1st Gen A/C System Replacement How-To (Seized Compressor)
Discussion in '1st Gen. Tacomas (1995-2004)' started by geodude, Aug 31, 2013.
  1. Aug 5, 2020 at 2:08 PM
    #161
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I don't know if the oil mixes up with the refrigerant; I mean, the UV dye definitely does, so it would make sense that the oil does too.
    The idea isn't to just remove oil - I'd evac the system, and then refill the compressor with a bit less than I put in last time.
    The temps on the freeway are about 2-4F lower than just in the driveway; so different, but not by much. That could also have to do with the fact that it's 15F cooler outside than it was when I measured the other day (just due to time of day)
    Fun times, lol.
    cruiserguy[QUOTED] likes this.
  2. Aug 5, 2020 at 3:24 PM
    #162
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Oh that's nothing in regards to temp differences. I wouldn't think on the fan clutch anymore, if cold air temps only got 2-4 degrees cooler.
    I misunderstood. I thought I saw a post where you're cold air at vent was measuring 60+ or something. So I thought man, if you got 48 degrees on interstate, that's definitely an air flow issue. So that's what led me to that line of thinking. What's optimal vent temp? Low 40s?
    I mean yeah you can evacuate all the refrigerant and do it all over, but I'd want to be more sure that's the issue before doing that. First, I think I'd try letting a bit out of the low side, while it's running so you can't suck in air, and see if you get different temps. Overfilled and/or over-oiled refrigerant mix will hinder cooling.
  3. Aug 5, 2020 at 3:27 PM
    #163
    cruiserguy
    Elijah
    SEKS
    I really enjoy trying to help when folks have a good data and testing and details. Like you do:D
    With all the solid info you provide, it's like I have a real good clear idea of what you're seeing and stuff and that helps soooooo much. Troubleshooting over the internets can be extremely difficult :D
  4. Aug 6, 2020 at 7:56 AM
    #164
    Ragnar
    Ragnar Member
    Derek
    2003 Tacoma 3.4L V6
    Has anyone else had immense trouble with removing the mounting bolts from the compressor?
    I’ve had no luck removing the bottom two bolts on the compressor. They’re extremely hard to get to even with plenty of extensions, joints, and blaster.
    I’ve tried coming at them from below (removing the skid plate) and also through the wheel bay but with no luck.
    Anyone have any tips or tricks?
  5. Aug 6, 2020 at 8:03 AM
    #165
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Regular or wobble?
  6. Aug 6, 2020 at 8:11 AM
    #166
    Ragnar
    Ragnar Member
    Derek
    2003 Tacoma 3.4L V6
    wobble
  7. May 7, 2021 at 5:53 AM
    #167
    1997tacomav6
    Denver
    To remove the ac compressor do you need to remove the power steering pump?
    Fan shroud?
  8. May 8, 2021 at 1:32 PM
    #168
    turbodb
    Dan
    PNW
    AdventureTaco
    1997tacomav6[QUOTED] likes this.
  9. Apr 6, 2022 at 4:25 PM
    #169
    tidmarshsmiths5
    tidmarshsmiths5 Member
    Paul
    2004 Tacoma Prerunner 2.7 2wd
    Gold Standard!!!
  10. Apr 16, 2023 at 5:58 AM
    #170
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    this is a super helpful & informative thread/post for a toyota noob!
    thanks to the OP for all the work & to the member who told me to look here for my problems.
  11. Sep 25, 2023 at 9:30 AM
    #171
    geodude
    geodude [OP] Well-Known Member
    Glad to see this helped some people out.
    As an update: 10 years and ~130k additional miles after this repair, A/C still blowing cold. Thanks
    otis24 likes this.
