1st Gen 3rd member removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by dkellogg3, Dec 28, 2015.
  1. Dec 28, 2015 at 11:45 AM
    dkellogg3
    dkellogg3 [OP] Active Member
    03 SR5 TRD Offroad
    2003 TRD Offroad SR5
    V6
    4WD
    Elocker
    So, I'm getting around to pulling my 3rd member. I'm following this thread. Went through step by step, including the do not-disconnect-the-brake-lines, and the manually-switch-the-elocker-with-a-screwdriver steps. Cant get the sucker to slide off, it feels like something is holding it on at about the 1:00 position looking rearward. This is the area of the locker, so I think it must have something to do with that, but it could also be rust.
    Is there anything different about the procedure for the 1st Gen vs. the 2nd Gen w.r.t. the locker?
    Please help! I feel like I'm sitting on the garage floor with my guts hanging out!
    THanks,
    Don
  2. Dec 28, 2015 at 12:35 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I just read the thread that you linked to. I've removed 3rd members before, but that was in 1962.
    You could try getting it started by using a hammer and a nice, thin chisel between the 3rd member and its housing. I would first make sure that the elocker is all the way to the center of the housing and then start tapping the chisel lightly all around the housing until I could see it "crack" all the way around. Then I would hammer a bit more until the crack widens to about 1/16 inch or so, and then carefully separate the 3rd member the rest of the way.
    Keep us posted!
  3. Dec 28, 2015 at 12:57 PM
    dkellogg3
    03 SR5 TRD Offroad
    I'm loose all the way around, except around the 1:00 position. When I wiggle I can get the bottom to move about 1/8". At the top at around 12:00, and at about 3:00 I can just see oil moving in the joint when wiggling. Was worried about marring the mating surfaces, but if I use permatex I guess that should fill in any defects.
  4. Dec 28, 2015 at 2:29 PM
    dkellogg3
    03 SR5 TRD Offroad
    Still no luck. Uploading a video of it wiggling. Will post link when complete.
  5. Dec 28, 2015 at 2:36 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    *watches man wiggle third member on Internet*
    jmaack likes this.
  6. Dec 28, 2015 at 2:36 PM
    dkellogg3
    03 SR5 TRD Offroad
  7. Dec 28, 2015 at 3:02 PM
    dkellogg3
    03 SR5 TRD Offroad
    Any thoughts on double Nutting the top two studs and backing them out? 4 already came out during disassembly.
  8. Dec 28, 2015 at 3:18 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Locker is in the "locked" position?
    808tacomaramblaaa likes this.
  9. Dec 28, 2015 at 3:26 PM
    dkellogg3
    03 SR5 TRD Offroad
    Yup. All the way to the left, looking rearward
  10. Dec 28, 2015 at 3:41 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Watching that vid it looked like all the studs were free of the third. When prying on it is the pinion still free to move?
  11. Dec 28, 2015 at 3:43 PM
    dkellogg3
    03 SR5 TRD Offroad
    Do you mean is the drive shafts disconnected? If so, yes.
  12. Dec 28, 2015 at 3:45 PM
    devinzz1
    devin
    2023 aclb trd or mt
    I mean can you spin the diff by hand while prying.
  13. Dec 28, 2015 at 4:11 PM
    dkellogg3
    03 SR5 TRD Offroad
    Don't know about while prying, but when not prying, yes. Will check.
  14. Dec 28, 2015 at 8:06 PM
    dkellogg3
    03 SR5 TRD Offroad
    Anything else from the late night crew?
  15. Dec 28, 2015 at 9:03 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Are the axle shafts pulled out for enough to clear the 3rd member? Also, sometimes the elocker shift fork won't move as far as it needs to with just using a screw driver. If this is the case you will need to push in the driver side axle back into its normal position. Once the shaft is back, rotate it some in either direction and then again try to move the elocker shit fork over as instructed in the write-up.
    Edit: I'm willing to bet that the axle shaft isn't pulled out far enough. Do you have a helper available to pull out the shaft some at the same time that you are removing the 3rd form the housing
  16. Dec 29, 2015 at 4:02 AM
    dkellogg3
    03 SR5 TRD Offroad
    I'll try these this morning. Would spinning the pinion flange and looking at the wheels hubs be a "tell"?
  17. Dec 29, 2015 at 5:30 AM
    dkellogg3
    03 SR5 TRD Offroad
    The checked the locker fork, rotating the axle as you said, and found that I have it in the correct position. Pulled the driver side axle all the way out, and have the passenger side out 8". Still same problem. Is it time for prying?
  18. Dec 29, 2015 at 5:30 AM
    dkellogg3
    03 SR5 TRD Offroad
    Yes, when prying as shown in the video, pinion flange still moves.
  19. Dec 29, 2015 at 6:10 AM
    dkellogg3
    03 SR5 TRD Offroad
    The suspected culpril... the stud at 1:00. Flange rusted to stud inside the hole?. PB blaster + heat & cold. Any other tricks?
  20. Dec 29, 2015 at 8:32 AM
    dkellogg3
    03 SR5 TRD Offroad
    Success! It was the stud/flange corroded. PB Blaster + heat + cold + time + pry bar = 3rd member off.
    tan4x4 and devinzz1 like this.
