1st Gen 4x4 Front Diff Bearing Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, May 7, 2013.
  1. May 7, 2013 at 10:01 AM
    boshak
    boshak [OP] Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    While sifting through the mounds of info in the 2nd gen thread about their front diff vibrations, I noticed that there are several 1st gens with similar issues (myself included). I made this thread to compile our own experiences and make it easier for us to filter through the information.
    Please post your 1ST GEN experiences with diagnosing your problem, replacing the bearing and if it was on the driver or passenger side, what manufacturer you used (ECGS or OEM), details of the job, and whether the problem was fixed or if it came back.
    Problem: (Language taken from 2nd gen thread, thanks little brothers)
    It has been identified in a number of previous threads that vibrations may originate from a worn needle bearing and/or CV axle shaft on the driver's side of the front diff, a condition that is often exacerbated by putting a lift on the truck. A worn bearing/axle shaft condition may be present if you experience vibrations/groaning/growling (most typically between 30-40 mph, but also at other speeds) and the vibrations disappear the instant you switch from H2 to H4. Therefore, this is not a place to discuss rear driveline vibration issues, rear carrier bearings, rear driveshafts, axle shims, or other irrelevant matters.
    Potential Solutions:
    Replace the front differential needle bearing, whether it's from ECGS or OEM. This is the solution for 2nd gens and hopeful to hear similar experiences for 1ST GENS.
  2. May 7, 2013 at 1:28 PM
    brianpdx
    brianpdx Well-Known Member
    1999 SR5 TRD 4x4
    Interesting. I need to try something. Dropped the carrier bearing, got shims installed to no avail. Subscribed.
  3. May 14, 2013 at 9:59 AM
    boshak
    Tony
    Southern California
  4. May 14, 2013 at 11:34 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Interesting. I took off friday to swap my CV's, change ball joints, and inner/outer tie rods.
    I this may be the cause of the annoying vibes. I wonder how much of a pain in the dick it is to remove and press in a new bearing.
  5. May 15, 2013 at 3:11 PM
    boshak
    Tony
    Southern California
    Here is a video of how easy it is on a 2nd gen.
    I spoke to ECGS. The 1st gen bushing is still in the works but the rep couldn't gauge timing for availability. Since it hasn't been tested thoroughly, it didn't sound like it would be ready anytime soon.
    I'm taking my truck to the shop tomorrow for inspection. I'll keep you posted on what they find.
  6. May 15, 2013 at 6:23 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    04 SR5 4x4 TRD Xtra Cab
    Mine has had this issue for almost two years. Its a deep, rumble strip sound on the drivers side between 15 and 35 mph or so. I've contacted ECGS numerous times. They told me last November that a fix for first gens would be out in January. Still waiting..
  7. Jul 12, 2013 at 2:52 PM
    Inverno4
    Baltimore, MD
    First gen bearing is ready. Got to call to order. Price for bushing and removal tool around $100.
  8. Jul 23, 2013 at 7:48 AM
    Inverno4
    Baltimore, MD
    Got the new bearing from ECGS installed. No more vibration!
    alphabravo likes this.
  9. Jul 23, 2013 at 1:21 PM
    Inverno4
    Baltimore, MD
    Details of my install:
    It took about two hours to get everything done. Two key things were first the removal tool needed to be shaved a little bit in order to fit behind the needle bearing. We tried tapping it in place and to no avail. Also when the needle bearing is almost out, you have to add something to extend to puller. Once the bearing is out against the steel plate, it still have a bit more to come. New bearing very easy to install using Autozone racer driver kit.
    If anyone wants my removal too, I'd be willing to sell it.
  10. Jul 23, 2013 at 6:22 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Interesting. How much you want for the tool?
  11. Jul 24, 2013 at 4:23 PM
    Inverno4
    Baltimore, MD
    If you give me a week to make sure the install doesn't have any problems, ill sell it for $40 includes shipping.
  12. Jul 24, 2013 at 6:45 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    yeah ill take it when your sure of the fix.. how much is the bushing?
  13. Jul 25, 2013 at 3:41 AM
    Inverno4
    Baltimore, MD
    Correction, I paid $40 for the removal tool so I'd sell it for $30, which includes shipping. The bushing was $50 and the axle seal (not necessary but recommended) was $15.
  14. Nov 18, 2013 at 8:14 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I've been having similar vibes and just got off the phone w/ ECGS about this fix.. Price went up to $60 for the bushing and $60 for the tool ..:eek:
    I know that Inverno4 fixed his issue w/ the bushing, but how about the OP and tacomataco2 ?? did you guys install the bushing?
    thanks
  15. Nov 18, 2013 at 6:49 PM
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I too would like to know. Bump for answer :) mine goes away in 4wd, and I checked some of the other things like wheel play. It's weird though, I feel/hear it more from hub side.... Subbed.
  16. Nov 18, 2013 at 8:21 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    I didn't, i think its about $130 with shipping for everything. A little much for me right now haha
  17. Nov 19, 2013 at 11:49 AM
    johnboyTRD
    South SF bay
    Well... Pretty sure I'm gonna do this in the next month or two. Planning on updating y'all. If you don't see anything, hit my lazy *** up by pm.
  18. Nov 26, 2013 at 1:59 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    So, we sacrifice needle bearings, for a bushing assembly? Not too sure how I feel on that, but whatever works right.
    I have this slight grumbling/pulsing vibration in the front of my truck. doing 30-40, I feel this slight pulsing vibration, on the driver side floorboards, once every 5 seconds or so. Is this a sign my needle bearings took a dump?
    why is it only the driverside that goes crappy?
  19. Nov 26, 2013 at 5:17 PM
    johnboyTRD
    South SF bay
    That is what mine does... I just purchased the tools needed (I'm a newb), calling ECGs tomorrow to see the scoop on bushing. Stay tuned. I read somewhere from a chap who spoke to ECGs that these were supposed to be good for 200k +. I'll try and ask tomorrow when calling.
    jahsonferg likes this.
  20. Nov 27, 2013 at 5:39 PM
    johnboyTRD
    South SF bay
    Spoke with Craig at ECGs. Cost is. $120 for tool and bushing. He basically said this fix will last as long as the truck. I guess I'll be the test subject and report back. Ordering and installing in the next monthish.
