1st Gen and 2nd Gen wheels/tires - interchangeable?
Discussion in 'Wheels & Tires' started by mooch91, Dec 31, 2011.
  1. Dec 31, 2011 at 4:52 AM
    mooch91
    mooch91 [OP] Well-Known Member
    PA
    2012 Tacoma AC SR5 4x4
    All,
    Need a fairly quick answer (if possible): are 1st Gen and 2nd Gen wheels and tires interchangeable?
    That is, would 265/70/16 wheels and tires from a 2nd Gen fit on a 1998, and vice versa, would the 31/10.5/15 (6 lug) from a 1998 fit on a 2nd Gen? I know the overall dimensions are about the same, but I don't know much about the bolt patterns, backspacing, and brake clearance on the two.
    And are all 1st Gen (through 2004) interchangeable?
    Thanks!
  2. Dec 31, 2011 at 6:09 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2002 Sliver-ade-o 2008 P71
    Yes
    The second gen wheels will fit the 1998 but the backspacing is less (more tucked in). 15 inch wheels will not fit a second gen.
  3. Dec 31, 2011 at 6:13 AM
    mooch91
    PA
    Thanks... actually found out that I need to confirm if a 6-lug on a 98 Tacoma 4x4 (31x10.5x15) is the same as a 6-lug on a 94 4x4 (265x70x16).
    If anyone knows, please let me know! Thanks!
