what they signed up for when they gave you lifetime replacement. :evil:
  14. Oct 22, 2022 at 11:30 PM
    #414
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    2 Odyssey Extreme batteries, and 11 years later and my 180 amp DC Power Engineering alternator still shows no signs of slowing down. Best thing you can do for a healthy electrical and ignition system.IMO
    Just installed a 270 am DC Power on my FZJ80.
  15. Nov 12, 2022 at 11:04 AM
    #415
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    chrslefty, cbechtold and 1997tacomav6 like this.
  16. Nov 12, 2022 at 7:46 PM
    #416
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
  17. Nov 19, 2022 at 7:38 PM
    #417
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
  18. Nov 30, 2022 at 11:04 AM
    #418
    chagovatoloco
    chagovatoloco [OP] Active Member
    Santiago
    1999 Tacoma SR5 4x4
    Arb front bumper, EMU 883 front springs, Bilstein 5100, power stop front rotors, 105 amp alternator, KC underhood lights, 33" KO2 tires, KC LED daylighters.
    I'm just amazed this thread is still going, lol. Some one asked me about a 120 amp fuse it is bussman: bp/flm-120-rp. I used a denso unit because it was OE but honestly any quality reman alternator that interchanges from this number will work.
    Also I like to add that many people do not know how much tension to put on the belt. So a simple test is to place a socket on the alternator pulley after tightening and try to turn the pulley. If the whole engine tries to turn with the pulley then the tension is set correctly; if the pulley spins easily without moving the belt than the tension is too lose or maybe the belt is worn.
    I have been running this since I first posted it with zero issues.
    Hope this helps,
    Santiago
    Nano909, Area51Runner, leid and 2 others like this.
  19. Feb 3, 2023 at 3:58 PM
    #419
    Slumped.slim
    Slumped.slim Member
    1996 Xtra Cab 2wd Taco
    Anyone have any insight on a alternator that also fits for the 2.4 Taco? Anything over the crappy 60amp I have would help. I got some help from @chagovatoloco saying theres a chance of a V6 one fitting but theres no for sure answer
  20. Feb 3, 2023 at 9:03 PM
    #420
    det107
    det107 Well-Known Member
