1st Gen 4x4 Front Diff Bearing Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, May 7, 2013.
  1. Jan 25, 2019 at 1:00 PM
    #261
    Dek Ngo
    Dek Ngo Well-Known Member
    D
    Austin, TX
    '96 4x4
    Does anyone have an already modified removal tool to sell?
  2. Jan 30, 2019 at 9:01 AM
    #262
    acs118
    acs118 Well-Known Member
    Pittsburgh, PA
    2002 4WD V6 TRD Tacoma
    Reporting on my experience:
    2002 3.4 Ext cab; Stock (specifically no lift)
    Had the whirrrling, friction/ vibration in the gas pedal and steering wheel most noticeably at 25-35mph. Heavy loading left turns made even more noise, which made me think it was the FP wheel bearing (again). No wheel movement when off the ground suggested the wheel bearing was OK.
    4-Hi made 90% of the noise and vibration go away.
    Replaced the stock needle bearing with the ECGS bushing.
    Fixed the issues mentioned above.
    tntacomaguy likes this.
  3. Feb 1, 2019 at 6:59 AM
    #263
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    How many miles are on your guy's trucks when you start getting these problems? Is there a first gen how to video out there? I just started getting this vibration, goes away in 4wd. @152,000 miles. I've had a 2.5" lift on it for about 25k miles now.
  4. Feb 1, 2019 at 7:08 AM
    #264
    Dek Ngo
    D
    Austin, TX
    '96 4x4
    My truck has 187K on it.
    Here's a good video on this process (it was done on a 3rd gen 4Runner, but it's basically identical to our 1st gens):
  5. Feb 1, 2019 at 8:41 AM
    #265
    acs118
    Pittsburgh, PA
    Noticeable effects around 135-140k miles, fixed at 145k.
    buckmaster243 likes this.
  6. Feb 1, 2019 at 9:26 AM
    #266
    synergy10
    synergy10 @synergy10.sd
    San Diego
    My previous double cab had around 115k-120k miles but it only started after I installed a lift kit. On my extra cab I never had this issue. Even after lifting it with the same exact kit...it also has just under 230k miles now.
  7. Feb 1, 2019 at 6:08 PM
    #267
    buckmaster243
    Buck
    Washington
    Anyone know if there first gen and second gen bearing puller is different? Anyone selling a first gen one if so?
  8. Feb 26, 2019 at 8:12 PM
    #268
    Phessor
    Phessor Well-Known Member
  9. May 16, 2019 at 8:03 AM
    #269
    SJTaco4x4
    SJTaco4x4 Active Member
    Charlie
    San Jose, California
    2004 DC 4x4 TRD
    Does anyone have a modified ECGS bearing removal tool for sale?
  10. Aug 23, 2019 at 7:58 AM
    #270
    yeahkkyle
    yeahkkyle Well-Known Member
    Kyle
    PA
    2002 Tacoma TRD Offroad 3.4L 5spd
    I'm about to order a ECGS Bushing to replace my needle bearing since after leveling the truck the vibration started. Question for other who had this issue. When I jack the front tires off the ground and spin the driver side tire I can hear a very slight click/bump in the front diff. Not sure if its the needle bearing making the noise. My drives side axle will move up and down like 1/8''. Anyone else have this click/bump feeling from the worn needle bearing? I might pop the front axle out and spin the diff and see if it still does it.
  11. Aug 24, 2019 at 9:27 PM
    #271
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Vibes after lifting generally are not from the diff bearing. If your bearing was bad the vibe would have been there before the lift was installed.
  12. Sep 30, 2019 at 3:45 PM
    #272
    ROLO CA
    ROLO CA New Member
    Rolando
    2004 Toyota Tacoma 4x4 4dr
    aux cord, bedliner...pretty stock
    Looking for the modified tool if anyone has one for sale. My zip is 93446
  13. Dec 3, 2019 at 7:53 AM
    #273
    kdwellssr
    kdwellssr Well-Known Member
    Kelly
    Arkansas
    99 Tacoma ext cab 4x4 v6 automatic
    30.5 tires, Nerf bars, Brush guard, Trailer tow kit
    I have a 99 Tacoma. I believe that is a 1st Gen. Mine seems to be the right side bearing as I checked it with a pry bar on the cv housing and there was a lot of movement as well as a fluid leak at that point. I can seem to find and information on that side. The outer housing bearing or More. I've taken it apart to where the bearing retainer clip is. Can I just remove the clip and slide the bearing out? The bearing I'm seeing is not a needle bearing. I see the needle bearing and bushing now. It is in the center back further inside. I was looking at the big bearing right behind the seal. Does that one need to be replaced?
  14. Dec 4, 2019 at 8:15 AM
    #274
    kdwellssr
    Kelly
    Arkansas
    any chance you would have some contact info for who to call to order? Maybe a web site I can go check it out? .I did find the web site. Still wondering if the large bearing behind the Hog ring... need to be replace?
  15. Dec 4, 2019 at 5:19 PM
    #275
    Garwood
    Garwood Well-Known Member
    Pensacola, FL
    2002 TRDOR Xtra Cab 5spd MT
  16. Dec 15, 2019 at 6:32 AM
    #276
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Anyone have the removal tool they’d like to sell?
  17. Feb 20, 2020 at 5:09 PM
    #277
    RubyTheRedTaco
    RubyTheRedTaco Well-Known Member
    NH
    '03 Ext. Cab TRD Limited 4x4
    Trying to get rid of rust!
    I've had the exact same pulsing vibration while driving ever since buying my truck with 138k miles. It's bone stock, no lift or anything special. Went for a drive today and the vibration went away in 4Hi. Got underneath and there's a significant amount of play/slop where the driver's side CV enters the front diff as well as diff fluid leaking from that area. I think the needle bearing and seal are both bad as others have experienced. I'm going to order the ECGS bushing and new seal soon and attempt to put them in myself. Does anyone have a modified removal tool they'd like to pass on? I'd greatly appreciate it, thanks!
  18. Feb 24, 2020 at 8:51 AM
    #278
    RubyTheRedTaco
    NH
    Anyone have the modified tool they'd like to sell? Bueller...Bueller....
  19. Feb 24, 2020 at 2:41 PM
    #279
    Garwood
    Pensacola, FL
    Yeah man, I got one up for grabs.
  20. Feb 24, 2020 at 9:32 PM
    #280
    RubyTheRedTaco
    NH
    Ok thanks I'll PM you
