1st Gen 4x4 Front Diff Bearing Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, May 7, 2013.
  1. Apr 5, 2014 at 8:10 AM
    #81
    jeehole
    jeehole Member
    thanks for the reply Tom.
    I think I am dealing with multiple problems. I'm pretty sure I have a wheel bearing problem, as the symptom is classic. So I'm going to proceed with my plan to replace that and the leaking oil seal. Then I'll deal with the vibration problem.
    Thanks
  2. Apr 5, 2014 at 2:13 PM
    #82
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    Sounds like a plan.... let us know how it goes.
  3. Apr 23, 2014 at 10:07 AM
    #83
    asiansurveyor
    asiansurveyor Well-Known Member
    Central Oregon
    Anyone wanting to sell their tool in a week or two? The vibration is killing me and I am ordering the bearing today.
  4. Apr 23, 2014 at 10:25 AM
    #84
    TomYotaNH
    Tom
    Seacoast NH
    Sure, mine is for sale, just send me a PM and we'll set it up.
    Tom
  5. Apr 23, 2014 at 1:14 PM
    #85
    asiansurveyor
    Central Oregon
  6. Apr 23, 2014 at 2:09 PM
    #86
    TomYotaNH
    Tom
    Seacoast NH
    Never tried it, but it looks much bigger than the tool for the diff bearing, plus you're in a pretty tight area, not sure you could get a good pull on the 'hammer'.
  7. Apr 23, 2014 at 7:43 PM
    #87
    asiansurveyor
    Central Oregon
    PM'ed, thanks Tom!
  8. Apr 24, 2014 at 7:20 AM
    #88
    asiansurveyor
    Central Oregon
    Has anyone replaced the roller needle bearing with the OEM part or has everyone replaced it with the ECGS bushing? I am just curious how can a bushing replace a bearing? Then what was the purpose of Toyota using a bearing? Any input would be helpful before I prefer either.
  9. Apr 24, 2014 at 7:25 AM
    #89
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I've heard of people doing so with mixed results, but mostly on 2nd gen. From what I understand, this is far less common in 1st gen.
    As far as a bushing vs bearing... It's not really a great comparison IMHO. I couldn't tell much difference between the two when they were out, other than the ECGs felt more substantial.
  10. Apr 24, 2014 at 7:26 AM
    #90
    johnboyTRD
    South SF bay
    Maybe someone much wiser than myself will clarify the bearing/bushing concern better :)
  11. Apr 24, 2014 at 9:36 AM
    #91
    asiansurveyor
    Central Oregon
    I am confused as how the rotation of the splined half shaft inside of the static ECGS metal bushing is better than a needle bearing? It seem to me that the shaft would just be generating heat from the metal to metal contact of the bushing or is there another bearing that allows for the rotation of the shaft when the front differential is not engaged?
  12. Apr 24, 2014 at 11:32 AM
    #92
    johnboyTRD
    South SF bay
    My understanding.... It has to do with tolerances. There is play in the needle bearing, often pronounced when lifted, which cause the vibration. The bushing which comes from ECGs is a tighter tolerance.
    If this is wrong, I truly hope someone will chime in...
  13. Apr 24, 2014 at 5:31 PM
    #93
    TomYotaNH
    Tom
    Seacoast NH
    Nope, that's the case, and there is a lubrication groove in the bushing which keeps it from heating too much from friction. There is a good video on the ECGS site for the Gen II tacomas which shows this. It really just supports the CV shaft much better going into the spline gear than the needle bearing.
    Tom
  14. Apr 24, 2014 at 6:07 PM
    #94
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    So long as it's bathed in lube, it should live just fine.
    Would definitely keep a closer eye on the gear oil on that end after doing the work.
  15. Apr 25, 2014 at 10:07 AM
    #95
    asiansurveyor
    Central Oregon
    Alright, after watching the video again, it makes more sense. Guess it can't be bad if ARB went with the bushing route too. Thanks Tom.
  16. May 3, 2014 at 12:54 PM
    #96
    asiansurveyor
    Central Oregon
    Just got done with installing a the ECGS bushing and new axle seal and I am vibration free!!! Removing the CV axle was the most time consuming part of the whole process, and removing the 35mm by yourself is tricky until I decide to use a long 2x4 to apply pressure to the break pedal.
    Here is what I used to help remove lower shock bolt:
    18A040FC-9810-463D-BD96-BE12A333BB4A_zps_c83c980c34552cb2424977515fef4452bf62a2e9.jpg
    The best tool ever to remove the old needle bearing out (Now for sale for $30 Shipped...):
    7831099F-C8D0-49E1-82DD-119FB0454825_zps_a1b0de9e3dd4d03d189ec2704f69313c7596cc6a.jpg
    Here is the best way I found to help get the new axle seal back on with a ball joint tool from AutoZone:
    A66E68EF-B0F1-4952-943C-495AD7E6568C_zps_d953cecf666500d02b6bb21662721e3c6a35f88d.jpg
    EEB13282-63EE-42C2-A3C1-14A13F3CFE88_zps_47b777d88dc30aefb42ac9f9668b9ea3e4918a21.jpg
    Overall, it wasn't bad, just time consuming if you are doing this yourself.
  17. May 3, 2014 at 2:49 PM
    #97
    soup101
    soup101 Active Member
    Joe
    Maryland
    04 SR5 TRD DC 4x4
    OME 882 Coils, OME Dakars with D6XL AAL, Nitrocharger Sport Shocks, Sky Manufacturing rear axle relocation plate set 3/4 inch towards rear, BAMF BPV Relocation Bracket, Leer 100R Shell, Trail Gear Sliders, Trail Gear Low Profile Front Bumper, CBI Outback 1.0 Rear Bumper w/ tire swing-out, Cornfed Suspension Diff Drop
    asiansurveyor - I'll take the tool. PM sent
  18. May 3, 2014 at 9:05 PM
    #98
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Subbed for later..
  19. May 4, 2014 at 7:50 AM
    #99
    TomYotaNH
    Tom
    Seacoast NH
    Glad to see it all worked out!
    and glad to see the tool keep it's US tour going :)
    TL
  20. May 4, 2014 at 2:16 PM
    #100
    asiansurveyor
    Central Oregon
    Shipping your way on monday!
