1st Gen 4x4 Front Diff Bearing Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, May 7, 2013.
  1. Nov 28, 2014 at 3:20 PM
    #141
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    What really sucks is package tracking,,as you watch your package pass twice by your house, within a mile,,then finally arrive at the step after the third pass on the freeway. Portland to Seattle,,back to the original Portland terminal it arrived at, then to here(40 miles north of Portland).
    Fedex burned a extra 327 miles due to idiocy on the dvd burner I just got.
    So there is your extra cost,,when it should have been about $5-6 for your parts. They tack on the "Whoops" percentage when they figure out there rate.
  2. Jan 20, 2015 at 3:54 PM
    #142
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I lifted my truck a couple of weeks ago and I started to get the vibration between 30-40mph. putting it in 4hi did seem to help. However, I only get the vibration when I first start driving the truck. after about 3-5mi the pulsing vibration is gone. was this the same for the rest of you guys?
  3. Jan 20, 2015 at 8:58 PM
    #143
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Mine did not go away over time that I recall. But other than that sounds about right. My vibes did go away completely in 4hi.
  4. Jan 21, 2015 at 1:29 PM
    #144
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    No. The noise we are referring to normally doesn't go away regardless of how lucky ng you drive but mine did seem to go away over about 35 mph
  5. Jan 21, 2015 at 3:39 PM
    #145
    chowwwww
    Orange County
    03 Doublecab 4x4
    I want to make sure that it's the needle bearing before I buy the parts. Guess I'll just have to dig around and maybe have a mechanic look at it then. Thanks. It sounds like its the needle bearing though. Just want to make sure first.
  6. Jan 27, 2015 at 8:48 PM
    #146
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    To all the members that have done this upgrade. Is it just the driver's side? I have the same symptoms with my 2000 tacoma with 256k.
  7. Jan 27, 2015 at 9:00 PM
    #147
    johnboyTRD
    South SF bay
    Just driver yup
  8. Jan 28, 2015 at 11:14 AM
    #148
    JAGER91374
    Des Plaines
    3 TRD O/R
    Yes. Just the driver side.
    Pretty easy fix just make sure you buy the tool from someone that has already done the repair as there is significant grinding required to make the took fit.
  9. Jan 28, 2015 at 11:36 AM
    #149
    520Toyota
    C.V.
    Nor Cal
    Ome lift
    Does anyone have the specification, dimensions or tolerances on that tool? I can machine a tapped plate that goes in the needle bearing.
  10. Jan 28, 2015 at 1:11 PM
    #150
    johnboyTRD
    South SF bay
    I do not, sorry.
  11. Feb 4, 2015 at 5:03 PM
    #151
    JTrean
    JTrean Well-Known Member
    Not sure if I fit into the specific vibration speed as everyone else here, but I have a vibration at 50mph plus. It feels like it's coming from my driver front. The steering wheels shakes, feel it at my feet and my cv axel spits grease out all over the place. I had the cv replaced when I bought the truck two years ago and it has been spitting grease ever since. Today I got under my truck and could feel a bit of play in my cv axle where it goes into the front diff. The passenger side had some play as well but not as much as the driver side. My truck does have a diff drop as well. Any insight would be appreciated.
  12. Feb 10, 2015 at 6:54 AM
    #152
    EngRWW33
    EngRWW33 Well-Known Member
    Anybody have a removal tool for sale? I'm getting the vibes described above (albeit much worse when cold; ALMOST unnoticeable when warm) and would like to tackle this before they get worse.
  13. Feb 23, 2015 at 7:34 PM
    #153
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
  14. Feb 23, 2015 at 7:42 PM
    #154
    JTrean
    Modifying the removal tool is very easy with a Dremel.
  15. Feb 23, 2015 at 9:59 PM
    #155
    EastBayTaco
    EastBayTaco Well-Known Member
    Carlos
    Bay Area, CA
    96 Tacoma 4x4 SR5
    OME Everything! (883 coils with Dakars), Light Racing UCAs, Wheelers SS brake lines, Toytec 1" lift shackles, Magnaflow muffler, CKMA12 ARB On-Board Air Compressor, Custom 80' Sliders
    I ordered the tool/ bushing and will be here this week. Install likely done this weekend so I'll have tool ready for sale by next week.
  16. Feb 24, 2015 at 5:36 AM
    #156
    EngRWW33
    I have no doubt about that, but if I can help a member recoup some of the money they spent on a (possibly) 1 time tool and at the same time maybe save $5-$10, then I would prefer to do so.
  17. Feb 24, 2015 at 8:14 AM
    #157
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    I just order the bushing and tool as well. Hopefully I'll get it done this weekend, then there will be another tool in circulation for whoever needs it.
  18. Feb 24, 2015 at 8:56 AM
    #158
    johnboyTRD
    South SF bay
    Too bad we didn't sync up earlier rob, heck I could have dropped mine off to you lol
  19. Feb 24, 2015 at 8:56 AM
    #159
    johnboyTRD
    South SF bay
    I sent my tool to someone who sent it to someone I believe... What a great community.
  20. Feb 24, 2015 at 10:20 AM
    #160
    johnboyTRD
    South SF bay
