1st Gen 4x4 Front Diff Bearing Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, May 7, 2013.
  1. Nov 2, 2015 at 12:05 PM
    #221
    bmfx1
    bmfx1 Member
    Sacramento
    1996 Tacoma SR5 4x4 xtra cab 3.4L
    3" Toytech lift
    Nope no special bushing for the right side, They sold me a oem toyota bearing. :cheers:
  2. Nov 4, 2015 at 12:25 AM
    #222
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    ok i got the bushing and the tool on the way. also a cheap race driver kit off Amazon.
  3. Nov 4, 2015 at 3:04 AM
    #223
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Change the seal while ure at it.
    alphabravo[QUOTED] likes this.
  4. Nov 4, 2015 at 4:49 AM
    #224
    NF2001Yota
    NF2001Yota Well-Known Member
    2001 4 door 4x4 toyota tacoma
    All of those silver shavings are just there to make the Gear oil sparkly right? :annoyed:
  5. Nov 4, 2015 at 5:52 AM
    #225
    devinzz1
    devin
    2023 aclb trd or mt
    Juts aswell to start pulling that diff. Theres some big ass shavings in there
  6. Nov 5, 2015 at 4:21 PM
    #226
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  7. Nov 5, 2015 at 6:18 PM
    #227
    devinzz1
    devin
    2023 aclb trd or mt
    I didnt get a sticker... :notsure:
  8. Nov 16, 2015 at 10:48 AM
    #228
    NF2001Yota
    Does anyone know where to purchase 4:10 gears for the front differential?
    Debating on buying a used one or rebuilding current one.
    Thanks
  9. Nov 16, 2015 at 3:25 PM
    #229
    devinzz1
    devin
    2023 aclb trd or mt
    Ecgs...?
  10. Nov 16, 2015 at 5:24 PM
    #230
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  11. Jan 26, 2016 at 12:13 AM
    #231
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I finally got this installed. Here are a few pics:
    The job would have been impossible without this crowbar I think. I used it to lock the rotor so I could remove the hub nut, also to pop the CV and seal off, then to push the CV back on.
    Pop CV with crowbar.
    Pop seal with crowbar.
    Seal off.
    Drilled holes in the bearing extraction tool so I wouldn't lose it inside the diff.
    Further modify ECGS tool to fit inside the bearing. Rather than change the diameter of the tool I chose to bevel it so that it can be angled into position behind the bearing.
    One further modification to the tool with the grinding wheel so that I can grip it with the vise grips and prevent the threaded rod from turning. Without this mod you don't really have enough nuts to do the job
    Extract old bearing. Tool wired so I don't lose it inside the diff.
    Add spacers for the last bit of the pull.
    Drive the bushing in.
    Check that the bearing is going in straight.
    I needed the crowbar again to drive the CV back on.
    Setup for driving the CV back on. I'm embarrassed to say how long this took, giving the flange a few wacks and then turning the hub nut with the wrench and repeating. I'm thinking there must be a better way.
  12. Apr 21, 2016 at 5:43 PM
    #232
    James Lee
    James Lee 1st gen for the win.
    Seattle,WA
    2001 Tacoma 4x4 Limited TRD
    -OME 882 coils -Jeep Jk 10mm trimpackers -Wheeler's extending rear brake line -OME Dakars+aal -4in Deckplate -nitro sport shocks all around -Star Hid projector headlights -Trail gear rock sliders -Trail Gear low profile front bumper -Pro Comp 51's 15x8 on BFG KO 32" -ARB snorkel -EBC pads and rotors -Rago Fabrication ditch lights+brackets -SpiderTraxx 1.25 wheel spacers -Snugtop Canopy
    Sorry if this is a dumb question. Is the bushing applies for both driver and passenger axles or just driver side?
  13. Apr 21, 2016 at 6:37 PM
    #233
    devinzz1
    devin
    2023 aclb trd or mt
    Just drivers. Passenger uses a bigger bearing that doesn't give as many issues I believe
  14. Apr 21, 2016 at 9:40 PM
    #234
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yes. That is what they told me as well. They don't make anything for the passenger side.
  15. Apr 22, 2016 at 10:56 AM
    #235
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    I still can't believe Toyota never issued a TSB on this for 1st gens. Mine has been doing it since my truck had 35K miles or so. And my 4runner just started doing it a couple months ago. 4runner is on the list tho, so it's going in to be fixed.
  16. Jun 28, 2016 at 11:00 PM
    #236
    Hiluxborn
    Hiluxborn Well-Known Member
    Clint
    2002 white tacoma trd
    5 inch tuff country lift, adjustable bilsten 5100's. Toyo MT's on 16' wheels. Magma flow muffler. Viper alarm/auto start. Moog sway bar links,tie rod ends and lower control arm bushings.
    Does anyone have the tool that's been modified that I could buy off them?
  17. Jun 29, 2016 at 12:30 PM
    #237
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    To answer you question about removing/replacing the axle nut yes there is, a pneumatic impact wrench! Makes it very short work..old post I know, just wanted to throw in my .02c
  18. Aug 22, 2016 at 11:11 PM
    #238
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Anyone have a resized removal tool for sale?
  19. Aug 27, 2016 at 7:11 AM
    #239
    scheide
    scheide Well-Known Member
    nebraska
    84 toyota
    4.88 gears, marlin crawler, 4" lift,lockers front and rear,33x10.5 swampers, header, u-bolt flip kit,relocated shocks in rear,walker muffler, pinion e-brake conversion,9000 ramsey winch.
    Maybe this is my problem...I just installed a 3" lift with 5100's and toytec coils. now I have a significant vibration starting at 50 mph. Never had a problem before the lift. I have since then replaced lower ball joints, tie rod ends and new cv axles. Lowered the springs to the lowest setting , which now sets at 2" of lift. Alignment is spot on also. Could this be my problem also? I haven't tried driving it in 4hi yet. Any advice is appreciated. thanks.
  20. Mar 21, 2017 at 5:29 PM
    #240
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    I also have a 3" lift up front and 1.5" rear and I started getting vibes aswell. Axle shims fixed some of them but I still have vibes from like 60-70 and in H4 at like 50. Guess i need to consider doing this on mine.
